Page 5 of 7 FirstFirst 1234567 LastLast
Results 101 to 125 of 160
Thread: Steed Speed E36 Twinscroll Manifold - Installation Thread
  1. #101
    Feb 2010
    Maryland
    97' M3/4/5
    How is the NVH with a poly engine mount compared to say a stock mount? I ran poly mount inserts on a v6 mazda before for about 1 day before reverting back to stock. I understand there is some compromise when going FI but I would still like to hear people's opinions.
    Sent from my SGH-M919 using Tapatalk
  2. #102
    Apr 2006
    Minnesota eh?
    86 325es
    I use a sleeve type poly bushing (like an A arm bushing), and with no carpet and a kirkey aluminum seat bolted to a solid seat base and the roll cage, it feels and sounds like you are sitting on top of the engine lol.
  3. #103
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I have no complaints about full size poly mounts like the vorshlag, which is a pretty hard 75D. Been using them for years.
  4. #104
    Vancouver, B.C., Canada
    '97 M3
    In my experience, poly engine mounts are not as much of sacrifice compared to poly transmission mounts.
    That small poly disc is not going to do much for NVH. Is my assumption correct that it is a bolt thru type, meaning no studs for further isolation?
    At this point, it is our best available solution (without fabricating our own) so props for the work so far.
  5. #105
    Mar 2003
    NC
    CES Stage 3 Turbo M3
    Quote Originally Posted by chikinhed View Post
    At this point, it is our best available solution (without fabricating our own) so prop for the work so far.
    The poly bushing is actually an akg trans mount bushing that has a hole through it, no studs. You simply bolt the mount to the chassis through the the bushing. We can make almost any design we need really, it was just the easiest solution at the time versus a straight solid mount to the chassis and it worked out well.
  6. #106
    Bellingham, WA
    e30
    The Inline 6 is balanced at idle and you can run pretty stiff mounts without much NVH impact. Put 75D mounts or solid rubber mounts on a 4cyl without a balance shaft and it will vibrate your fillings out. At least thats what happens if you use the mounts in an M42! Never had an issue in a 6cyl!
    -Nick
    91 E30 M42 on VEMS
    Turbo Camshaft Thread
  7. #107
    Apr 2006
    Manchvegas
    Boosted M3’s
    My engine mount, turbo is a gt40/94R 1.06ar
    1997 Cosmos E36 M3/4/5 Boost Logic GT40/94r .85 Technique Tuning
    Stock motor
    1998 Estoril E36 M3/4/c4 Steed Speed2 Gt40/94r 1.06 Technique Tuning,
    Built motor, Best ET ( 9.63 @ 142.61 mph MS100+meth ) 10/08/21
    Best mph ( 10.08 @ 144.66mph MS100+meth ) 9/18/19
    build thread:
    http://www.bimmerforums.com/forum/showthread.php?2269817-Habbit-continued-Turbo-build-V
  8. #108
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by Mod Addict View Post
    <img src="http://www.bimmerforums.com/forum/attachment.php?attachmentid=588290"/><img src="http://www.bimmerforums.com/forum/attachment.php?attachmentid=588291"/>
    <img src="http://www.bimmerforums.com/forum/attachment.php?attachmentid=588292"/>
    Don't think it would pass the white glove test. Clean it and try again.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  9. #109
    Jan 2005
    Santa clara,CA
    F80
    Where is your air filter positioned at?
  10. #110
    Apr 2006
    Manchvegas
    Boosted M3’s
    Stock motor
    build thread:
  11. #111
    Mar 2012
    Renton, Wa
    98 m3
    Oh the joys of no ac. I envy all the room.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  12. #112
    Jul 2005
    PEI, Canada
    2001 330i
    So is there only 4 of 20 (GB) installed so far?
  13. #113
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Is there any traction on the new motor mount arm?
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  14. #114
    Joliet, IL
    Out of Service
    Quote Originally Posted by 3literheater View Post
    +1
  15. #115
    '97 M3
    I've been slowly collecting the parts I need to swap in the Steed/9180 combo. I'll have everything I need by the end of this week. My plan is to make at least a couple of mount arms and sets of custom AC lines. Although, I have a few aircraft to finish up first before I can focus on my M3.
  16. #116
    Joliet, IL
    Out of Service
    Put me down for engine arm
    Why do you need custom AC lines?
  17. #117
    Mar 2012
    Renton, Wa
    98 m3
    Let me know how you handle the ac lines. I have been wanting to do that..
    1989 535i - sold
  18. #118
    '97 M3
    Based on Phil's info of installing the 9180 on the Steed, it's too tight at the SAP pump tray and the AC lines for the WG dump pipe. He ended up cutting the SAP tray. I'll do my best to not cut the tray and find a better routing for the AC. I'd like to put the lines down under the frame rail giving more room for the turbo intake and away from the heat. I plan to use aluminum (maybe stainless) tubing and AN fittings.
  19. #119
    Mar 2003
    NC
    We have been talking to Eric since the beginning of the year. I will speak to him again today.
    He has a prototype drawn up and ready I believe, and then we will be going into production soon after he has the last details worked out. I will post another update as soon as we get confirmation and some photos to post.
  20. #120
    Oct 2005
    Northern California
    Any pictures of this?
  21. #121
    Jun 2005
    New England
    It's not the dump pipe. It's the top of the wastegate that hits the AC lines. Either custom bend lines to go further under the SAP tray or cut a little off the SAP tray and lift/bend the lines in place.
  22. #122
    '97 M3
    I've finally begun my Steed TS / EFR 9180 install tonight.
  23. #123
    Manchester, N.H.
    96 332IS 6466 turbo
    Running yet ?
    1996 332IS
    Built 3.2
  24. #124
    '97 M3
    Running yet ?
    I think I'll start a mini build thread and only post pertinent info here.
  25. #125
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Yay
  1. The Official Racelogic E36 Install Thread!
    By Shuasha in forum Forced Induction
    Last Post: 08-02-2016, 07:58 AM
  2. DIY for intake manifold install? (E36 M3)
    By SmokemhontaS in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-15-2013, 02:29 PM
  3. Feeler: Steed Speed T4 manifold With downpipe/wastegate piping
    By GG///M3 in forum Forced & Chemical Induction Parts
    Last Post: 11-21-2011, 09:48 AM
  4. E36 Steed Speed Manifold
    By bubela in forum Forced & Chemical Induction Parts
    Last Post: 07-13-2011, 01:50 PM
  5. T3 Steed Speed manifold.
    By flow in forum Forced Induction
    Last Post: 07-19-2010, 08:14 PM
