BMW E36 DRL (Daytime Running Lights) Euro/Canada Module Relay 61358368039 61.35-8 368 039
Selling my two Euro/Canadian DRL modules for the E36. They are both tested to be 100 percent working. These are very hard to find in the US for a good price.
One is the older 6 pin module and the other is the later 7 pin module. I used the 6 pin one in my E36 and it requires a bit of modification for it to work, but not much. The only difference is that the fogs will not turn off when you use your high beams.
If your car is built 94 and older, you can swap the relay and you have DRL's instantly. If you are 95+, You must add pins 1 and 5 to get the DRL's to work, and tap them into the headlight switch harness. More details here:
60 shipped each. PM me before buying, I do not use Panjo. Please let me know which one you need (6 pin or 7 pin).
http://www.unofficialbmw.com/e36/electrical/e36_daytime_running_lights.html
List Date: 11/6/2016
For more info, click here to view the original listing: BMW E36 DRL (Daytime Running Lights) Euro/Canada Module Relay 61358368039 61.35-8 368 039
This item is no longer available.
