1995 BMW M3 manual, boston green, luxury package, no accidents, never tracked PRICE DROP
95 BMW e36 M3 for sale--I love this car to death but it is time to sell her, my lady does not support me having 3 german cars. Car has 163,6xx on her, runs great, no smoke, starts immediately; came from factory with luxury package, power seats, cruise control, power sunroof/windows. 5 speed manual, clutch is strong, no slipping. Never raced, never tracked, participated in 1 autocross event. The car was originally a TX car owned by an elderly person, a BMW technician bought it approximately 5 years ago at 120k and then found out he was having a kid, I bought it from him 4 years ago bone stock at 140k. It lived in NYC for 2 winters, otherwise car has been in NC&VA away from snow. As you can tell by only putting 20k on in 4y, it was rarely driven in NYC, primarily used for road trips back to NC for which it was very reliable. It was rarely driven last year as I primarily ride my bicycle to work.
-Title in hand (it is titled in NC but shouldn't be an issue)
-Comes with snow tires mounted on 335i rims
-Yakima racks not included in price but negotiable. Can include 2 bike racks and ski racks.
Exterior is a 6
Interior is a 7
Drivetrain is an 8
With a small amount of love, this car could easily become show quality or with the right modifications could quickly become a reliable track car. I consistently get compliments both at gas stations and any time I have it in a shop as to the remarkable condition it is in for a '95.
I have done some tasteful upgrades to the car, these include:
-Ground control Koni adjustable height/stiffness on all 4 corners (car is lowered approx 1")
-3.5" MAF/24lb injectors
-AFE intake (sounds amazing)
-silicone Bimmerworld throttle body boot
-Turner Motorsports Conforti chip tuned for the MAF/injectors/intake, +30ish HP gain
-reinforced rear suspension towers
-Powerflex RTABs
-UUC HD black transmission mounts
Maintenance: I have all records since I've owned the car, unfortunately none before. Owner will receive an Excel document and all of my paper receipts. Maint done includes:
-oil changed with Castrol Synthetic every ~3k miles, only used BMW filters
-oil filter housing gasket and radiator hoses replaced 3y ago
-both power seats had all the gears changed (all movements now functional)
-guibo replaced 2y ago
-Stewart water pump with metal impeller with metal housing (upgrade from plastic components) 2y ago
-tie rod ends & sway bar end links replaced approx 1y ago
-front rotors and pads (Pagid red) and calipers (1 was seized) replaced approx 1y ago
-SS brake lines 1y ago
-plugs & wires 2y ago
-PCV hose replaced 1y ago
-alternator & battery replaced 6mo ago
-RR ABS sensor replaced 4mo ago
-driver window motor and regulator replaced 3mo ago
-coolant expansion tank & radiator hose replaced 1mo ago, coolant flushed
-valve cover gasket replaced 1mo ago
The Bad:
-there are some seeping oil leaks, I've been told the rear main and the oil filter housing are leaking slowly, never have to top it off
-power steering hoses are moist but not dripping, not requiring any fluid (very common on these cars)
-airbag light comes on at startup, turns off within 60 seconds
-idle occasionally bounces, never stalls. hoping ICV replacement and clean will fix. also common in these cars
-display shows 'low coolant' @ startup, needs coolant sensor replaced (has been this way since I owned it, never bothered me)
-pitting in both rear discs, pads are good and no vibration in pedal during braking, stops ona dime
New rear Sumitomos, 1y old front Sumitomos, 245 40s square all around. Side note--shop guaranteed 245s wouldn't rub up front when they shifted the slightly used rears to the front when I replaced the previous fronts; however at full lock the fronts rub very slightly
Price is $6795 OBO, no lowballs, no trades, no joyrides, serious inquiries only, I work quite a bit so don't have time to waste
Brian @ 336-905-0436
List Date: 10/7/2016
For more info, click here to view the original listing: 1995 BMW M3 manual, boston green, luxury package, no accidents, never tracked PRICE DROP
This item is no longer available.
