Page 5 of 6 FirstFirst 123456 LastLast
Results 101 to 125 of 129
Thread: Mklock's Nickel and Dime Ya turbo project / build thread.
  1. #101
    Mar 2013
    Upstate NY
    M3
    Thanks, Dyno was done at Boosted Creations in Victor.
  2. #102
    Mar 2013
    Upstate NY
    M3
    Quote Originally Posted by hsvturbo View Post
    Congrats. Very good numbers for pump gas and a s362.
    Yessir, thanks. Your Manifold is holding up well. We hotlaped 6 times n a row on the dyno zero issues lol. Guys at the shop were like it just keeps making more...
  3. #103
    Mar 2013
    Upstate NY
    M3
    Togue fest prepped, 8 psi, ready for Tail of the Dragon this weekend. 2500 miles incoming, lets test my build
    275/35/18 Rsrr for anyone wondering.
  4. #104
    NY
    skateboard
    Quote Originally Posted by Mklock View Post
    How loud are those tires? Are you running flares?
    ― George Orwell
  5. #105
    Mar 2013
    Upstate NY
    M3
    Very fckin loud, they grip like monsters though once up to temp, 33psi F, 31psi R, they sound like monster truck tires but my exhaust is louder... yes 75mm rear flare, 50mm front flare, able to squeeze a square setup, rears I could easily run a 305-315.
  6. #106
    NY
    skateboard
    Sweet . Which flares?
    ― George Orwell
  7. #107
    Sep 2009
    Syracuse, NY
    95 M3 Turbo, 08 535xiT
    You driving all the way down or trailering?
  8. #108
    Mar 2013
    Upstate NY
    M3
    Just tried looking for it, it's on EBAY, usually 110$-140$. Usally under "drift style" etc. Couldnt find them now, they pop up a lot. Fitment on OEM panels is 90% good, you have to cutout non-M3 side mouldings or M3 mouldings, and that's it. They line-up with the sheetmetal.
    /e Vrbun - Driving all the way, 300 car event called Togue Fest.
  9. #109
    Vancouver, BC Ca
    1993 325is
    These?
    https://www.ebay.com/itm/BMW-e36-Fen...zoHK:rk:8:pf:0
  10. #110
    Mar 2013
    Upstate NY
    M3
    Negative, did some more looking, pretty sure these are it. They have gone up in price. https://www.ebay.com/i/253398033124?...241c6dfff98495
  11. #111
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Im shocked those RSRRs are hooking at 600. I had RSRRs and they are a great tire no doubt and were wonderful for twisties but couldnt get them to hook for shit.
  12. #112
    Mar 2013
    Upstate NY
    M3
    They are not hooking 600 These are meant for left n right turns, once they are up to temp they hook okay. Not meant for drag racing though.
    They are 275/35/18 varient.
  13. #113
    Mar 2013
    Upstate NY
    M3
    Watkins Glen, Still rippin. Still slayin. Turbo E36 will not die.
  14. #114
    Mar 2013
    Upstate NY
    M3
    Welp, so here I am 2020 wow. Car is still alive maybe I'll update this with some photos. My past turbo setup has retired mostly. Ended up boring the engine out to 87mm because why not? Fully built, rods, what have you, e46 m3 oiling system, yada yada. Oh, also did a 6 speed swap on the way because why not.
    So, here I am at the final stages of this setup. Moved to the new Steedspeed manifold too, pretty cool part. Car just does not like going into boost @ WOT. It goes very lean 15+ and I eventually let out because well it breaks up and I know that's probably too lean. Using a 22RPD 80LB tuning setup. I've done everything I can think of, fuel pressure, checked everything to do with the MAF, boost leak, hoses, FPR hose, everything is setup perfectly. Trying to think of what could cause it to go so lean only under WOT as it rolls into the spring pressure. Fuel pump is relayed and is a 340lph pump. All of this is on 93octane too.
    Keep mind idle is smooth as glass, afr is 14.2-14.9 during idle. Driveability is gorgeous, pulls good. ONLY WOT and that is it. Vaccum is right around 16. If you all can think for me maybe something stupid i miss, it's got me stumped and i've rarely had issues and i wanna drive this hooptie to piss off the locals lol.
  15. #115
    Vancouver, BC Ca
    1993 325is
    Just a total shot in the dark here, and I don't truly understand the BMW DME strategies, but could a bad TPS fool the DME into thinking that the car is NOT at WOT when you "command" it?
  16. #116
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by jakermac View Post
    45% throttle is the main condition for wot
    (Gross simplification)
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  17. #117
    Mar 2012
    Renton, Wa
    98 m3
    The good idle and cruise paired with breakup are really throwing it for a loop.
    At breakup does it feel like it’s coughing or crackling?
    Your plugs looked good yesterday.
    Any codes? It could be a cam-sync type error. If you free rev it does it go happily to 6-7k?
    1989 535i - sold
  18. #118
    Mar 2013
    Upstate NY
    M3
    Quote Originally Posted by vollosso View Post
    @ Jaker, so I'm not a guru at the DME either but I've tried 3 seperate TPS just to be sure and they all act the same with which ever one I put in.
    Yeah, It's so strange, with the conditions of it driving and idling better than it ever has by far, as far as smoothness and whatnot you'd figure going into a little boost would be fine.
    I'm leaning towards it crackling and not coughing. I'm going to try a different set of coils and coil harness just to rule out a missfire. Also try a different set of plugs because that's cheap enough.
    Yup, I figured as much they looked great to me too.
    Zero codes, minus a stupid evap code but that's it.
    Goes right to redline, i've bounced it off limiter several times and it's smooth as glass.
    Could unplugging the battery do anything lol. Grasping at straws if I have too lmao.
  19. #119
    Vancouver, BC Ca
    1993 325is
    Spark blow out? What gap are you running?
  20. #120
    Mar 2013
    Upstate NY
    M3
    .022 on the gap.
    Turns out it was a faulty MAF, was a last ditch effort but lo n behold we got tooooonnnns of fuel now. Brand new MAF and I'm not sure if i messed it up somehow but all is well and it's boosting strong again.
  21. #121
    Vancouver, BC Ca
    1993 325is
  22. #122
    Jun 2013
    A Beach in Fl, US
    Z3 Turbo Ferrari 328gts
    Hey vollosso been trying to PM you but your box is full i need a turbo tune.
    2001 Z3M S52 OBX T4 Top Mount, GTX3582R T4 1.06, 66MM Compressor, 3 Inch IC Pipes,HPX, Wiseco 8-1, Ported Head, Carrillo Pro​ Rods, CES Cut Ring, 3.5 Exhaust, ARP, Big FMI, Turbonetics Gate Fender Exit, 2 Walbro Pumps, UUC 6 Puck Ceramic, Aluminum Flywheel. With working A/C.
  23. #123
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by Turbo E36 View Post
    Space
    1989 535i - sold
  24. #124
    Nov 2016
    Long Island, NY
    A few
    .022 on the gap.
    NICE. Post a vid of said boostin'.
  25. #125
    Mar 2013
    Upstate NY
    M3
    Yeah. Actually a dyno day in 2weeks too. I plan on getting a remote tune to get it perfect eventually but I might do the dyno day just to see what it makes. Only 50$ so worth to see if I built this thing right. I'll get a little video after a little.
    For anyone wondering about the steedspeed creeping it does for me as well. Open dump WG. I'm creeping 3psi past spring pressure. IE: 6lb spring I'll climb to 10 or so, 15lb sprin, I climb to 18-19psi.
  1. '79 323i restore/m20 carb project build thread
    By onedroppr in forum 1975 - 1983 (E21)
    Last Post: 11-01-2017, 10:53 AM
  2. Boosted 528's turbo E39 build thread
    By boosted 528 in forum Forced Induction
    Last Post: 02-04-2015, 10:37 PM
  3. Replies: 11
    Last Post: 07-19-2009, 10:35 AM
  4. 2002 turbo / megasquirt build thread
    By n00bjabi in forum Forced Induction
    Last Post: 03-05-2009, 12:04 PM
  5. 1996 M3 Turbo V3 Build Thread
    By DanR in forum Forced Induction
    Last Post: 09-05-2008, 09:18 AM
