Page 6 of 8 FirstFirst 12345678 LastLast
Results 126 to 150 of 187
Thread: BlackPearl's V2 Build: The Steed and the 69 sxe
  1. #126
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Not worried about the 188 holding up?
  2. #127
    Nov 2005
    Tampa, Florida
    TURBO 99 M3, F82 M4
    Quote Originally Posted by BlackPearlZ View Post
    Thanks guys, when that turkey neck isn't half popped out it's a lot better. Usually 3rd gear is sideways.
    I'm gonna order a diff here soon. Was leaning towards a 2.93, but I saw the ICS guy swearing by the 2.79. My plan is a half mile event at the end of March.
    Nice I was planning on running at that event myself, they delayed the registration so the event might be cancelled and rescheduled. How much of a difference do you feel the new steed makes?
    Mod list - M50 manifold; TechniqueTuning Stg2, Apex Arc-8, ZKW euro, clear corners Mike R diffbrace, Koni Yell with HR race
    X-brace UCC tranny mounts -BLK/with enforcers, powerflex rtabs,lcabs, AAfanclutch, mishimoto rad, UCC Ultra-cerametallic Clutch.
    You will go through days of joy and days of sadness as the pursuit for power leads to madness...
  3. #128
    Sep 2010
    Boynton Beach, FL
    Turbo 350Z
    Quote Originally Posted by rajicase View Post
    Not really. I mostly do rolling runs. If it were to die I would expect it do be from a launch.
    Quote Originally Posted by JuCo View Post
    I saw the facebook post last night. I'm pretty bummed. I really don't want to have to go to Ocala.
    I don't really have an apples to apples comparison, but I think with my 666 spool up probably would have been very close. The important difference to me is how much cooler my engine temps are with the bottom mount setup, and that I was easily able to add a/c back in.
    '97 M3/4 3.0l "Frankenstein" 760whp
    E90 335i 6mt Sold
    '97 Jetta TDi 16v ABA swap w/ pt6266 Sold
    2004.5 350Z APS ST 475whp 505wtq Sold
    2000 323i Sold
  4. #129
    May 2016
    hiram ga
    e36 325is turbo m3 swap
    im thinking about going with the steed, i see you said the stock motor mount worked but you cut your condor mount? im confused.
  5. #130
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I'll guess he meant stock motor mount arm.
  6. #131
    Sep 2010
    Boynton Beach, FL
    Turbo 350Z
    Yes, the stock arm works if you run a screen rather than an intake pipe/filter. The motor mount interfered with the turbo inlet, therefore I cut it in half. I think I posted a few pics a couple pages back.
    E90 335i 6mt Sold
    2000 323i Sold
  7. #132
    Mar 2011
    Neverland
    E34 525i
    hope you took some vids of your runs. That thing was moving
  8. #133
    Sep 2010
    Boynton Beach, FL
    Turbo 350Z
    Quote Originally Posted by Hofmeister View Post
    I got one from the stands and one I had mounted on the car. I'll Upload later. She ran ok. I gotta figure out how to keep that turkey neck fitting in. I pulled the manifold and epoxied it, still blew it out. Also, my m50 manifold has developed a slight crack in one of the runners. Its not all the through... yet. I've been eyeing one of those ebay aluminum front facing manifolds, or going to the junk yard and getting another m50.
    E90 335i 6mt Sold
    2000 323i Sold
  9. #134
    Jun 2005
    New England
    Get a metal barb fitting and thread and epoxy it in place. Mine is a natural gas fitting and has been in there 10 years.
  10. #135
    Sep 2010
    Boynton Beach, FL
    Turbo 350Z
    I'll give that a go, thanks for the tip.
    E90 335i 6mt Sold
    2000 323i Sold
  11. #136
    Apr 2006
    Minnesota eh?
    86 325es
    I think a 1" NPT fitting is the right size if I remember right. It will actually thread into the hole in the intake and can be sealed up with epoxy.
  12. #137
    Mar 2012
    Renton, Wa
    98 m3
    X3 for the brass type fittings. Going on 4 years without a hiccup.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  13. #138
    Vancouver, B.C., Canada
    '97 M3
    You guys are just using the wrong sealant/glue.
  14. #139
    Feb 2012
    1995 BMW M3
    I epoxied my plastic OE fitting in place. Been rock solid for 15k miles.
  15. #140
    Sep 2010
    Boynton Beach, FL
    Turbo 350Z
    I pulled the manifold this evening to put a fitting in and found a second crack developing. I'm considering just getting one of those ebay aluminum manifolds. I don't care if it doesn't gain any power, I just don't want to have another plastic manifold start to do the same thing. A little being wouldn't be bad either.
    E90 335i 6mt Sold
    2000 323i Sold
  16. #141
    Toronto, Canada
    E36 Turbo
    I'm no expert, but your failure seems to be very, very rare. IMO you would be better off getting another M50 manifold vs that Chinese ebay junk that looks like it was designed and assembled by Ray Charles.
  17. #142
    Apr 2006
    Minnesota eh?
    86 325es
    I found another intake manifold option the other day. Cast aluminum and 467 US dollars plus shipping
    https://www.ksr.as/en/products/bmw-r...-manifold-80mm
  18. #143
    '97 M3
    Quote Originally Posted by notorious vr View Post
    ......that chinese ebay junk that looks like it was designed and assembled by ray charles.
    lol!
  19. #144
    Sep 2008
    Toronto, ON
    6465 328ti
    I found another intake manifold option the other day. Cast aluminum and 467 US dollars plus shipping https://www.ksr.as/en/products/bmw-r...-manifold-80mm
    That looks good, damn
  20. #145
    Apr 2006
    Minnesota eh?
    86 325es
    I asked them if they would sell me the runner section so I can make my own plenum but no dice on that. I am toying with standing the motor up some more.
  21. #146
    Bellingham, WA
    e30
    http://racehead.com.au/products-page...50-52-itb-kit/
    I'm pretty sure Rama would sell you just the runners based on other comments he has made. Just another option.
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  22. #147
    Apr 2006
    Minnesota eh?
    86 325es
    I just sent him an email. If I keep spending money I won't be able to finish the car this spring but it would be nice to do it once and not have to redo everything in a year.
  23. #148
    Sep 2008
    Toronto, ON
    6465 328ti
    Do you know how much shipping would be? Trying to crunch a final number arrived in my hands
    Oh and what kind of 80mm Throttle body it uses?
  24. #149
    Sep 2010
    Boynton Beach, FL
    Turbo 350Z
    Ross machine sells nice manifold building parts. I built a plenum for my vw from their stuff years ago.
    They use the Godspeed throttle body's. I've used that 80mm before, also on my vw. It requires a Infiniti tps sensor, or slightly modified ka24de sensor. I used the ka as it was much cheaper.
    I think I'll scoop up the ray Charles for science. They said 190 shipped for 3 day ups shipping.
    E90 335i 6mt Sold
    2000 323i Sold
  25. #150
    Sep 2008
    Toronto, ON
    6465 328ti
    Ross machine sells nice manifold building parts. I built a plenum for my vw from their stuff years ago. They use the Godspeed throttle body's. I've used that 80mm before, also on my vw. It requires a Infiniti tps sensor, or slightly modified ka24de sensor. I used the ka as it was much cheaper. I think I'll scoop up the ray Charles for science. They said 190 shipped for 3 day ups shipping.
    Props to giving it a go, hope it works well keep us posted!
  1. E30 build! Some questions and the build
    By Bennysbmw in forum 1983 - 1991 (E30)
    Last Post: 01-16-2016, 11:51 PM
  2. Spec E36 build current picture and the Jaffster knob!
    By S.Lang in forum Track Car Builds
    Last Post: 12-01-2007, 04:09 AM
  3. What year did the ASC and the LSD start?
    By .....Dhan..... in forum 1991 - 1999 (E36)
    Last Post: 01-16-2007, 07:51 PM
  4. What are they building in Glendale where the 134 and the 2 cross?
    By Ghery in forum California sponsored by Avus Autosport
    Last Post: 04-22-2005, 05:29 PM
  5. Replies: 5
    Last Post: 10-01-2001, 09:42 PM
