Infiniti G35S Turbo BMW M3/4/5 Ninja ZX6R 636
Penn State University '08...better than your school since 1855
Sigma Lambda Beta International Fraternity Incorporated
UTI Class of '10, BMW "STEPchild"
Acurazine.com Mod Squad
Interesting, good to know for future reference. Might have to make a trip to WPB soon to see my cousin, maybe JuCo and I can see this car run lol.
Put some id1700x injectors in. These are small body injectors therefore fitment was a little different due to the plugs being lower. It required detaching the injector plugs from the harness cover. There are little rubber grommets, that you remove, and gives about an inch of wire slack needed to reach the plugs.
My id1000's with pnp adapters will be up for sale shortly. About 1000 miles on them.
[QUOTE=BlackPearlZ;29568325]Put some id1700x injectors in. These are small body injectors therefore fitment was a little different due to the plugs being lower. It required detaching the injector plugs from the harness cover. There are little rubber grommets, that you remove, and gives about an inch of wire slack needed to reach the plugs.
Any good place to buy the 1700x? The least i found was 1500$!!!
1989 535i - sold
1999 M3 Tiag/Dove - sold
So who is the guy associated with that was selling the injectors below MAP? I assume MAP is Manufacturers Advertised Pricing/MSRP? At first I thought you mean MAP as in https://www.maperformance.com/
Little pull I did today https://www.instagram.com/p/BPlpAzkF0Gx/
25ish with a boost leak. That fitting on the back of the manifold keeps popping out slightly. Never had a problem with it until the last 3 times I drove the car.
Sounds nasty! Love how hard it looks like it's pulling too.
Thanks guys, when that turkey neck isn't half popped out it's a lot better. Usually 3rd gear is sideways.
I'm gonna order a diff here soon. Was leaning towards a 2.93, but I saw the ICS guy swearing by the 2.79. My plan is a half mile event at the end of March.
