Great progress! My rear shock plate is bent and will be replacing them soon with bilstein b4s...
Some updates:
UPS Man Goodness!
BC Coilovers - seemed like the best solution for adjustability
Time to get to work, started with the busted shock...
Rear upper arm off, shock bolt coming off, but the strut is frozen in.
Hit this thing with a sledge and chisel over 50 times, no budge. Time to get serious.
Somewhere between using heat for ~20min and banging countless times with the sledge and chisel
And it is finally off. I honestly think it took~500 hits with the 5lb sledge with heat pretty much melting everything. This ended up being the case for both sides.
New Hotness vs. Old & Busted
Doing the rear upper arms while I am at it (honestly, there is no way the old arm would still thread the bolt anyway)
Copious amounts of anti-seize installed (never doing that fight again for removal)
For anyone who does this, job is almost impossible without a racheting wrench to hold the bolts.
New coilover and rear upper arms installed!
Might as well replace the front lower arms while I am at it
Did you anti-seize the treads if your new coil overs? If not you will have junk in a couple of years. Just a FYI
I didn't use anti seize on mine two years ago and it's still golden, fully adjustable.
Just a suggestion, salt and aluminum aren’t friends
Nice job saving this car your doing Awesome work and it's nice to see !... subscribed
First time out on the road since mid august. Car drives great with the new coilovers! Also did an entire polish / paint correction.
Next is the bodyshop to remove some minor wheel well rust.
Great job so far! Keep it up!
-Chris
02 540iT LS2 || 13 550XI Msport || 94 530i || 04 330ci || 92 Galant VR4 || 94 Supra TT/6 810whp
The car looks great! What a hell of a job getting that old suspension outta there.
|| 1995 740i || M60B40 || DUDMD || ̶o̶r̶i̶e̶n̶t̶ ̶b̶l̶u̶e̶ Mercedes Brilliant Blue Metallic || Style 168 Wheels 1" Spacers ||
Thank you!
Yeah, I've been working on cars for a while - and this one was def. one of the most brutal suspension removals I have ever experienced! lol.
Thanks for the heads up on this one. I went back and put anti-seize on the threads and couplings.
why you dont get this for your E38
https://www.ebay.com/i/251318655937?chn=ps&dispItem=1
it will display your phone screen on it
El Cid 1999 ILDUDMD Tune/DINAN CAI/19 in Style 95 Rims/Bilstein's Shocks/Eibach Lowering Springs/OEM Folding Mirrors/Custom Cupholder/Custom Wood Sunshade/Sport Steering Wheel/Euro Center Console/Leather Shifter/Rearview Camera /Luke Custom 10 in Sub Box/Cross Drilled Rotors/Rear view Camera/BMW OEM Monitors/BMW E38 Picnic Tables/Vanity Headrests/OEM Roof Rack/Strut Bar/Dinan MAF and Dinan Throttle Body and Dinan tunning /BM53 Radio upgrade /Custom Innovadrive NXG39 modify and Alpine ILX-W650 touch screen radio.
Woohoo! Next batch of parts in - full 750il brake swap.
Note you need the caliper and mounting brackets. Mine came with both. (Fronts from Autozone, rears from Rock Auto. Ordered Online)
End of year update! Bodyshop took care of all of the rust spots, and I swapped over shadowline trim from a sport model. Also finished the 750il brake swap on all 4 corners.
I wanted to but ran out of time. They are painted with that standard gray paint that lots of rebuilt parts use. I may redo it later!
Thanks! I have the fronts set at full soft and the rears set at 4. It is fine for my taste but did increase road noise more than I’d like. I would have gone with full OEM sport suspension if it wasn’t so dang expensive!
Looks really nice.
Tasteful well sorted build. Your car looks immaculate. Gsx biker who sold me the 750 calipers rebuilt and painted mine. Including the spring retainers. I threw in a set of color coded stainless brake lines as well. I'm still breaking mine in so I can't really tell any particular driving difference. How do yours feel compared to the stock brakes?
Sent from my VS995 using Tapatalk
Lookin' good!!
Thanks - your setup looks awesome! My brakes needed a total refresh so I didnt mind spending a tad extra for the 750 setup consideing the amount of highway driving and hills / mountains that I deal with. I did the upgrade knowing that it probably wouldnt impact overall stopping distance / etc, but the pedal feel certainly feels much more linear now. I did SS lines and pentosin fluid along with it. Overall I am really happy with the result.
