Below is the latest progress on my turbo build, I've started collecting parts since early 2015 and have finally gotten to this point. The run below is at 13psi (E85) making 540whp/488wtq on a Dynojet, once I get the eBoost2 configured I'll up it to ~16. Update 12/12/16: Turned up to 18psi and made 610whp/571wtq. See post #17 below for dyno sheet etc.
I'm not so active on BFC as of late posting most of my progress on Instagram, feel free to give me a follow!: @re36tro
Turbo related modifications:
- Garrett GT35R Turbo
- SPA T3 Manifold
- CES/Cutring HG (no spacer)
- RK Tunes E85 Tune
- ARP Studs
- 115lb Injectors
- Rally Road fuel rail
- Walbro 400lph FP
- Aeromotive FPR
- Tial BOV
- Tial 44mm MVR WG
- Full 3" DP/Exhaust (Vibrant)
Zeitronix log at 13psi
My favorite build.
Looks like everything worked out extremely well. As those are awesome #'s.
Well done.
1996 332IS
Built 3.2
Technique Tuning 80# tune.
1/4 mile 10.84 @ 136.72
WWW.CESMOTORSPORT.COM
Nice looking build and car!
Not sure if I want to test drive that beast. Mines gonna feel really slow if I do.
Thanks...obviously couldn't of done it w/ out your help and of course parts
Appreciate it
30whp not much of a difference, but the R888's you may feel
Thanks! Ya, if you're talking exact then your goals are well within reach. I may turn it up to ~16-17 soon but probably no higher. I'm still on a stock bottom end.
2006 CB M3/2/SMG
1998 AW M3/2/GT35R
I'm not sure you have to worry about the stock bottom on E85 as long as your tune is good... the only warning I've gotten is that the GT35R spools so fast that even on a good tune, the rods are susceptible to bending over time (like several thousands of miles of repeated beating). And we're talking gradual bending, not snapping in half.. detonation does that and if your tune is good you shouldn't have that to worry about.
If the ultimate plan is to build the bottom end (someday)... I'd let her rip... check the compression on occasion and perhaps measure/compare piston height through a spark plug hole. If you were to catch it early, what would keep someone from just throwing a set of rods and bearings in it if the pistons/walls still look good.... that's not very expensive and can be done in your garage.
Very nice!
What hot side?
This is not me at disrespectful; but I'm shocked that there is not more torque with stock compression and 13psi with e85.
This is my signature....
I actually thought the same but as I'm new to this, my guess is as good as yours.
Just start from 0 and increment by 50 per division. Same goes for the Z axis. These are all pics from my phone to Instagram thus reason for size reduction.
2006 CB M3/2/SMG
1998 AW M3/2/GT35R
Probably really good actually since it will only help the rods/block.
Dean just did 610whp/571twq @ 18psi
Took me 21 psi to do that on 93 pump with GT3582R. Good job. Does the turbo have more in it? I did not really think so.
Not bad for T3 setup.
1996 332IS
Built 3.2
To be honest it might have more...the HP plots seem to still be going strong at 18psi but that's a lot further than i was planning/expecting on going on stock internals. I dialed it down after this one run. I will probably boost no more than 16psi which should be in the 560whp/520wtq range.
Ya, I thought it would of tapped out. Your GT35R unit is still running strong.
Updated dyno 12/12/16:
12psi: 500whp/462wtq
15psi: 550whp/505wtq
18psi: 610whp/571wtq
Zeitronix log at 18psi:
2006 CB M3/2/SMG
1998 AW M3/2/GT35R
Really impressive dude.
Nice responsive 600whp system, nice and simple.
My $0.03 is to top it out at 21-22#'s and be happy. Stop there ! Don't get greedy.
1996 332IS
Built 3.2
Wow...22psi? That would probably put me about 670whp/630wtq (assuming things hold up). I was under the impression the general (yet aggressive) rule of thumb for stock internals was to limit under 550wtq. I actually was nervous to hit those numbers at 18 and will probably go no higher than 16.
2006 CB M3/2/SMG
1998 AW M3/2/GT35R
Keep it at 18, youll be okay, just started following you on instagram, sweet build.
1996 332IS
Built 3.2
1996 332IS
Built 3.2
Lol your right, but still, i didnt window the block until 34-35lbs, 28-29psi felt great and didnt break, going built now and seeing where I end up, ill be haopy with the car in the 750-800 range, it was dead reliable at 600-650whp on stock internals, part of me wishes I kept it at that level.
Need more instagram accounts to follow from binmerforums users. Wanna see the beasts in action.
