Results 1 to 11 of 11
Thread: AGM Battery for E60
    Sep 2011
    Cupertino, CA, USA
    2010 BMW 535xi
    AGM Battery for E60
    Here is my research on AGM Battery Replacement. All the below are workable and have the exact specifications and could be all made in the same factory. The Home Depot one is the exact brand too. The Pep Boys & advanced Auto one looks really good price.
    Original BMW AGM Battery - Made by Exide
    850CCA, 160RC, 92Ah, 850A
    13.5 x 7.5 x 7 inches
    S: 61217639054
    AW: 61217639053
    165902-10 US
    https://www.pepboys.com/product/deta...0763_affiliate
    Part #: 49-850BAGM| SKU: 838838
    Discount: 25%
    Discount Code: ROADTRIP25
    Save 25% with code PEP25BATT
    $180 after 25% discount
    http://www.homedepot.com/p/Edge-L5-4...49DS/205342457
    Dimensions
    Product Depth (in.)* 6.88*
    Product Width (in.)*13.88*
    Product Height (in.)*7.5*
    $245 no discount
    http://www.autozone.com/batteries-st...?checkfit=true
    Battery Height: 190 mm - 7 1/2 in
    Battery Length:353 mm - 13 15/16 in
    Battery Width: 175 mm - 6 15/16 in
    $184 no discount
    http://shop.advanceautoparts.com/p/a...000#fragment-2
    Same as Carquest - Need to Open an account
    Discount: 30% / Up to $50.00. Discount Code: TRT30
    Cold Cranking Amps: 850. Cranking Amps: 1000. Reserve Capacity: 160
    Height: 7.5. Length: 13.94. Width: 6.938
    $186 then get a 30% discount
    https://www.walmart.com/ip/Platinum-...40647529#about
    Walmart Battery not yet available.
    Cold Crank Amp: 900CCA H8 AGM
    Product Dimensions (L x W x H): 14.31 x 6.88 x 7.50 Inches
    $140
    Hope this helps someone!!
    2010 535i xDrive AUTO
    PDC, NAV, HUD, HD & SAT Radio, Premium Audio
    Premium, Sport & Value Packages
    Black Sapphire Metallic
    Black Dakota Leather
    Sep 2008
    Atlanta GA
    530I
    Thanks, I think I am close to needing a new one so this could be very helpful
    Sent from my D6708 using Tapatalk
    Jan 2016
    Ca
    2001 525it
    You will have to register the battery after it is installed and if the original battery is a lead acid and you install an agm you might have to update the software for it
    Sep 2011
    Cupertino, CA, USA
    2010 BMW 535xi
    Quote Originally Posted by Maini View Post
    S: 61217639054
    AW: 61217639053
    165902-10 US
    Discount: 25%
    Dimensions
    $245 no discount
    $184 no discount
    $140
    Some additional options!! also added the Exide Battery Specification sheet for reference.
    https://www.batteriesplus.com/productdetails/sli49agm
    Capacity 20hr: 92AH
    Cranking Amps: 975
    Warranty: 48 Month Free Replacement
    Weight: 57.75 lbs
    Length: 13.9375 in Width: 6.875 in Height: 7.5 in
    $220. 10% Discount available
    http://www.sears.com/diehard-advance...7&blockType=G7
    • Item Weight (lbs.):58.5
    • Length (in.):14 Height (in.):7.5
    • Group Size: 49
    • $150.44. look for discounts
    Attached Files Attached Files
    May 2010
    dallas, tx
    2008 Nissan Titan CC
    I'm told the new battery, regardless of what kind or where it's replaced, MUST be (re) coded to the i-drive system for optimal performance.
    Something a Dealership or Indy must do using their diagnostic tools.
    Anyone replaced their battery at a BMW Dealership? I'm curious to how much it costs and what type of warranty, core charge, etc they have?
    DE, USA
    '15 435i,'10 535i,'08 X5
    Buy the $130 Walmart battery, Carly ap, suitable iPhone/Android adapter and register/code it your self. You'll spend less then the dealer will charge and you'll have a powerful code reader for future diagnostics.
    Mar 2008
    Monroe, CT
    2007 530xi 6 spd.manual
    Quote Originally Posted by militarydave View Post
    Whoever told you that is WRONG! If you replace the battery with a battery with the same specs, no coding is necessary. The trick is, generally an exact replacement is not available, so you go with something a little or even a lot different. The affordable Carly app and appliance is available to anybody to use to reregister the new battery to the new specs.
    http://www.mycarly.com/product/bmw-app/
    I've seen dealers charge up to $600 to replace a battery. And the warranty is no better than what AutoZone or Advanced Auto offer.
    2007 530xi, Black Metallic Sapphire, 6 speed manual, Sport package, Cold Weather Package, Premium Package, Premium Sound Package, Sirius Satellite Radio, MTech front bumper, Replica Style 166 wheels
    Jun 2018
    Iowa
    2010 BMW 535xi Wagon
    I just installed a new H8 EverStart Maxx battery from Walmart in my 2010 e61. I have CarlyBMW, so I thought this would be easy. However, I did not realize that I would also need a PhD in battery chemistry to complete this task! I cannot determine if my new battery is lead acid vs. AGM, let alone the AH rating. There's not much information on the battery label. Some scouring on the internet indicates the battery has a reserve capacity of 140 min and lead acid. I have seen various ways to "convert" from RC to AH, and they all yield different results. Anyone have any light to shed on this specific battery?
    Mar 2011
    OK
    e30, e61
    If possible, I'd return the lead-acid battery and exchange for the AGM one: https://www.walmart.com/ip/EverStart...up-h8/40647529
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    It has a pretty good warranty so I would not worry if you cannot off but want to return it. I have a Bosch agm in my 08 E61 535xi but don’t think agm is necessary.
    DE, USA
    Walmart battery (by Johnson Controls) is FLA....Flooded Lead Acid, not AGM.
    My '10 E60 (5/09 build) was delivered with a FLA battery that lasted 7 years & 3 months. I had no reason to believe the 50% more expensive AGM battery would give me 50% longer life, so I stayed with the FLA. Since I was replacing an H8 with another H8, I simply renewed the previous registration, w/o changing AH rating.
  1. AGM or Lead Acid battery for 7 series?
    By Sambal in forum 1995 - 2001 (E38)
    Last Post: 07-17-2013, 08:37 AM
  2. What's the best battery spec for E60 530i?
    By Alex0607 in forum 2004-2010 (E60,E61)
    Last Post: 01-15-2012, 11:19 AM
  3. What's the lightest AGM battery reasonable for a daily driver Z3?
    By Silberwald in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-14-2011, 02:24 AM
  4. Battery Charger for E60?
    By LHB1 in forum 2004-2010 (E60,E61)
    Last Post: 01-28-2011, 02:03 PM
  5. found a good source for AGM batteries
    By dkindig in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-17-2010, 09:01 AM
