Page 2 of 2 FirstFirst 12
Results 26 to 33 of 33
Thread: My M50B30 Build
  1. #26
    Vancouver, BC Ca
    1993 325is
    There is a fix for Chrome and Firefox users to re-enable Photobucket pics. Google is your friend.
  2. #27
    Canada
    89 ix
    Quote Originally Posted by jakermac View Post
    That doesn't work anymore
    *edit: doesnt work with chrome but still works with firefox
  3. #28
    Oct 2016
    Atlanta, GA
    1995 BMW 740i 02/95
    More info on m50b30nv stroked? I have a spare m54 I'm tryna dismantle
  4. #29
    Sep 2016
    Everett, Pa
    95 BMW 318is
    I did this build myself. Problem is it backfires through intake. I keep rechecking the timing with no start. Just popping through intake. Any thoughts?
  5. #30
    Apr 2014
    PA
    So it's been awhile..... I have bought and completely rebuilt 2 cars and just recently bought a Ford 6.9 diesel Flatbed.... Needless to say this thing has been neglected, but no more!!! Here is the progress so far.
    Got the m50b30 close enough where the other engine had to come out.
    Trans, exhaust and drive shaft to. Switching to a zf320. More on that later....
    Switching over the necessary components
    Shop dog Jr.
    I have thing for tranniez
    SO. Everyone on the internet says the zf310 and zf320 are identical in all things that matter. NOT. First off, my 310 had a forward transmission mount in the shape of a U. The 320 does not. Seems it doesnt matter but tripped me up for a little. Next, the Shift selector joint on the rear of the transmission are different lengths. Not by much but enough to throw of your shifter. 4th gear was slamming the center console. Changed the 320 joint for the 310 joint and worked perfect. I was pulling my hair out trying to find the problem and it was jus tthe little joint!
    Got the engine installed to
    zf320 with new clutch, t.o.b., guibo and slave.
    Changed CSB and put d shaft back in.
    90% complete!!
    Till next time!
    "Helicopters: 10,0000 pieces of metal fatigue rotating around an oil leak."
  6. #31
    Jun 2018
    RSA
    e12 528i, e30 3?? e32 74
    Got the m 50 b 30 close enough where the other engine had to come
    hey gents. What was your final outcome on the m50b30 stroker motor? whp? was there any disadvantages? and my biggest concern, would it be great to build for constant high revving?
    thanks
  7. #32
    Feb 2008
    Los Angeles
    see sig
    Props to OP S61Dan.
    I just picked up an M54B30 for cheap - disassembled, and it looks pretty good. I'll soon be pulling the M50B25tu out of my '93 E36. Deleting VANOS - it's a track only car. I was suspicious about swapping in M54 cams. I have what purport to be S50 cams. We shall see.... Any experiential input or advice is appreciated.
    You fly helos, so, ur nuts, but appreciate the help. Thx
    Tom
    E93: 09 328 'vert [dd]
    E53: 03 X5 4.4i [tow]
    E36: 93 325is [track]
    E30: (LeMons) [R.I.P]
    2nd Gen LS1 Camaro Build
  8. #33
    Alachua, FL
    '92 BMW 535i/5 Lazurblua
    I've got a '93 E34 M50B25 with 305k miles, ran great until a coolant leak sprung last year... Didn't overheat that I know of... But ran a bit rough and had a CEL when last started and has been sitting a year... Thinking to revive it and have M54B30 engine available at the local Pick-n-Pull... Don't know if I should use my high mileage block for a stroker or look for a full swap...
  1. My M50B30 Build
    By S61Dan in forum 1988 - 1996 (E34)
    Last Post: 08-27-2018, 08:55 PM
  2. My turbo build up (56k No Thx)
    By 5mall5nail5 in forum Forced Induction
    Last Post: 09-25-2007, 11:29 PM
  3. I've decided to document my MegaSquirt build!
    Last Post: 03-21-2006, 07:59 PM
  4. MY Cage Build Thread :) (56k beware)
    By magnetic1 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 08-22-2005, 02:04 AM
