Page 4 of 14 FirstFirst 12345678910111213 ... LastLast
Results 76 to 100 of 348
Thread: Project "Try Out Drifting" (with an old slushbox E36 sedan)
  1. #76
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Quote Originally Posted by Press22 View Post
    Man this thread is awesome. I'm always jealous of the tracks everyone gets to have close by.
    Thanks!
    I do feel very fortunate to have these events available at AutoCity Speedway. Although kart racing was a COMPLETE blast, I'm pretty sure I've never had as much fun racing as I have at these events just getting sideways and trying to make smoke.
  2. #77
    Miramar, Florida
    supra
    LSD, 3.91, replaced sub frame along w/bushings... koni sa 550f 650r. Also seat and wheel... my 3rd time out 2nd time was mostly in pits though.
    Sent from my iPad using Tapatalk
  3. #78
    DeWitt, Michigan
    Thanks! Are you still around here suffering the frigid cold, or are you back in Florida as listed in your location?
  4. #79
    Aug 2015
    California
    95 M3
    broken camberarms.jpgI see that you can weld. It would be a good Idea to pull your camber arms off and reinforce the pieces circled. I've seen 3 different ebay arms break at the clevis while drifting. You could remake the c piece with thicker metal or weld some plate onto it to beef it up.
  5. #80
    DeWitt, Michigan
    Thanks, I'll take a look at them in the spring before I hit an event.
    Did the clevis material itself break, or was it the weld where the threaded rod is attached to the clevis material? I can see that being a natural break point the way they are attached.
  6. #81
    fairfax,va, usa
    2 E30s and a maxima
    yea pix? I have a set of those and don't want to snap them lol.
  7. #82
    Aug 2015
    California
    95 M3
    Quote Originally Posted by tptrsn View Post
    I've seen it happen both ways. The first time the threaded rod ripped out of the clevis where it was welded the next time the clevis itself broke where it attaches to the knuckle.
  8. #83
    DeWitt, Michigan
    Wow, I'm surprised that the clevis material would break... I'll give mine a good looking over next time I have a handy opportunity, and see if it looks like I need to be doing any reinforcing. You wouldn't happen to have access to any pics of those breaks would you? I'm guessing not, but it would be cool to see, especially to see where that clevis fatigued and broke.
  9. #84
    fairfax,va, usa
    2 E30s and a maxima
    Yea I'm not seeing how you can reinforce it any better.
  10. #85
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    compare them to the TMS one's and you'll see why they break.
  11. #86
    DeWitt, Michigan
    Is that Turner Motorsports?
    Like these?:
    https://www.turnermotorsport.com/p-3...ttrack/?pdk=Aw
    I think I can replicate that level of strength with a bit of my hackery.
  12. #87
    Aug 2015
    California
    95 M3
    Sorry guys I asked and they don't have pics. I'll take a picture of how they welded it back together next time I'm at my friends house.
  13. #88
    BALTIMORE
    the OE arms are literally made out of stamped sheet metal, yet oddly enough people run them all the time without shearing them in half
    the pictured arms' clevis is made from 3mm formed steel plate and has a 18mm bolt with nearly 56mm of weld holding it to the plate. even accounting for the (probably) shitty chinese welds, short of wall taps and/or minor wrecks, i don't see why they would suddenly break on track
    just remember, if the camber arm doesn't bend/break during a wreck your trailing arm/subframe will
    Popular engine swap weights & stock engine weights
    M42 + trans - 427lbs
    302 + t5 trans - 475lbs
    m20b27 + g260 - 497lbs
    m52b25 vanos + g250 - 544lbs
    351w + t5 trans - 572.5lbs
    LS,
    aluminum block + t56 - 609lbs
    LS, iron block + t56 - 719lbs, EST.
    http://www.bimmerforums.com/forum/sh...60-m42-1jz-2jz
  14. #89
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    Like these?:
    yep, thats them. never seen one break, and i've seen 2 after wall impacts. They do bend though.
  15. #90
    Aug 2015
    California
    95 M3
    Quote Originally Posted by jalopi View Post
    The stock arm is also stronger where it mounts to the knuckle than the ebay ones. Neither of my friends who broke theirs even hit anything. That's the scary part. It's a great way to get that jdm camber you're looking for. This also broke his outer cv joint. broken camber arm.JPG
  16. #91
    BALTIMORE
    i dunno man, something tells me your friends made some curb/wall taps on those ebay arms and never told you about em, people have been running those for years with no issues
    LS,
  17. #92
    DeWitt, Michigan
    Well, nonetheless, I will be taking a good look at mine then next time I have a decent opportunity staring me in the face. Maybe the next time we have snow if I'm not in a hurry when I slap on the snow tires I'll take a peek at them. This car is a riot in the winter now that I replaced the blower motor resistor.
  18. #93
    DeWitt, Michigan
    Some video of the awesomely horrible LRS doing its thing just popped up! Not one of my more exciting runs, but at least I didn't spin out on this one..
    Or on bookface:
    https://www.facebook.com/dailydriver...2773864840243/
    Watching this video reminded me that I want more power. Just ordered a turbo haha..
  19. #94
    Oct 2012
    Las Vegas, NV
    E36 M3, jzxE28
    That was a cool little section.
    What turbo did ya get? Spill the beans!
    instagram @andyitslit
  20. #95
    fairfax,va, usa
    2 E30s and a maxima
    Won't manual swap. But will turbo. lol you're funny.
  21. #96
    DeWitt, Michigan
    Fitting with my theme of slapping as much cheap eBay Chinese garbage as possible on this car, I got this one:
    http://www.ebay.com/itm/131612722990...%3AMEBIDX%3AIT
    If that turbo isn't quite as responsive as I want, I will buy an even cheaper, even smaller one ...
    I already have a much maligned $129 eBay turbo manifold (that actually looks much better quality than I expected), some Siemens Deka 80# injectors, and a TiAL 38 wastegate sitting on a shelf to go with the turbo.
    But I'm forcing myself to get the 540 turbo project much closer to running before I get to play with the LRS much more. The 540 project is a chore, the LRS project is the reward haha.
    Quote Originally Posted by protomor View Post
    Thank you sir! I still like turbos despite my hatred of clutches I've grown into.
    Besides that, with enough power I won't need to kick the clutch so much, right? Lol
  22. #97
    fairfax,va, usa
    2 E30s and a maxima
    Yea but won't you fry the auto trans? Those things don't like heat IIRC.
  23. #98
    DeWitt, Michigan
    Only one way to find out. So far it's been a champ, and I have this sitting in the garage waiting to be abused:
    At this point it's sort of a race to see if I smoke the clutch or gearbox in the 540 mit turbo and put the th400 in that, or if the slushbox in the LRS gives up first and gets to try out a th400 swap kit from someguy2800.
  24. #99
    fairfax,va, usa
    2 E30s and a maxima
    More power to you man. Just don't fall into the perpetual build trap. So far you've managed it well though.
  25. #100
    DeWitt, Michigan
    I hear you on that!! Gotta get 'er done fast and wreck more tires.
  1. Replies: 0
    Last Post: 05-09-2013, 03:59 PM
  2. Anyone with an Artic Silver e36 try to paint their front corners?
    By highboostingm3 in forum BMW Rides & Events
    Last Post: 07-29-2004, 07:35 AM
  3. Quick Run with an old fox body 5.0
    By jcsomerset in forum Kill Stories
    Last Post: 02-29-2004, 07:20 AM
  4. Reunited with an old friend...
    By Kevlar in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-21-2002, 09:59 AM
  5. can anyone peel out from start with an automatic?
    By DeezBMW in forum 1991 - 1999 (E36)
    Last Post: 04-01-2001, 06:29 PM
