Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 82
Thread: '00 M Roadster log
  1. #26
    Feb 2004
    san diego
    ...it depands
    SS clutch lines... Finally replacing brittle oem lines while doing the clutch line flush...
    Not shown here, but I ended up replacing the clutch slave altogether as its nozzle was slowly leaking and letting air in...
    And oh boy, did I think I was having a heartache when the above happened... . Apparently many inexperienced or even experienced but careless folks (i.e., for me, inexperienced and careless particularly) supposedly go through it.
    2000 Z3 M Titanium Silver / Imola Red+Black Nappa
    2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
    Since 1987 12 euros / 2 kdms / 2 jdms
    - Zach
  2. #27
    Feb 2004
    san diego
    ...it depands
    Pressure bled them yesterday after the replacing the brake lines and clutch slave.
    - Zach
  3. #28
    Rep Korea
    96 m roady, 99mcoupe
    Those chrome mirror surrounds, where can i get one. Looks great. I shud fly u over here so u cud give advise on what to do on my z3. .
    나의 SM-G950N 의 Tapatalk에서 보냄
  4. #29
    Feb 2004
    san diego
    ...it depands
    Randy's subframe reinforcement kit. - Marked it off my to do list!
    I haven't post much update lately as I had some curve balls thrown at my life both family and work. But I'm happy to say that it is past now with better outlook and some spare time to get back into my z3!
    And here is the most recent one... Pardon my craftsmanship though.
    - Zach
  5. #30
    Feb 2004
    san diego
    ...it depands
    Resonators deleted...
    UPDATE
    Resonators are now put back on with dual vacuum butterfly valves. See them here >
    As background, I've always liked the stock muffler sounds (even the 2000+/- rpm drone). But I felt it was lacking with 2.5" tips and the a little bit in exhaust sound in higher rpm. And I wasn't able to settle for a particular exhaust system.
    With the 3" tips (by Eurosport Design) previously done, I finally got to try deleting the resonators, and it seemed to work for my need. I understand some s54 folks prefer adding resonators because of the rasp sound. But as for me, it was the cup of tea which I've been seeking. It makes about the same sounds as stock until it reaches 3000 rpm, then it adds the a bit of rasp sounds.
    I added some video clips in case anyone might find it helpful because I'd also had hard time finding good sources when I was researching. But also note that it sounds much louder than it really is in the videos (i.e., It really has almost about the same sounds except it has that rasp above 3000rpm).
    Clip from Side:
    [Rev 1] Gradual 0~6500 rpm
    [Rev 2] 0~3000 + 3000~4500
    [Rev 3] 0~3000 + 3000~4500 + 4500~6500
    [Rev 4] 0~3000 + 3000~4500 + 4500~6500 + 4500~6500
    [Rev 5] 0~3000
    [Rev n] …
    Clip from Rear:
    [Rev 2] 0~3000
    [Rev n] …
    - Zach
  6. #31
    Feb 2004
    san diego
    ...it depands
    My cluster gauges have been increasingly developing dark spots (not shown here though).
    So I recently removed and fixed them with sanding the clear backplate method (i.e., making the surface frosty).
    During:
    After:
    Referenced
    - Zach
  7. #32
    Oct 2017
    Los Angeles, CA
    2000 S54 - Mcoupe
    What did you do?
    Quote Originally Posted by nevan View Post
    Attachment 632272
  8. #33
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by z3m.casey View Post
    What did you do?
    Sorry about the confusion. That was the only photo i had at time of posting. I replaced the photo so I hope the new one looks less scrambling.
    - Zach
  9. #34
    Nov 2008
    Kelowna
    '99 M Roadster '08 135i
    nevan, don't be so hard on yourself it's a pretty darn good job!
  10. #35
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by Z3 M Roadster View Post
    Thanks for the kind words!
    I feel lucky to be here with many experts (i.e., too many to name individually), which keeps me humble too!
    - Zach
  11. #36
    Feb 2004
    san diego
    ...it depands
    Chrome Roll Bar
    A couple of months ago, I stumbled upon a listing for a set of chrome roll bars from a Z3 forum in South Korea.
    Upon talking with the seller, both seller and I gained the confidence so we decided to make a deal. Payment and shipping was a bit of challenge, but it went through.
    7 weeks and across the Pacific, they finally arrived. And I couldn't be happier. ;-)
    Photo from the listing:
    Photos after the install:
    - Zach
  12. #37
    Oct 2013
    Tennessee
    2000 M roadster
    WOW. you are incredibly dedicated and very meticulous. strong work!
  13. #38
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by crashgordan View Post
    Thank you!!
    - Zach
  14. #39
    Feb 2004
    san diego
    ...it depands
    Sub-frame bushings (ended up going with 80a bushings) + diff bolts
    Toe/camber adjustable eccentric busings
    Half shaft service kit
    Rear wheel bearings
    - Zach
  15. #40
    Feb 2004
    san diego
    ...it depands
    An unexpected toll..
    Replaced it sometime last year.
    ...because this happened...
    - Zach
  16. #41
    Feb 2004
    san diego
    ...it depands
    Switching to a 2.62 pulley
    3.60 (7psi) --> 3.33 (10psi) --> 2.62 (15psi)
    Then I quickly learn that the VFE's DV was letting go at about 9-10 psi. With an adjustable BOV (set at about 15 psi), it stopped releasing the boost.
    The_Splitter_a_Recirculation_and_Blow_Off_Valve_95804.jpeg IMG_20190120_154311.jpg
    However, IAT issue became more prominent (due to considerably higher iat...).
    - Zach
  17. #42
    Feb 2004
    san diego
    ...it depands
    Intake Manifold Water Injection
    This is the route which I've decided to experiment...
    IAT at fuel cut-off:
    - Currently at about 175F in 65F weather.
    - Targeting for 50~70F lowered temperature.
    Injection pump bracket - mockup
    Finished bracket
    - Zach
  18. #43
    Feb 2004
    san diego
    ...it depands
    Injection pump installed in SAP location
    Next step: Tubing, test-wiring, and mounting the controller, probably inside of DME box (later, it was relocated to the cabin behind of where a head unit would go), etc...
    - Zach
  19. #44
    Aug 2003
    Dallas, TX
    Z3M, X5M
    Looking forward to see how much the temps drop with the water injection.
    -Phil
  20. #45
    Jul 2004
    Houston, TX
    36 Cylinders
    The car is adapting down a lot of ignition advance, very likely due to the extra boost and intake temps. May have to send you a bit lower ignition advance.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  21. #46
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by Z-Thrizzle View Post
    You and me both, Phil!!
    Thanks Abel!
    - Zach
  22. #47
    Feb 2004
    san diego
    ...it depands
    Tapped to the windshield fluid tank. Thanks for the inspiration and the trade, Phil!
    Connecting the tube
    Loose wires (relocated to the cabin later on) need to be organized and tucked away after test drive...
    - Zach
  23. #48
    Feb 2004
    san diego
    ...it depands
    [Experimental trials and errors]
    Cliff notes from learned lesson:
    100% is very effective in reducing iat. But it also dilutes fuel, which causes more knocks... And I settled with the 50/50 mix in the end.
    [NOTE] I used the Torque with a cheap ebay dongle... So please ignore all other data except the IAT.
    Idle IAT
    Near 5-6k rpm IAT in similar outside temp (which is about 45F drop from the original 175F est.). After some adjusting MIN/MAX psi and swapping nozzles, I was able to reach 114F with distilled water, no methanol.
    In short, it did help improving the heat-soak under the load. And I was impressed when it did. Originally I thought it would engage at preset psi then simply normalize and spray linearly until it reached max psi... Interestingly (although i don't fully understand how the injection algorithm works), it seems to try conserving the w/m fluid during normal operation...which makes sense, I suppose. It does operate very smoothly though.
    The downside is that it works as a just-in-time system. It isn't an intercooler replacement. So it idles hot and runs hot like normal heat-soaked engine. But under certain boost, it lowers IAT (which is more than adequate for now). FWIW, I thought it was an interesting technology. I also thought this type of system would work even better if it had intercooler in conjunction... But for now, it is what it is. And I am happy with it.
    - Zach
  24. #49
    Feb 2004
    san diego
    ...it depands
    Here is the latest progress/update
    - New AFR kit to replace the old one.
    - Disabled pre-c** o2s b*** 2 (wb o2s in its place)
    - Disabled EWS, Sa*, EV**** test, em*****n readines
    - Plan to test incremental -5% fuel map for 50/50 WM ratio. - 100% of water to reduce the IAT resulted in too much knock...
    - Added a manual on-off switch to WMI
    I had some accuracy and latency issues with the 30psi gauge. So I replaced it with a 15psi gauge with better quality.
    - Zach
  25. #50
    Feb 2004
    san diego
    ...it depands
    DISCLAIMER
    For informational use only
    A special shout-out to Abel!
    Set-up
    • Vortech v3 si (VFE didn't offer any iat cooler option )
    - 2.62" pulley (15psi at 7k).
    - Converted to a spring tensioner (credit: z-thrizzle)
    • A small size motor oil cooler (200f average)
    • Adjustable Bov (15psi --> fuel pump & e85 friendly 12psi)
    • Home made open-to-air ccv with a manual oil return
    • AEM Progressive WMI
    - 50:50 ratio with 500cc/min nozzle
    - 1psi/12psi (min/max)
    - Manual overide switch
    • LC-2 wbo2s (replacing an old AEM)
    Tools used
    • RomRaider
    • Siemens flasher
    • Testo (credit: pheno)
    • INPA
    • Torque
    Tunes
    DME-1: 91 octane w/WMI
    • Base: 3.33" optimized tune (credit: 328Power04)
    • Global map: - fig.1
    - +3~5% high rpm/load
    - -1~2% low-mid rpm/load
    • WOT enrichment: +2~3% top cells - fig.2
    • Ignition:
    - -2~5 deg high rpm/load - fig.3
    - set to about 15 deg mid-high rpm/low load, blended
    • WOT response: 50% - fig.4
    • 7130 limiter
    • Etc... - fig.5
    DME-2: E85 w/WMI - experimental
    • Started from the Tune-1
    • +30% to global map and other fuel-related (WIP). - fig.6
    • Better ignition timing (Reverted to the base tune) - fig.7
    DME-3: 91 octane w/o WMI
    • Failsafe tune with a very conservative global map and ignition
    Figures
    -fig.1
    -fig.2
    -fig.3
    -fig.4
    -fig.5
    - Zach
  1. 98-00 m roadster problems?
    By Mik3 Agby in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-08-2003, 01:37 PM
  2. My mom's '00 M Roadster
    By Longhorn in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-12-2003, 07:21 AM
  3. Trade '01 M5 for '00 M-Roadster + cash
    By NormK in forum BMW Cars For Sale / Wanted
    Last Post: 12-30-2002, 08:58 PM
  4. Compression ratio of the S52 motor in the 98-00 M Roadster?
    By SilverStreak in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-09-2002, 02:04 PM
  5. 00 M roadster VS 00 SS Camaro
    By BlackMroadster in forum Kill Stories
    Last Post: 05-01-2002, 11:15 AM
