Yes
https://www.youtube.com/watch?v=YHNwEmPgyhU
I wonder what the time will be on drag slicks...
BMW 325ix M50 turbo active 4wd 7spd dct 840awhp
BMW E30 M50 turbo 6 speed with boost by gear and traction control. 764whp @ 1.7 bar (24psi)
Wow that's fast. What's ur setup damn
How much power u laying down ?
What kinda 60 ft you pulling ?
325ix e30 ??????
Any more details on the drive train? Is the trans and transfer case and front differential also out of an e34? Did it take any custom parts to make that work or just regular 325ix axles? Are all the drivetrain parts stock or is there any custom work done to them to make them survive at that power level? We do have 325ix's here in the US but I didn't know they even made an awd e34. They never sold them here.
Yes TC and front diff from E34, front axles too but they need some work to fit. Custom one piece rear drive shaft, modded front drive shaft, custom engine and trans mounts, you have to cut and weld the firewall and trans tunnel to fit everything. Im also running bigger brakes and 5 lug.
wow. great work!! all on a 2.5L?? do you happen to have a dyno graph? would love to see the curve of your powerband.
Powertrain: Big Bore 87mm S50| Boost Logic Gen 2 Mani | BorgWarner S366 | CP 8.5:1 pistons | Eagle Rods | O-Ringed block | Tial 50mm | Precision 46mm | LINK G4 standalone | ZF| F1 stage 3 clutch/15lb ltwfw| UUC Black TM/E| Vorshlag MM's | 3.23LSD w/AKG race bushings| AKG race subframe bushings| 'Bear Motorsports' Re-enforced subframe | Walbro 525lp fp| VPD pulleys| 4'' DP into 3.5 straight pipe"||
Handling: FK konigsports| '95 M3 strut mounts| Rogue Engineering RSM's| UUC RTAB's| 20mm front spacers| 2915lbs Full interior
Aesthetics: M3 bumpers| 18''x 8.5/9.5 BBS LMs| ZKW's| 50w 6000k HID| Smoked Corners| 50% wndshld/5% all around| M3 sedan seats F&R| Black headliner| Black/Grey suede door panels| ZHP knob| M3 steering Wheel|
PPF Z2 turbo cams. Yeah that's why I raised this one to 8000rpm, it just wants more! They respond great to boost too.
Are these the same one you are running with 280/280 and no vanos?
http://server.pure-pf.com/webshop2/i...duct&id_lang=1
wow, that is a really good powerband for a non vanos! I think I might have to try either those or the vanos cams on PPF's website.
You are running stock e34 differential and transfer case with 720 wheel horsepower?
Stock rear end also?
Are the 535/335xi parts this stout?
