Page 4 of 6 FirstFirst 123456 LastLast
Results 76 to 100 of 129
Thread: Mklock's Nickel and Dime Ya turbo project / build thread.
  1. #76
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by Mklock View Post
    I see, should I use a second form of holding it onto the tunnel? I cut all the vallies with a blade and had a super clean surface before hand. I'd prefer not cleaning it up in a year or two. Also used a heat gun to help adheasion.
    I didn’t use heat. I specifically used “fatmat” in mine. Adhered great.
    But just after the bell I had a splice and it ran out of there over the last few years.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  2. #77
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    Quote Originally Posted by vollosso View Post
    Yep I cleaned and sandpapered my tunnel.
    But alec, was yours TAR BACKED??? Or just foil.
    Mine was foil with some insulation on the back side. It was DEI brand.
    Sent from my SM-G900V using Tapatalk
  3. #78
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I put DEI fiberglass heat tape on about 8 years ago. Holding up well. Very thin so access is as good as it can be. I did one car with 2 inch tape and bought sheets for another car. Not a pretty as the fancy stuff in the pictures above.
  4. #79
    Mar 2013
    Upstate NY
    M3
    DEI was one that I was looking at, I opted to go thinner with this stuff. It's more of a sound dampener I think but should reflect some heat. Dynamat is the name brand of it, guess we will see if it holds up! This did have the "Tar backing" though and I let it sit in the sun to get playable. All I know is the stock stuff thats in there turns to literally dust and I could not deal with it lol.
  5. #80
    Mar 2013
    Upstate NY
    M3
    Making progress, switched HVAC to digital. Carpet is in along with the right pedals. Engine dropped in fairly easily, and what do ya know couple wires rigged up and it fired right up! E36 FTW! Shoutout to Volloso for the hookup on wiring it.
    https://flic.kr/p/27zVK6W
  6. #81
    Nov 2015
    Lake Tapps, WA
    99 Turbo M3
    looks amazing man, I wish my under carrage was that clean. What happened to the 20lb sxe and stock motor? did you ever blow it up? im on 92/meth, 3.5" exhaust with the s366 at 11lbs right now enjoying that big laggy monster, wonder what ill end up blowing the motor with.
    99 Turbo M3 - BWs366 - RSI - Fuse Fabrication - JE Cutring -
  7. #82
    Mar 2013
    Upstate NY
    M3
    20lbs with the s257sxe got me to 510whp and 490wtrq. Turbo ran out of air but that was nothing I was not expecting. It was rated at 625 HP and pretty much did exactly that. Stock internals are known to be pushed into 600whp so once you graze that threshold, it's anyones guess on when she pops. I'll "attempt" a 600whp pull just for the size queen number then I'll set it to 525 whp and call it good. Motor seems nice and loose when turning it by hand so I have faith in it.
  8. #83
    Huntsville, AL
    95 M3
    What is with the spacer on the motor mount?
    WOT
  9. #84
    Mar 2013
    Upstate NY
    M3
    To clear for a 4" intake. I just re drilled the bolt pattern on the block 1" lower than the orginals, welded 1"x 4" piece on the bottom to allow room for the lower bolts 1" lower. Made up the difference with a longer stud and aluminum spacer for the mount side.
  10. #85
    Mar 2013
    Upstate NY
    M3
    Final product of the engine bay, things missing, oil cooler, and a decent catch can setup. That's all I will be adding to this. I'm happy with the end result. Excuse the front clip being black, came off my M3. This will be getting done when I paint the car.
  11. #86
    Nov 2013
    VA
    E36
    looks great!
  12. #87
    Mar 2012
    Renton, Wa
    98 m3
    Looking good
    1989 535i - sold
  13. #88
    Mar 2013
    Upstate NY
    M3
    So I'm curious to ask, does anyone have the infamous rear valve cover leak? I've come to the conclusion that it's to much heat on the seal. It was fine for awhile, but now it's leaking again. I've noticed obvisouly it gets SUPER hot in that area. I'm going to try a turbo blanket + plus a stainless steel shield that attaches to the valve cover studs. If anyone else has any input or experience with this, I'd be grateful thanks!
  14. #89
    Mar 2012
    Renton, Wa
    98 m3
    I have never had an issue, I have like 30-40k turbo and 5 years on the same gasket
    1989 535i - sold
  15. #90
    Jun 2015
    Long Island, NY
    E36M3TURBO,E82135i,F15X5
    I have the same issue. I wonder if it has to do with crankcase pressure while in boost.
  16. #91
    Toronto, Canada
    E36 Turbo
    I for the life of me cannot get any of my VC to stop leaking... After switching from OBD2 to the OBD1 cover it's the worst it's ever been.
    I've been told that OE BMW gasket is the only way to make it not leak... I"m not hopeful but I did go ahead and purchase an OEM BMW gasket kit and will be moving back to OBD2 cover as well.
  17. #92
    Mar 2012
    Renton, Wa
    98 m3
    just rtv the whole cover haha. at least it won’t leak then.
    1989 535i - sold
  18. #93
    Dec 2014
    Marin,Ca.
    4.9L 540i/Porsche 997
    I wish I knew about this sealant with some old girlfriends.
    P.S. I mean the mouth area.
    22RPD Tuning '95 540i/6 custom turbo mit Borg Warner S400sxe/Rebello Racing 4.9L M62/JE pistons/Arrow rods/custom cams/S62 crankshaft/Darton sleeved/Focal custom stereo
    Porsche 996 Turbo Evosport GT 700-[700hp]-my daily
  19. #94
    Mar 2013
    Upstate NY
    M3
    Bahaha, whole thing was RTV already because I've had bad luck. Just a super thin bead (correct way) around it all. I'm also debating that it's a venting issue aswell. I'll report back after I use another NEW gasket, more RTV lol and a proper dual vent, (first vent from OE) second vent I'll try to figure out some kind of baffle setup plus big catch can. I'll also be adding heat shielding inbetween manifold + valve cover seal.
    /e my only gripe with the oil leak is that it drips on my manifold causing it to smoke like a mofo, then everyone thinks my car is a POS. Also, It's always combined with me driving like an idiot then letting it idle to cool down after a hard run.
  20. #95
    Mar 2013
    Upstate NY
    M3
    Okay okay okay guys get ready to drink the HATORADE. 100% stock bottom end 180k miles on the engine. "Wow its laggy" etc posts not be needed I'm at 15psi @ 3700, Yes not the best I KNOW. It does not SEEM laggy to me, I can't run a crazy aggresive map. 93 pumparoo gas, SO I CAN GO ANYWHERE WOOOO. Car runs insanely good. APPARENTLY 575 wtrq is safe nowadays lolol! Thanks to everyone who has shared knowledge on this forum! Can't thank everyone enough!!!!
    /e I'm not sure whats happening at the end, car redlines at 7k on the tach, I told the guy to pin it till she bounces off the limiter, maybe I was spinning maybe he let out IDK. Just imagine it keeps that power till limit, because it does. At least I'm not afraid to putup my backwoods E36 build dyno lol.
  21. #96
    NY
    skateboard
    Why only 6,500 rpms?
    ― George Orwell
  22. #97
    Sep 2009
    Syracuse, NY
    95 M3 Turbo, 08 535xiT
    looks awesome, where did you dyno?
  23. #98
    Apr 2006
    Minnesota eh?
    86 325es
    Don’t worry about dyno curves. It will haul ass on the street and that’s what matters.
  24. #99
    NY
    skateboard
    Correct
    ― George Orwell
  25. #100
    Huntsville, AL
    95 M3
    Congrats. Very good numbers for pump gas and a s362.
    WOT
  1. '79 323i restore/m20 carb project build thread
    By onedroppr in forum 1975 - 1983 (E21)
    Last Post: 11-01-2017, 10:53 AM
  2. Boosted 528's turbo E39 build thread
    By boosted 528 in forum Forced Induction
    Last Post: 02-04-2015, 10:37 PM
  3. Replies: 11
    Last Post: 07-19-2009, 10:35 AM
  4. 2002 turbo / megasquirt build thread
    By n00bjabi in forum Forced Induction
    Last Post: 03-05-2009, 12:04 PM
  5. 1996 M3 Turbo V3 Build Thread
    By DanR in forum Forced Induction
    Last Post: 09-05-2008, 09:18 AM
