Results 1 to 7 of 7
Thread: Coding SULEV e46 ms45.1 for a manual transmission
    Nov 2010
    Nashville, TN
    1983 320is
    I have a 2003 325i touring SULEV car that I've converted to a manual transmission. I've coded 205 out of the SA in all the modules except for the DME, which is throwing a code for lack of communication to the EGS. I can't find a program code to flash the DME for an M56 with a manual transmission, and honestly I'm not sure that there were any M56 manual cars produced. I tried to change the vehicle order to a manual of everything else then program the DME as if it was a replacement hoping that it would read the SA and code the DME accordingly, but nothing has worked. I have ISTA-P and Autologic. I live in CA and the car needs to pass smog. Anybody got any ideas? Apparently there's a local tech who knows how to get in there and actually delete the lines of code about the faults it's producing so that it no longer has the language to do so, but I feel like that could lead to other issues.
    Jul 2004
    Houston, TX
    36 Cylinders
    After coding the whole vehicle, did you erase adaptations in DME?
    The flash usually includes data for both auto and manual, and eeprom held info whether it is auto or manual.
    You should be able to get more info and even a fix using Tool32.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Nov 2010
    Nashville, TN
    1983 320is
    would the flash still include that data if there was no configuration of this car with a manual?
    Sep 2003
    Birmingham, UK
    BMW 850 and E55 AMG
    MS43 and possibly MS42 both used the same files for auto and manual, and they would auto-detect what they were running.
    I would try resetting all adaptations, INPA will show a long list of different ones that can be reset, and tool32 should have it, maybe the initialisierung job or similar. I would imagine MS45 is going to be similar.
    This can also check to see if aircon is fitted for example, and in some cases SAP's
    Giftschrank Projekt
    Sep 2003
    Alta Loma, CA
    M3, 325i, Ram 3500, FF
    I thought I had the only M56 Manual... Did you ever get the coding done?
    Thomas at BavTek in Riverside, CA coded mine 60,000 miles ago. Website doesn't mention coding, if your still in CA it's worth a call.
    http://www.bavtekinc.com/
    May 2016
    Bay Area, CA
    2002 M3 Coupe, 2013 535i
    I also have M56 manual (2004 touring) and about to tackle the coding - any leads? recommendations?
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    as mentioned before the coding is there for both auto and manual. All you need to do is clear the adaptions after the TCM is removed.
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
  1. E46 wtb e46 m3 6 speed manual transmission
    By skippy918 in forum BMW Parts Wanted
    Last Post: 09-25-2013, 03:54 PM
  2. E46 E46 M3 6 speed manual transmission
    By nolocontendere in forum Drivetrain & Transmission Parts
    Last Post: 08-12-2011, 06:00 PM
  3. E46 WTB: E46 m3 6 speed manual transmission
    By LukeG in forum BMW Parts Wanted
    Last Post: 01-12-2010, 11:52 AM
  4. WTB: E46 M3 6 Speed Manual Transmission
    By KellerBMW in forum BMW Parts Wanted
    Last Post: 09-02-2006, 12:52 PM
  5. 2001 325 xi (t) wagon for sale MANUAL TRANSMISSION
    By enodog in forum BMW Cars For Sale / Wanted
    Last Post: 07-20-2006, 08:59 AM
