Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 89
Thread: 6-speed manual swap into e36 m3
  1. #51
    Mar 2001
    FL
    E36, E46
    6 speeds have essentially identical in-gear ratios the 5 speeds do. You're just adding an overdrive.
    Quote Originally Posted by Baby ///M3 View Post
    I have a six-speed unit from the E46 M3 paired with a 3.91 diff. But my supercharged E36 is making around 380rwhp or so.
    This combo is not as bad as some may think considering that I do equal amount of city/highway driving on my E36 (although it's not driven very often). Despite the lower gear ratio, I actually find myself shifting less driving around in the city, as I can just leave it in the fifth gear without shifting as long as I am not going slower than 20mph. 1st gear is still very useful going up a steep driveway and driving around in the parking lots.
    Does anyone know how different ratios would impact the way a supercharged E36 accelerates? I had a hard time keeping up with a stock late model Mustang GT off the line this other day because I had to shift to 3rd even before we broke the speed limit.
    Jon
    Echoing exactly what Braymond said..
    As i've touched on in other posts, S52's just don't take well to short gearing. The concept big turbo guys use applies to you too - by running taller(lower ratio) rear end, you'll stay in boost longer and capitalize on the power band. Short gearing winds the gear out quicker, but in the case of a centri SC your mega power range is even smaller than a turbo to begin with so you are basically shifting yourself *OUT* of peak power. Not to mention creating unnecessary traction issues and negating the value of having a 6 speed. With your power and style of use you should be running a 3.46 max IMO.
    Very very rough math: +size wheels will offset your ratio by one gear step give or take. So by running 18's with a 3.46 it would be like running 17's with a 3.38. 3.73 would behave like a 3.64, etc. Vice versa, 17's with a 3.46 would be like 18's with a 3.64, or in your case 3.91+18" is more like 17's with a 3.73.
    '99 Estoril Blue + Dove Grey ///M3 coupe
    '04 Jet Black + Cinnamon ///
    M3 coupe
  2. #52
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    Quote Originally Posted by jvit27 View Post
    As i've touched on in other posts, S52's just don't take well to short gearing. The concept big turbo guys use applies to you too - by running taller(lower ratio) rear end, you'll stay in boost longer and capitalize on the power band. Short gearing winds the gear out quicker, but in the case of a centri SC your mega power range is even smaller than a turbo to begin with so you are basically shifting yourself *OUT* of peak power. Not to mention creating unnecessary traction issues and negating the value of having a 6 speed. With your power and style of us you should be running a 3.46 max IMO.
    This!
  3. #53
    Jul 2002
    Los Angeles
    08' M5 & 98' M3
    Excellent points!
    Thank you both for your help. Time to hunt down a 3.46 diff to replace the 3.91.
    Jon
    08' BMW M5 (Alpine white/Indy red) - Dinan/Brembo/Corsa/Forgestar/Vorsteiner/3M/Dinmann/SMG
    98' BMW M3 (Dakar yellow/black) - Dinan/RMS/Vortech/Work/Denon/Brax/Helix/3M/Recaro/Stoptech/AST/6MT/3.91 LSD
    BMW 325isA (gone but not forgotten)
    ACS Type II front bumper-ACS Type II sport mirrors-ACS Type II roof spoiler-ACS Type I rear apron-ACS rear wing-ACS pedals/dead pedal-ACS wood gear knob-ACS wood trim-ACS badges-BBS RS II 18's-TMS chip-ECIS intake/cover-RMS exhaust-Dinan transmission chip-ERT crank pulley-ZKW/DDEII/Phillips 6000k Hids-Kenwood eXcelon head/CD changer-Alpine sound field processor-PPI Art amps-MBQ speakers-Infinity 10' sub-Alpine 8070 alarm-Chrome trunk lid-Chrome gauge rings-In Pro smoked corners-BMW OEM clear tails-M3 mouldings-M3 floor mats-M3 door sills-M3 Lux wood trim-M3 rear sway-X brace-Koni shocks-Bav Auto springs-JTD RSMs-Front/rear strut braces-E46 front grills-Kamei eyelids-Kamei cf door handles-tinted windows-German ECC plate
  4. #54
    Manchester, N.H.
    96 332IS 6466 turbo
    The size difference in the wheels does not always apply.
    Ie running a 245/45/17 = 25.7" tall tire. Switch that to a 245/40/18 and your still running a 25.7" tall tire. So, all will be equal.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  5. #55
    Mar 2001
    FL
    E36, E46
    Quote Originally Posted by Butters Stoch View Post
    Well stock is 245/40-17 and that is 24.7, so.
    M3 coupe
  6. #56
    Manchester, N.H.
    96 332IS 6466 turbo
    And that was an example. Not any correct size.
    So. You can't say 17 is X.xx and 18 is X xx. Very few run a stock size. Some stretch onto 18's and they are shorter than the 17".
    a 16" size would be 225/50/16 is 24.9" wouldn't change any gear ratio.
    1996 332IS
    Built 3.2
  7. #57
    Mar 2001
    FL
    E36, E46
    Clearly you missed the part where I said "Very very rough math"
    Ok it's time for bed now, Butters.
    M3 coupe
  8. #58
    Jan 2005
    Wilkesboro, NC
    95 M3, 86 325
    Bumping this for a pertinent question.
    Does anyone know the exact length that a 5-speed driveshaft has to be shortened to facilitate the 6-speed swap?
    I was initially looking at picking up a used auto driveshaft, but I've got a six bolt input at the differential and recently replaced my driveshaft (last year).
    After contacting a shop that willing to modify the length, it'll be about the same price as getting a used auto shaft. I feel its better in the long run since I'll have something that I know works and was recently re-manufactured.
  9. #59
    Mar 2001
    FL
    E36, E46
    Quote Originally Posted by Reprisal View Post
    Want to say it's 3.5" but I can't remember or find my notes..
    Top, shortened for 6spd
    Bottom, stock 5spd.
    M3 coupe
  10. #60
    Jan 2005
    Wilkesboro, NC
    95 M3, 86 325
    Bottom, stock 5spd.
    Driveshaft shop I called seems to have done this before. Over the phone said that he thought it was 88mm on the nose (3.5" translates to 88.9), but I wanted some verification.
  11. #61
    Mar 2001
    FL
    E36, E46
    Seems right then. Sorry it's been awhile
    Another way to verify is get the measurements from an automatic M3 driveshaft, which works, but is ~1/2" too short of ideal IIRC. (Probably around 3")
    M3 coupe
  12. #62
    Durham, NC
    2x 97 M3/4, 05 530i
    US spec 5 speed CV style driveshaft is 1469mm long
    Euro 6 speed driveshaft is 1367mm long. So it needs to be 102mm shorter, or 4.016 inches. And that all has to be in the front section. If you are using a 4 bolt U joint style driveshaft, the flange length on the diff is different. Those are 1492mm long, but the extra 23mm is either the different in flange height from the diff or is taken up with the slide joint. I'm not sure.
    So I'm not a driveshaft expert, and those are just the numbers that I've found online. And the euro 6 speed driveshaft I have is in my car at the moment, so I'm not going to be able to measure for you. Sorry. The best bet is to just take your car to the DS shop and have them measure it to be sure.
  13. #63
    Jan 2006
    Oakhurst, CA
    Quote Originally Posted by kevinwilly View Post
    Correct. 6-bolt drive shafts use the same rear section Euro and US. The measured difference is all off the front section.
  14. #64
    Nov 2002
    Westchester, NY
    i hated the way my e46 m3 shifted (gearbox and clutch).
    does the zionsville 6 speed feel like the oem e36 m3 tranny?
  15. #65
    Mar 2008
    West Covina, CA
    97 M3/4/5, 98 M3/2/5
    Quote Originally Posted by RickyN F355 View Post
    It will be similar as it is the 6 speed ZF off the E46 330 ZHP.
  16. #66
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Some say the ZF GS6-37 shifts better than the Getrag 420G.
  17. #67
    Nov 2002
    Westchester, NY
    Which is which? Is the getrag the e46 m3 tranny?
    Sent from my BBB100-3 using Tapatalk
  18. #68
    Nov 2002
    Westchester, NY
    Quote Originally Posted by tofunin View Post
    Ok so it won't be like the e46 m3 which is the getrag, correct? The 330i is more like the e36 m3?
  19. #69
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    By all accounts that I've heard from people that have done both, the ZF is much less notchy and easier to use.
    I've got the 420G and a Rogue shifter, it isn't bad, but it's not as nice as the stock 310..
    If I were t do it again, I'd go with the ZF...
  20. #70
    Nov 2002
    Westchester, NY
    called zionsville- nice guys. $3500 for their ZF with potential $200 core for trade in
  21. #71
    Having daily driven a car with a 420G and now daily driving a car with the ZF 6 speed, the ZF gets my vote any day of the week...
    Smoother, less notchy, but not at all "vague" - you know where all the gears are and its like the gearbox actually wants you to shift into them. The 420G is almost so notchy that it's like "are you sure neutral isn't ok?" any time you try to put it into a gear.
    PRICE CUT on ALL FABRICS
  22. #72
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Quote Originally Posted by BimmerBreaker View Post
    ...Smoother, less notchy, but not at all "vague" - you know where all the gears are and its like the gearbox actually wants you to shift into them. The 420G is almost so notchy that it's like "are you sure neutral isn't ok?" any time you try to put it into a gear.
    Sounds like a shifter issue or the particular trans in the car you drove. I have the euro six speed (Getrag) and gear selection is a precise. Maybe it's the Auto Solutions shifter I'm using. The only negative of the Getrag is, when cold I get the 'second gear crunch'. Once warm, that disappears.
    88M3 AW 43k miles Project FS
  23. #73
    I've driven quite a few 420G's, they were all like that. Its just that it requires more force to get it into gear than the ZF. Have you driven a ZF 6 speed? If you haven't, try to get behind the wheel of one, its silky smooth.
    I don't miss the second gear crunch... my ZF syncros are worn, so I get some 2nd gear grindtime funtime in my ZF too. Best of both worlds
  24. #74
    Nov 2002
    Westchester, NY
    yeh and if i remember correctly using the sport mode the e46 m3 made shifting even worse
  25. #75
    Jan 2002
    Central Pacific
    The Getrag in my 99 was not beat and had less than 60K on it... or I just got lucky.
  1. S54 swap into E36 M3 sedan.
    By 309m3 in forum Engine Conversions
    Last Post: 06-12-2019, 06:32 PM
  2. e46 m3 diff swap into e36 m3?
    By tynashracing in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 02-12-2014, 09:29 AM
  3. Driveshaft for E46 M3 6-speed swap into E36
    By chrisshara in forum 1991 - 1999 (E36)
    Last Post: 01-02-2014, 03:37 PM
  4. e30 medium case differenial swap (into e36 m3)
    By Tristo in forum 1992 - 1999 M3 (E36)
    Last Post: 11-15-2011, 12:14 AM
  5. e36 m3 zf 5 speed manual swap
    By cove30m3 in forum Drivetrain & Transmission Parts
    Last Post: 01-10-2011, 12:01 PM
