Page 5 of 5 FirstFirst 12345
Results 101 to 104 of 104
Thread: 99 E36 M3 STU/ GTS2-3 build #thesilvercar
  1. #101
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by NotoriousJJE View Post
    Man it sure looks like fiberglass but Mike said it wasn't. I can't tell what it is. I will take close up pics of the underside and post them.
    From the look of the spot of damage you showed in your pic above, the area in question is definitely fiberglass. When you cut the hole for the hood vent if the dust from the cut was white, then I'd say the whole hood is fiberglass. If it was carbon, the dust and the fibers/strands in that damaged area would be black.
  2. #102
    Apr 2014
    Slidell, LA
    Many
    And fiberglass has a very distinctive smell when cut. Takes me days to get the smell out my head/nose.
  3. #103
    Nov 2007
    Orlando
    99 M3, 11 GT3RS
    Quote Originally Posted by jakermac View Post
    Definitely not carbon. I just remember Mike saying that it was a different cloth than fiberglass. Weird. Been around boats long enough that I should know it when I see it. When I cut it, I didnt get it all in my arms and hands like I usually would with fiberglass but it definitely could be.
    So after I fixed the motor, I got back to trying to diagnose what was going on with the brake lines. The lines themselves were fine, the leak was coming from two of the fittings adapting the stock hardlines to the stainless lines going to the firewall. The problem has to be coming from the flares.
    This exposed a fundamental flaw with the way I plumbed it. In order to fix a problem in the brake lines, I have to drop the motor. This is a terrible problem and really shortsighted on my behalf. So I decided I need to re-plumb them.
    Dropping the motor with the whole subfram is about eleventy billion times easier than the other way. We did it an hour.
    IMG_8961[1] by NotoriousJJE, on Flickr
    Revisiting the brake lines, the access here sucks. To avoid problems in the future, I am going to eliminate all the junctions in this area.
    IMG_8963[1] by NotoriousJJE, on Flickr
    First step is going straight from the master to the firewall. I should have done this from the beginnig.
    Next step is flaring the rear hard lines in a better spot (underneath the car) and running ne hard line from underneath the car to the firewall.
    The last step is replumbing the front lines all together. I am going to go from the bimmerworld brake lines to new stainless lines all the way to the firewall.
    The AN stff is sealing great and is fairly easy to do. GOing to try and stick to it.
    Thoughts?
    99 M3 STU/ GTS3 Project
  4. #104
    Vancouver, BC Ca
    1993 325is
    Most likely S-glass. A lighter more advanced version of fiberglass.
  1. 99 E36 M3 LSx Build
    By ckpitt55 in forum Engine Conversions
    Last Post: 07-08-2017, 03:08 PM
  2. E36 FS 99 e36 M3 suspension parts, will also fit e36 3 series
    By ricanbmw7 in forum Suspensions, Springs & Shocks
    Last Post: 08-24-2010, 01:36 AM
  3. E36 96-99 E36 M3 Upper Strut Mounts
    By desynch in forum BMW Parts Wanted sponsored by Bavarian Auto Recycling
    Last Post: 07-07-2010, 08:35 PM
  4. E36 WTB: 95-99 E36 M3 near Florida
    By RacerSi in forum 3 series & Z Series
    Last Post: 03-17-2010, 06:56 PM
  5. E36 96-99 E36 M3 Bilstein Sports - $500
    By desynch in forum Suspensions, Springs & Shocks
    Last Post: 12-08-2009, 10:49 PM
