Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 64
Thread: My M50B30 Build
  1. #26
    May 2014
    Springfield OH
    1993 525i 1995 553i
    Are you using the 2 piece piston ring set? I heard that there was some kind of hybrid M52/M54 Frankenstein 3 piece ring set that wears a lot less more than the factory 2 piece set.
    95 E34 553i6 LS TR6060 Project
    93 E34 525iA Beater with no heater
    VANOS kicked in yo!
  2. #27
    Apr 2014
    PA
    Using stock m54 piston rings.
    "Helicopters: 10,0000 pieces of metal fatigue rotating around an oil leak."
  3. #28
    Apr 2014
    PA
    Update again: Worked on the engine today. Put the rear main seal housing in and installed the oil pan all with new gaskets. Also helped my Dad put his completed M54b30 into the E39. Wheew!
  4. #29
    Arid Zone
    E34sx5
    Very cool to see.
    ________________________________
    Nik
    91' M5 3.9L Stroker
    92' M5 3.8L
    95' 540i6 Supercharged
    95' 540i6 4.7 Stroker
    95' 550i6 M70 Conversion
  5. #30
    Sep 2016
    Niagara
    1995 525i, 1994 540i6
    Awesome! Thanks for all the pics!
    What did you use to "hone" the cylinders?
  6. #31
    Apr 2014
    PA
    I used one of those 3 puck stone ones on a drill with some motor oil
  7. #32
    Apr 2014
    PA
    Update: Was ready to install the head and was cleaning the surfaces when I noticed a CRACK from a valve seat running to a coolant jacket. Was more than a bit upset. I looked over the head quick when I received it from the machine shop, however apparently not close enough. I had the surface covered with tape to do the valves and only removed the tape in prep to install. Called around for quotes on repairs and they were in the $500-$700 range.... What are you gonna do? Sourced a loaded head from a local guy on the cheaper side and am redoing all of the cylinder head work. Had donor head pressure checked and cut and will be doing valves sometime soon. Stay tuned!
    Donor head! has Aprox. 95k miles on it. Car was wreaked.
    Let's start over!!
  8. #33
    Mar 2012
    Baltimore, Maryland
    2016 640i, 1990 535iM
    Awe man bummer. I'll be staying tuned for the results. Hopefully you will not go back to the same place for head work
    2016 640i Coupe'
    1990 Bmw 535i Turbo 600whp
    1999 740iL: Sold
    1997 740i: Crashed and Parted
    1988 535i: Crashed and Parted
    1988 528e: Crashed and parted
    IG- @Rogetta_Stone
  9. #34
    Apr 2014
    PA
    Quote Originally Posted by E38740iMD View Post
    Can't blame the machine shop, I just asked for a resurface not any "extra" inspection. I mean, yes they probably SHOULD have seen it as who DOESN'T inspect the surface you just cut.... This has been a sort of bad luck build between the bent rod, cracked valve retainer and now the head being cracked. No gains without pains I suppose.
  10. #35
    Hamburg, NY USA
    e23, e32, e34, e39
    Go back and look at pics posted on first page- can you see the crack now? Looks like number 5 exhaust??
    Good thing you caught it before install. Sucks either way.
  11. #36
    ATX
    Sundry old Grrrrmans
    Damn, Dan the Man, that sucks. I'd be a little ticked the shop didn't even mention it...but agreed that just sourcing a new M50 head is cheaper than fixing those cracks.
    - Brent
    www.angry-ass.com
    Quote Originally Posted by danespann View Post
    Every E34 needs the same things in the end.
  12. #37
    Apr 2014
    PA
    Quote Originally Posted by m735is View Post
    It was the third cylinder from front of the engine.
    Quote Originally Posted by BleedsBlue View Post
    Im sure the guy barely looked at it. More disappointed in myself for not looking at it hard enough when I received it. Water under the bridge I guess. I am working on the "new" cylinder head as we speak.
  13. #38
    Apr 2014
    PA
    Update: Got the new head polished, valves lapped and installed. Put on a new hg and installed the head. It's starting to look like something now.
  14. #39
    Oct 2008
    Denver
    '91 M5
    Looks good.
    Current Fleet:
    E34 1991 M5 Macaoblau on Complete (ruined)Leather Champagne - http://forums.bimmerforums.com/forum....php?t=1705166
    Past:
    E34 1989 535i 5-Speed AlpineweissII on Natur - Parted
    E34 1992 525i 5-Speed Islandgrun on Pergament - Parted
    E34 1995 540i 6-Speed ShwarzII on Shwarz - Sold to Sneezy.
    E34 1995 525i 5-Speed Calypso Red on Parchment - http://forums.bimmerforums.com/forum....php?t=1748143 - Sold locally.
    E39 1998 528i 5-Speed Black on Black - Sold locally.
    E34​ 1993 M5 Alpinweiss on Black - http://forums.bimmerforums.com/forum...lpinweissII-M5 - Parted
  15. #40
    Apr 2014
    PA
    Got a chance to do some work on the build. Cleaned lifters/trays/cams from head #2 and installed them. Still needs timed and install sprockets/chain/ tensioners
  16. #41
    Apr 2014
    PA
    Got the chain tensioners, sprockets and chained installed and timed today.
  17. #42
    Mar 2010
    Marin, CA
    1989 535i Manual
    Looking good man!
    "Big Red" 9/88 Build 535i/5: E.A.T. Chip, 24lb Bosch Design III, 3.46 LSD, 4x Clear corners, DINAN-style 750i muffler, Racing King Subframe Inserts, Koni/Vogtland suspension, E34 M5 swaybars, Brembo/Porterfield brakes, Turbodiesel grills, 16" Style 8 rims, Euro front plate, M5 rear filler plate.
    Save
    Save
  18. #43
    Apr 2014
    PA
    Thanks! Wish I had more time. It's taking me a million years to build this thing.
  19. #44
    Apr 2014
    PA
    So it's been awhile..... I have bought and completely rebuilt 2 cars and just recently bought a Ford 6.9 diesel Flatbed.... Needless to say this thing has been neglected, but no more!!! Here is the progress so far.
    Got the m50b30 close enough where the other engine had to come out.
    Trans, exhaust and drive shaft to. Switching to a zf320. More on that later....
    Switching over the necessary components
    Shop dog Jr.
    I have thing for tranniez
    SO. Everyone on the internet says the zf310 and zf320 are identical in all things that matter. NOT. First off, my 310 had a forward transmission mount in the shape of a U. The 320 does not. Seems it doesnt matter but tripped me up for a little. Next, the Shift selector joint on the rear of the transmission are different lengths. Not by much but enough to throw of your shifter. 4th gear was slamming the center console. Changed the 320 joint for the 310 joint and worked perfect. I was pulling my hair out trying to find the problem and it was jus tthe little joint!
    Got the engine installed to
    zf320 with new clutch, t.o.b., guibo and slave.
    Changed CSB and put d shaft back in.
    90% complete!!
    Till next time!
  20. #45
    Jan 2015
    Tempe, AZ
    1995 525i/5
    It's cool that this thread popped up recently, as I've been thinking about an M50B30 build... what kind of gains can be expected from it? An S50 makes about 240hp, so with a proper tune would it be around that ballpark?
    1995 525i 5-speed - Thread
  21. #46
    Apr 2014
    PA
    Quote Originally Posted by dannyzabolotny View Post
    Hard to say. I am using a miller war chip for tuning so that will help clean it up, but it's basically a non vanos s50 so number wise it's hard to pin down.
  22. #47
    ATX
    Dan the Man! Good to see you back here.
    I doubt it as a lot of the power comes from the head, or really cams in this particular case - but it should be a torquey sumbish compared to a B25.
    - Brent
    www.angry-ass.com
  23. #48
    Apr 2014
    PA
    Thanks! Good to be back and working on this ole girl again.
  24. #49
    Jan 2015
    Tempe, AZ
    1995 525i/5
    So an M50B30 stroker with S52 cams should be more potent than just an M50B30 stroker, right? I'm just brainstorming ideas for my own build.
  25. #50
    ATX
    Definitely (or S50 cams); it's been awhile so my memory is fuzzy, but I know there are other advantages in the S50/2 heads like increased flow as well. Head work is everything!
    - Brent
    www.angry-ass.com
  1. My turbo build up (56k No Thx)
    By 5mall5nail5 in forum Forced Induction
    Last Post: 09-25-2007, 11:29 PM
  2. My turbo build becomes turbo-euro build!
    By sandspeed in forum Forced Induction
    Last Post: 09-06-2006, 10:32 AM
  3. I've decided to document my MegaSquirt build!
    Last Post: 03-21-2006, 07:59 PM
  4. MY Cage Build Thread :) (56k beware)
    By magnetic1 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 08-22-2005, 02:04 AM
