Results 1 to 2 of 2
Thread: Low compression along all cylinders.... Yay
    Sep 2016
    NWGA
    03 r53
    Hey all. To keep this story short I took this 02 mini S with 110k on trade for some work for a co-worker of mine. it has been sitting for 3 years. It was explained to me that it did over heat a couple times, but would cool back down. Im sure he missed some details being it sat for so long. But eventually it went into a limp mode/ ran bad and then would not restart once he got home.
    Ive done the troubleshooting that I knew to do which includes:Replaced the battery, checked grounds, pulled some engine codes (ill list them below), Fuel pressure is at 55psi, have good spark, getting a pulse from the injectors with the noids (though i only had 3v with a multimeter). Now the compression #1 30psi #2 70psi #3 60psi #4 50psi. It sounds like I am getting blow back, which is unfortunately to familiar to when i blew my head gasket on the chevelle not pulling enough timing back.
    Things I'll try tomorrow include a wet compression test and a leak down. then most likely taking the head off...
    small details, appears to be no water in the system and it builds pressure when I turn the car over, has a broken dipstick but i was able to snake it out and the oil looks brown and smells accordingly...
    here are the codes in order that I pulled them before clearing them to see if any would come back and NONE did. i know there are duplicates but thats how they read.
    p0302
    p0313
    p1229
    p1692
    p0302
    p0128
    p0313
    p1229
    p0500
    p1692
    Just trying to see if theres anything I should do in the morning but I wanted to post this up before I dive in for any tips or shared knowledge. I'm gonna drain the oil and water (if any) from the lower hose to see what I find.
    Thanks so much for reading all this btw
    Sep 2016
    NWGA
    03 r53
    So this happened... Any theories to why both sides would go out like this? Any way to check for water pump failure without the motor running?
  1. E39 low compression on all cylinders
    By Rodneyco99 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-15-2015, 01:32 PM
  2. E28 520i 1986 Low compression on all cylinders after head gasket change, HELP!?
    By jayblunt in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-13-2015, 12:55 PM
  3. Help, Low Compression In One Cylinder
    By anxious in forum 1991 - 1999 (E36)
    Last Post: 06-14-2007, 01:29 PM
  4. how much to have low compression in a cylinder repaired?
    By trevorborden in forum 1992 - 1999 M3 (E36)
    Last Post: 08-09-2006, 03:30 AM
  5. Low compression on 2 cylinders
    By adcoli in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-16-2005, 09:35 PM
