Page 6 of 7 FirstFirst 1234567 LastLast
Results 126 to 150 of 160
Thread: Steed Speed E36 Twinscroll Manifold - Installation Thread
  1. #126
    Manchester, N.H.
    96 332IS 6466 turbo
    So, just for info purposes.
    The studs provided by steed when installing a precision 1.0 ts housing will need to modified. 2 of them will need to be cut down 5mm (ish).
    Also, you will need a slim line bushing. I spoke with john, and the mount arm and bushing combo should be available very shortly, maybe this week.
    For now, I'm going to modify a bushing.
    Brad is having luck with the Ireland bushing, or I guess the AKG turbo bushing would be the same.
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
  2. #127
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    AKG turbo bushing is too thick. It's really not much narrower than stock.
  3. #128
    Manchester, N.H.
    96 332IS 6466 turbo
    This one ? https://www.akgmotorsport.com/produc...yurethane-75d/
    1996 332IS
    Built 3.2
  4. #129
    Vancouver, B.C., Canada
    '97 M3
    Here are the dimensions of the Ireland Engineering mount that I've been using......
    https://www.iemotorsport.com/bmw/E36...ne/e36umm.html
  5. #130
    '97 M3
    I sent an email to AKG asking for dimensions of the turbo mount and got a poor reply of... "If you let me know what dimensions you are looking for in a mount and the application, I can see if anything we make would work. Do you need an offset bolt, or a straight thru? Although our E36/E46 mounts are not a true bolt thru, our unique design functions as a bolt thru."
    At least they are willing to accommodate different set ups.
  6. #131
    Jun 2005
    New England
    Akg turbo mount is about 2.75 bottom and 2.25 top, and bottom thickness goes nearly to top.
  7. #132
    Mar 2013
    THE DIRTY THIRD
    '95 M3
    I just measured mine and it is 2 1/4" top, 2.5" bottom and 2 5/8" tall. The smaller top portion is only 3/4" of the total height.
    Turbo E36 M3 with all the things..
  8. #133
    Jun 2005
    New England
    Attachment 593605
    It's closer to 2.75 bottom than 2.5.
  9. #134
    Mar 2013
    THE DIRTY THIRD
    '95 M3
    Good call, I crawled under the car and tried to eyeball it. Not the most accurate way of doing it I guess.
  10. #135
    Jun 2005
    New England
    Ireland looks like the narrowest in the bottom/mid where clearance appears to be limited for some turbos. Maybe CES or Rally Road will come up with other options.
  11. #136
    Mar 2011
    Canadian in California
    Makes whoosh noises
    AKG have been the only ones to send me emails of dimensions in a timely and accurate manner. I bent my HPF motor mount bracket and switching to the E46 Rallyroad arm and didn't want to run the Volvo (rubber straight through mount with enforcer cup). Running an AKG E30 (45mm height) Solid, Bolt through with shims. 49.5mm is what the volvo mount originally was.
    Dunno if this helps or gives an option but Lisa at AKG has been nothing but awesome.
    Edit: *Thought the HPF mount was bent but it wasn't...either way went with the Rallyroad for a bigger intake*
    1000+RWHP, Lab22 Built Turbo S54 - BMW Half Mile Record Holder
  12. #137
    Geigertown, PA
    95 M blk/blk
    are we suppose to use the exhaust gaskets with this manifold? I thought I read somewhere that they were NOT using them, but I dont know the reason.
    96 328i ITR Racecar
    95 M3 blk/blk - hillclimb project - http://forums.bimmerforums.com/forum....php?t=1798796 - Retired to street duty after two awesome seasons!
    2002 325XiT - daily
  13. #138
    Manchester, N.H.
    96 332IS 6466 turbo
    Quote Originally Posted by bimmerbumm193 View Post
    I would.
    1996 332IS
    Built 3.2
  14. #139
    '97 M3
    Quote Originally Posted by Butters Stoch View Post
    I would.
    Ya you would
  15. #140
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Ya you would
    I call the one in green.
  16. #141
    '97 M3
    Quote Originally Posted by rajicase View Post
    Because she is showing more skin?
  17. #142
    Feb 2012
    1995 BMW M3
    Cause I see her giving them f*** me eyes. She looks like a real freak. My kinda lady.
  18. #143
    Manchester, N.H.
    96 332IS 6466 turbo
    Monica is looking lovely. ; )
    1996 332IS
    Built 3.2
  19. #144
    Apr 2006
    Minnesota eh?
    86 325es
    Around here we call that livestock.
  20. #145
    Feb 2012
    1995 BMW M3
    Moooo.
  21. #146
    Jul 2005
    PEI, Canada
    2001 330i
    Afterthought:
    Has anyone turned the manifold around to see if it could work as a Top-mount?
    My manifold is already installed...so I can' really play with it...
  22. #147
    Oct 2013
    Bulgaria
    E30 328t, E46 328Ci
    Let me get this topic out of the dust...
    Has anyone tried to install the manifold on an m5x swapped e30?
  23. #148
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by zoomer40 View Post
    I can tell you right now that’s not going to work. The frame will be in the way.
  24. #149
    Oct 2013
    Bulgaria
    E30 328t, E46 328Ci
    I thought so too, I guess its next to impossible to fit large bottom mount turbo in e30
  25. #150
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    Someone should make a bracket that bolts to the stock location to mount a urethane bushing offset towards the frame rail like this one
    http://www.ebay.com/itm/Prothane-19-...pXrKUX&vxp=mtr
    Then the mount arm would attach to that.
    like this
    Hey Perry, was this just a quick sketch or do you have the mount points of the motor mount arm modeled? I've yet to see a decent motor mount arm for this manifold made yet.
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
  1. The Official Racelogic E36 Install Thread!
    By Shuasha in forum Forced Induction
    Last Post: 08-02-2016, 07:58 AM
  2. DIY for intake manifold install? (E36 M3)
    By SmokemhontaS in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 05-15-2013, 02:29 PM
  3. Feeler: Steed Speed T4 manifold With downpipe/wastegate piping
    By GG///M3 in forum Forced & Chemical Induction Parts
    Last Post: 11-21-2011, 09:48 AM
  4. E36 Steed Speed Manifold
    By bubela in forum Forced & Chemical Induction Parts
    Last Post: 07-13-2011, 01:50 PM
  5. T3 Steed Speed manifold.
    By flow in forum Forced Induction
    Last Post: 07-19-2010, 08:14 PM
