Hi everyone, I really need some help here with my convertible to as this is not a "usual" problem. This past weekend, I heard a "pop" when putting the top down and later in the evening when I went to close it, it would not shut all the way. It was 2-3" short of reaching the latch holes on the top of the windshield.
Like an idiot, I had my friend push the top down while I held the close button so the the top would latch into place. Afterwards, I noticed the passenger side was bowed and out of alignment. Now, I cannot get the top to retract and don't know how to get it repaired as most of the independent shops are stumped as I am.
Does anyone here here have any advice as to how I can get this repaired without consulting the dealer whom I'm sure won't be able to help as they will probably quote to replace the entire assembly.
Here are pictures to show what my situation is.
Pictures:
I doubt you did any damage as I had the same issue but under different circumstances. My guess is that the pop you heard is a gear or cable.
