Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 5 of 5
Thread: How much off set does a guy need to fill up the fender wells??
    Sep 2016
    kalispell montana
    2008 528XI
    I have a 2008 528XI and the OEM wheels are 17 inch/7.5 width, 5x120 bolt pattern with a 20mm off set. I am wanting to widen the stance of the car but dont know what size wheel/tire package I can get away with because of the all wheel drive. Can I put a 19 X 8.5 with 35mm offset? These are the swirling questions that go through my brain. Someone please tell me if my thinking is off. My brain tells me that the wider the rim, you dont need to have bigger offset? UG...
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    The lower the number the closer to the fender lip. The higher the number, the closer to the frame of the car.
    If you stayed with 20mm offset, but went 1.5 inches wides, the outside face of the wheel would be 0.75 inches or about 20mm, further out towards the fender lip.
    Aug 2002
    South Bend, Indiana
    BMW 525I
    The tire will also have something to do with it as well. The alignment setting will also play into what works and what rubs. What you are proposing will actually only go out 1/2" further than it does now.
    If I can help let me know.
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
    Sep 2016
    kalispell montana
    2008 528XI
    Thank you for the info..I was able to find a wheel calculator specific to my BMW and its telling that exact thing. A 20x8 inch wheel with a 30mm offset will move the face out 1 inch, and a 30mm about .81 inch. Now I just need to find out if the front will rub with the 35mm. I do not want to modify the suspension or wheel wells at all. It looks as though the front wheel wells dont have as much room as the back? Thanks again.
    Aug 2002
    South Bend, Indiana
    BMW 525I
    We have 8.5 wheels with 30mm offset and they do not rub so you should be fine.
  1. How much of my inheritance $ do I need to spend for 600 + HP?
    By scott pa e46 32 in forum 1983 - 1991 (E30)
    Last Post: 08-27-2012, 12:45 AM
  2. How much of my inheritance $ do I need to spend for 600 + HP?
    By scott pa e46 32 in forum 1991 - 1999 (E36)
    Last Post: 08-24-2012, 04:20 PM
  3. Replies: 11
    Last Post: 11-07-2007, 06:41 PM
  4. Mounted my amp today... now i need to clean up the carpet
    By 5mall5nail5 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-11-2004, 09:49 PM
  5. do I need to jack up the car to replace water pump?
    By ccblanket in forum 1991 - 1999 (E36)
    Last Post: 02-20-2004, 03:33 PM
