Page 1 of 4 1234 LastLast
Results 1 to 25 of 82
Thread: '00 M Roadster log
    Feb 2004
    san diego
    ...it depands
    '00 M Roadster log
    M Registry Profile:
    http://www.bmwmregistry.com/detail.php?id=11401
    E36/7 M Roadster Background:
    http://www.bmwmregistry.com/model_faq.php?id=16
    MRBG (I found mine here. Thanks, Jon!)
    http://www.mroadsterbuyersguide.com/
    Hey all,
    I've been lurking around since 2004 and it's only been recent that I've gotten active ever since I've gotten my recent Z3M Roadster.
    And I've been receiving wealth of information and helps from fellas; too many to mention, but you know who you are. Thanks so much once again!!).
    Anyhow, I've been also inspired to start my own log to recap everything I've done and will be done.
    Although I don't anticipate this adding any value to my Z3M, it's just my small ways of showing my enthusiasm and affection for the z3m project.
    So I will return to add more info... Peace out! ;-)
    Zach
    2000 Z3 M Titanium Silver / Imola Red+Black Nappa
    2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
    Since 1987 12 euros / 2 kdms / 2 jdms
    - Zach
    Feb 2004
    san diego
    ...it depands
    Maintenance Service & Upgrades
    Date / Miles / Type / Details
    5/1/2013 - 84000
    UUC Clutch line
    Audiovox Mediabridge BT Adapter
    EAS (united auto security) Alarm + Siren
    Seat Incliner Pins
    Glove Compartment fix
    Car cover
    Hardtop hanger
    Rear vinyl window protection cover OEM
    Owner's Manual OEM
    HID
    Canadian DRL module OEM
    Tint Lifetime
    Leather Z arm rest
    ZHP shift knob
    9/1/2013 - 87000
    Front struts Bilstein HD
    Front strut Mounts KYB
    Front strut Plates OEM
    Rear struts Bilstein HD
    Rear strut Mount OE Meyle HD
    Rear strut plates UUC
    Font Brake Rotors Zimmerman
    Front Brake Pads Akabano
    Rear Brake Rotors Zimmerman
    Rear Brake Pads Akabano
    Wheel Aligntments ExpressTires
    12/1/2013 - 92,500
    Control arm bushings OEM
    Oil / Oil Filter 5W30 Synthetics / 7 qts
    Spark Plugs Platium+
    Fuel filter OEM
    New radiator OEM
    Power steering fluid OE
    Brake fluid OEM
    Guibo OEM
    Thermo Stat OEM
    Serpentine belt OE
    Clutch OEM/OE
    ------------------- 2014 -------------------
    6/1/2014
    New soft top NA OE
    Dent removal + Door guards N/A
    HK Rocker panel speakers OEM
    Aux Fan OEM
    RR Trail arm + R Sub frame OEM
    9/10/2014 - 95,000
    Differential / Transmission fluids OE
    ------------------- 2015 -------------------
    1/11/2015 - 96,275
    Bi-xenon projector retrofit OEM
    Control arms OEM (Replaced bushings)
    tie rods (inner+outer) OE
    sway links OE
    front bearing w hubs OE
    4/4/2015 - 97,000
    New tires (wheel balance) Replaced w/ Michelin PS
    Radiator Upper hose OE
    4/11/2015 - 97200
    Oil+Filter 5W30 Synthetics / 7 qts
    KONI SA Struts + Shocks Replacing Bilstein HD
    Analog clock Repair
    Wheel Alignments Firestone (Lifetime)
    6/1/2015 - 97777
    VFE SC Installed at 98k (400 break-in required)
    3” Outlet Exhaust Tips AM
    7/2/2015 - 98000
    Fan Blower Motor Resistor OE
    Alternator
    M50 Manifold (w adaptor & rail cover
    7/18/2015
    Oxygen Sensors (Up/Down streams) OEM Bosch
    7/25/2015 - 98450
    Fuel Pressure Regulator OEM Genuine
    Fuel Filter OE
    Fuel Pump+Gasket OEM Genuine
    8/29/2015 - 98500
    TPS OEM
    PCV Valve/VentHose/OilDrainHose OEM Febi / AM Uro/ AM Uro
    Cruise control switch OEM FEBI
    M50 Manifold removed Stock S52 Manifold re-installed
    MAF (Genuine OEM Upgrade) BMW Genuine OEM
    9/30/2015 - 99000
    ECT Sensors 1 & 2 OEM FAE Bapmic
    Engine Oil Temp Sensor OEM FAE
    IAT Sensor OEM FACET
    Crank Position Sensor OEM Siemens/ VDO
    Cam Position Sensor OEM Siemens/ VDO
    SAP Valve & Relay OEM Siemens/ VDO
    Spark Plugs NGK 6988 BKR7EIX-11 IX
    Vacuum hose AM
    ------------------- 2016 -------------------
    1/9/2016 - 100000
    Vortec SC Oil Vortec Oil
    "Vanos Rebuild (Seals, Gear Ring)/
    New VC Gasket and Valve Cover OEM Reinz and BMW Genuine OEM
    ECU Clone BMW Genuine OEM
    Rear Brake Light Seal Rebuild BMW Genuine OEM
    3/9/2016 - 100750
    Power steering rack & lines (rebuild) BMW Genuine OEM
    Power steering reservoir Meyle
    Power steering fluid Motul ATF
    5/1/2016 - 101500
    BMW M badges (S54, Rear/Sides) BMW Genuine OEM
    Engine / Tranny Mounts OEM Valco
    Seafoam N/A
    EvapBreather Valve OEM Meyle
    Oil Filter Housing Gasket OEM Reinz
    Idler Pulley OEM Meyle
    Idler Tensioner (Spring) OEM
    Vortech Pulley 3.33 6Rib/ 70mmDiameter/ 25mmWidth (VF: 6Rib/ 75mm Diameter/ 25mmWidth
    Oil Catch Can Aftermarket
    7/2/2016 - 102000
    Oil / Oil Filter 5W30 Synthetics / 7 qts / OEM Meyle
    "Oil Cooler / Oil Line / Thermostat / Oil Filter Cap" Aftermarket
    Oil Pan Gasket BMW Genuine OEM
    Main Seal w Gasket BMW Genuine OEM
    Detent Kit (5th/Reverse) BMW Genuine OEM
    Shift Linkage Seal BMW Genuine OEM
    Transmission fluid Motul ATF (1.3 qts)
    AEM Wideband O2 with Digital Gauge
    Ignition Coil (1) AM
    10/29/2016 - 104000
    Parking brake shoes
    Electromagnetic parking sensor
    Anenna Grommet
    Euro taillight fog lights (both driver/passenger sides)
    SRS sensor (passenger side) oem
    ------------------- 2017 -------------------
    1/4/2017 - 105000
    Strutbrace (Cosmo)
    Transmission mounts
    3/10/2017 - 105400
    Driverside seatbelt guide
    Driverside seat bushings
    M chrome trim leather shift knob
    Oil+Filter
    SC Oil
    6/10/2017 - 106000
    Vanos solenoid+Seals
    Dipstick + ORing
    Vented catch can (Modified PCV)
    Adjustable BOV (Ongoing)
    ICV hose
    Ignition Coils (5) OEM
    8/18/2017 - 107000
    Brake / clutch line flush
    Stanless steel brake lines
    -------------- Posted below --------------
    - Zach
    Feb 2004
    san diego
    ...it depands
    Vanos seal and rattle service
    Rear main seal and shift pins replacement
    Oil pan replaced with the RMS and shift pins.
    3.60 --> 3.33 switch
    WHP: 292 (6900rpm) / WTQ: 255 (4600rpm) - 91 octane
    Oil cooler - This photo is not mine, but exact same set up.
    - Zach
    Feb 2004
    san diego
    ...it depands
    - Zach
    Feb 2004
    san diego
    ...it depands
    Valve cover crack...
    ...a temporary fix with jb weld until a new "used" one arrives.
    ZHP knob
    I recently backed into a column at office garage. So i decide to add this while repairing the bumper cover. - I've had the kit for a while but I procrastinated. I should've done it sooner; perhaps, I could 've avoided the incident in the first place...
    - Zach
    Feb 2004
    san diego
    ...it depands
    eBay oil catch can
    AEM Uego AFR gauge for logging and start dme tunning.
    3.33 pulley
    3" Bi-xenon retrofit
    - Zach
    Feb 2004
    san diego
    ...it depands
    Euro-spec Blindspot and Heated Mirror - Driver side
    Euro-spec Blindspot and Heated Mirror - Passenger side
    Dice (Audiovox) Mediabridge
    USB port
    Mic located under the rearview mirror
    - Zach
    Feb 2004
    san diego
    ...it depands
    VF SC Kit (V3 Si) w/ M50 manifold - Before
    VF SC Kit (V3 Si) w/ M50 manifold - After
    Oil Cooler w/ S52 Manifold
    Euro Tail Fog Lights
    - Zach
    Aug 2013
    Bay Area, CA
    '99 Z3MC, '07 Z4 3.0si
    Really nice!
    The VF systems are CARB legal? I thought only DINAN made CA legal ones.
    Feb 2014
    Galt,CA
    2002 M Coupe
    I don't believe that VF makes any CARB-legal systems.
    Marty
    Feb 2004
    san diego
    ...it depands
    Thanks for the compliment.
    And regarding the carb question, I hope you've caught my subtle suggestion above.
    - Zach
    Feb 2004
    san diego
    ...it depands
    s54 overhaul...
    These aren't for my s52, but I will be doing an overhaul for my buddy's e85 z4m.
    It will include valve adjustment, vanos seals/sprocket hub bolts, and a few other goodies while there (parts in photos).
    I'm feeling excited about the project since I have a tendency to put s54 on a pedestal.
    - Zach
    Feb 2004
    san diego
    ...it depands
    It isn't exactly an extraordinary eBay find, but I scored a used strut brace (later I found out that its was sold by a forum member "rasmuw" here) to help the chassis.
    About 1/8~16" of mounts were shaved for better clearance... I just need to finish off by painting it in matte black. =)
    [Added]
    Just finished painting them last night.
    Mar 2016
    Blairstown, NJ, USA
    1998 M Roadster
    I'm glad I could help your project out! I'd wondered if the Cosmo brace had been bought by a Bimmerforum member. From my Arctic Silver '98 with hardtop to your '00 Titanium Silver with hardtop. I've enjoyed following your progress. Please post a picture when the brace gets painted black.
    Wayne
    1998 M Roadster
    1994 Honda ST1100--sold
    2017 Yamaha FJR1300ES
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by rasmuw View Post
    Will do, sir!
    Thanks very much again, and happy new year!!
    [Edit]
    Painted photo is added in the post.
    Feb 2004
    san diego
    ...it depands
    Driver seat belt guide replacement.
    I like working on cars, but there are some that I actually enjoy less (i.e., working on upholstery as an example) which is probably why I procrastinated until now...
    I am happy to report that I finally marked it off from my todo list.
    - Zach
    Feb 2004
    san diego
    ...it depands
    M Chrome Trim Leather Shift Knob
    - I am usually not a fan of chrome finishing, but this one (along with a few items) is an exception... ;-)
    (Retrofitted the lighting components)
    - Zach
    Feb 2004
    san diego
    ...it depands
    ... and here are the rest of chrome item that I mentioend. ;-)
    Spaz Stix, Mirror Chrome:
    Final:
    IMG_20170401_204216_343.jpg IMG_20170401_204216_341.jpg Testing with a spare RVM:IMG_20170402_220207_502.jpg
    These are replaced with chrome finished ones (oem).
    Last one is somewhat unrelated but another interest of mine which I recently completed. It's a Tamiya Z3 (1/24) with some mods.
    - Zach
    Feb 2004
    san diego
    ...it depands
    3" tips
    I like the stock exhaust set up. But I also thought the 2.5" oem tips were a bit outdated. So I've decided to update them.
    Ordered a set of four from Eurosport Design to fit my Z3M...
    IMG_20170421_173256_496.jpg IMG_20170421_173256_495.jpg IMG_20170421_173840_510.jpg
    Installed.
    - Zach
    Jul 2004
    Houston, TX
    36 Cylinders
    Looks awesome. Didn't realize you had a red interior. That is a very nice combo.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Feb 2004
    san diego
    ...it depands
    You are so kind, Abel! And thanks so much for your help and expertise!
    - Zach
    birmingham,al
    2001 3.0 Z-3 RD'STER
    Please forgive me for hijacking this thread but you both appear to be very knowledgeable with the Z3 Roadsters. Please allow me to ask a question: Are you familiar with wiring the 3 M gauges? I am doing a console swap (M console into a non-M) and have been told the existing M-pigtail harness can be used to connect the gauges. A Russian friend had his mechanic do it. (see photos). However, I have no knowledge of where they are connected beyond the female connector. Any thoughts? Again, my apology for being so rude, but I am desperate. Car has been sitting idle for too long.
    Feb 2004
    san diego
    ...it depands
    Quote Originally Posted by MORRIE View Post
    Hi Morrie, there is no need for an apology first of all. I think we are all here for the same reason: Enthusiasm toward our Z cars. In fact, I don't know if you recall. but you also helped me with hardtop lift holsters diy while back. Although I haven't done it yet, thanks to your very complete instructions, I am able to make one for myself when I am ready to do so thanks to you. And I really appreciated it.
    Also please understand that my knowledge is very limited to what I have learned from many trials of errors. As for the center console swap unfortunately, I have yet to do it yet. But something tells me that these two gauges (battery and oil temp) wiring probably may not exist. And they may need to be tapped directly from the source.
    Another route is to install other types of VDO gauges from I've seen other folks doing the swap... But I have a feeling that you may already know that (or have been told by others already).
    Or perhaps as your friend mentioned, source harness may already exist. But I'm sorry to say that I'm very limited with what I am able to offer in that regards...
    - Zach
    birmingham,al
    Hey, Zach....good to see you're still a Z3 enthusiast. I remember sending you detailed info. on how to construct the hardtop lift. I saved that for future reference...took a while to write up.
    How is the V-tech Supercharger working out for you? It's something I have thought about doing, but if I bolted it on, there would be other things needed done...radiator, trunk reinforcement, belts, etc. So I am holding off for now. However, your feedback might push me over the edge.
    Wayne is supposed to send me some photos of the wiring in his 98-M that might help me with my gauge wiring. I am still waiting for that information....hope it helps me complete the Console swap.
    Feb 2004
    san diego
    ...it depands
    Adjustable BOV and catch can
    Adjustable BOV/DV
    Trying out another catch can
  1. 98-00 m roadster problems?
    By Mik3 Agby in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-08-2003, 01:37 PM
  2. My mom's '00 M Roadster
    By Longhorn in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-12-2003, 07:21 AM
  3. Trade '01 M5 for '00 M-Roadster + cash
    By NormK in forum BMW Cars For Sale / Wanted
    Last Post: 12-30-2002, 08:58 PM
  4. Compression ratio of the S52 motor in the 98-00 M Roadster?
    By SilverStreak in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-09-2002, 02:04 PM
  5. 00 M roadster VS 00 SS Camaro
    By BlackMroadster in forum Kill Stories
    Last Post: 05-01-2002, 11:15 AM
