Results 1 to 6 of 6
Thread: FS: Steel toothed wheel + enforcement bush for electric rear sunshade
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Special production: Pics: http://de.tinypic.com/usermedia.php?...c#.VOqDO2ccSUk http://de.tinypic.com/usermedia.php?...c#.VOqDjGccSUk
    Details about installation etc here: http://www.bimmerforums.com/forum/sh...-made-of-steel
    Made to replace the weak original "plastic" toothed wheel which usually loses the teeth over the years and then the rear sunblind starts to rattle and is often inoperatable. That is the large one of the 2 inside the gear. Used in all E32, E34, E31 and even E38 till 1996 for sure, even some till 1998, also some Benz and Audi 5000 models.
    Note: I can only deliver the toothed wheel in version with HEX bolt, not the torx version, which was introduced from 1996 on in E38 and others (no definitive clear cut of change known as even in some 1998 models the hex version was used, so please check your rear sunshade motor), see here the 2 different versions http://de.tinypic.com/view.php?pic=1...7#.VOqClmccSUk
    Shipped by SAL from Japan US$65.00 (usually takes about 2-3 weeks for example to the U.S., non-trackable, non-insured). Alternatively shipped by registered air parcel, plus $10.00. Optional enforcement bush $ 8/piece.
    Please contact me by PM with complete shipping address and requested shipping method and I will let you know my Paypal details.
    Jan 2005
    Japan
    1 toothed wheel shipped to Manfed in Freiamt, Germany for his Audi V8 built year 1992.
    Same gear/motor as installed in our E32/E34/E31 is installed in some Mercedes Benz models of similar built years like W 124 and also Audi cars of similar production years.
    Got info from an Audi owner: This toothed wheel made of solid steel also fits for Audi gear p/n 4A0959733 to replace the weak original toothed wheel. Fits on the following cars (European type mentioned, please check the type description in your country)
    Audi 100/S4 (4A, C4) (1991 bis/till 1994)
    Audi A6/S6/S6plus (4A, C4) (1994 bis/till 1997)
    Audi V8 (4C, D11) (1989 bis/till 1994)
    Audi A8/S8 (4D, D2) (1994 bis/till 1999)
    Jan 2005
    Japan
    @ matts e39: 1 x steel toothed wheel for your E34 shipped to Donvale VIC, AUS
    Jan 2005
    Japan
    @Kurt: toothed wheel and enforcement bush for Mercedes Benz W 124 shipped to Grossgoettfritz, Austria
    Jan 2005
    Japan
    @Singing6: 1 toothed wheel + 1 enforcement bush for E34 shipped to Vienna, VA
    Jan 2005
    Japan
    @Ariel: 1 electric sunshade toothed wheel + one enforcement bush for your E34 shipped to Quezon City, Metro Manila, Phils
  1. Replies: 13
    Last Post: 05-25-2020, 10:17 PM
  2. FS: USED Solid Brass Caliper Bushings for Two Calipers.
    By Vince S. in forum Race Cars & Track Parts
    Last Post: 11-13-2007, 11:56 PM
  3. FS Style 124 Wheels and Tires for Sale in NJ
    By z0lt3c in forum Wheels and Tires
    Last Post: 11-02-2007, 09:24 PM
  4. FS: Meyle front control arm bushings for E36 M3
    By turbo mike in forum Suspensions, Springs & Shocks
    Last Post: 10-16-2007, 08:22 AM
  5. FS: 16" Enkei wheels with Yokohamas for e30
    By Hammdy in forum Wheels and Tires
    Last Post: 11-08-2004, 01:26 PM
