Page 2 of 6 FirstFirst 123456 LastLast
Results 26 to 50 of 129
Thread: Mklock's Nickel and Dime Ya turbo project / build thread.
  1. #26
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    How are they shot?
    It'd take some serious scoring before I deemed a set of cams shot. Even a good bit of scoring on multiple journals will never be an issue with these cams.
  2. #27
    Mar 2013
    Upstate NY
    M3
    Intake is in great shape but something went wrong with the exhaust, deep grooves multiple journals. Will update with pic in a moment.
    Feb 2012
    1995 BMW M3
    Honestly I'd run those without hesitation.
    That scoring has probably been there for 10s of thousands of miles and it hasn't caused any issues so far and it won't in the future.
    Just my 0.02
  4. #29
    Mar 2013
    Upstate NY
    M3
    This is true, i've only had the car for 20k Miles there is no way i caused all of this lol.
  5. #30
    Mar 2012
    Renton, Wa
    98 m3
    Thats pretty average wear. Wont help you sleep at night but theyll probably work.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  6. #31
    Mar 2013
    Upstate NY
    M3
    Stuff
    Pretty much ready to be put back together, Just waiting on timing case profile gaskets. Getting rear subframe ready for 210mm conversion as well. Going to clean a lot more and removed that horrible insulation they used in the tunnel.
    Shifter detent pins successfully done too, I did not really like that job mainly the 5th / reverse.
  7. #32
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Quote Originally Posted by rajicase View Post
    Just my 0.02
    +1
    I'd carve my name in that journal
    and spin it to 8K.
  8. #33
    Mar 2013
    Upstate NY
    M3
    Got the 210 in plus some new control arms, waiting on oil pan then motor goes in!
  9. #34
    Mar 2013
    Albany, ny, usa
    96 M3. 94 E34. 98 750il
    I wish i was man enough to tackle the turbo install and a diff at the same time.
  10. #35
    Mar 2013
    Upstate NY
    M3
    Worst part is it probably wasn't even necessary for what i'm going for, but to have this in makes me feel somewhat better. Fun fact, can lift front of car up with 2 fingers with this differential in.
  11. #36
    Mar 2013
    Upstate NY
    M3
    s257 or s363...? have a lead on the 63mm cast s300.
  12. #37
    Feb 2016
    Rogers AR
    1995 BMW M3
    what cams are you looking for?
  13. #38
    Mar 2013
    Upstate NY
    M3
    Schricks would be ideal.
  14. #39
    Mar 2013
    Upstate NY
    M3
    Drove car for an hour with no exhaust I can't hear but runs great will update once exhaust is done!!!
  15. #40
    Feb 2012
    1995 BMW M3
    Nice what turbo?
  16. #41
    Mar 2013
    Upstate NY
    M3
    Went with my s257 it's rated for 650 which is plenty, if not I also have a s364.5 sxe which apparently bolts in since you just did it.
  17. #42
    Mar 2013
    Upstate NY
    M3
    Exhaust FINALLY done holy crap, guy did a great job though could not ask for more. It sounds pretty nasty somewhat loud but hey its a 3.5 pipe. Boost will happen tomorrow with 10lb spring + Boost gauge and Wide-band hooked up. Also need to modify my feed line as it gets a little to close to the manifold but can be fixed with a 90* Fitting. Then i need to setup the CCV to catch can still a lot of small crap.
  18. #43
    Feb 2012
    1995 BMW M3
    So it's done??
  19. #44
    Mar 2013
    Upstate NY
    M3
    Yep running an driving and no funky sounds. I've got a lot of odds and ends like catch can, ac slim fan setup, change oil a few times, get an alignment, flush transmission + diff, hookup lights just the lame stuff nobody has time for.
  20. #45
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by Mklock View Post
    Gotcha. Yeah I ran around for like 2 weeks with no wipers after my build cause I was too excited to drive it and too lazy to put them on. Then I got caught in a random rain storm lol..
  21. #46
    Mar 2013
    Upstate NY
    M3
    Alright 7lb spring in was to lazy to hookup my boost gauge so hopefully it was close. Runs strong hooked up pretty well, AFRS @ 11.4 when WOT. I'm liking my boosted m3 was well worth the effort. Thanks guys for all the knowledge you all share it has helped me a ton. Now i just need to fine tune and ill be happy with this for awhile.
  22. #47
    Feb 2017
    Las Vegas
    1995 M3 Coupe
    keep us updated... im very interested in the spool/power characteristics of the turbo.
  23. #48
    Mar 2013
    Upstate NY
    M3
    OK so been running around with no primary o2 sensors. Finally extended them to fit my exhaust I plug them up and to be expected my idle drops to like 850 was at 1K without. My idle is just a little choppy now. Any input? Plugs @ .022 tune is for schrick cams I have s52 cams that's about all I can think of that may cause it. It's not bad but if I can fix it id like too. Turbo also is in boost at 2800 rpm for anyone that's wondering, in third gear just full throttle. Hits 7 psi ( my wg setup) shortly after at like 3400
  24. #49
    Mar 2013
    Upstate NY
    M3
    Yayyyy got the fracking infamous timing chain buzzsaw decal noise randomly now. Rebuilt vanos with anti rattle new guides just ordered a new primary tensioner hoping that the bmw god's allow it to fix it. It's so loud I can hear it over my exhaust, it's sounds horrific I won't be driving till repaired. Side note car does have dual valve springs. Things I'll try if tensioner does not fix vanos oil feed line, vanos solenoid, then I'll move onto gears, thrust washers etc. The very last thing will be the timing chain and the very very last thing will be oil pump. Please help me pray to the bmw god's thanks.
  25. #50
    Mar 2013
    Upstate NY
    M3
    Long story short everything on car is great, im on 20lbs of boost lets see how long that lasts lol. I might end up like RAJI. Dyno on saturday stay tuned guys lets see what the 57mm baby turbo makes.
    Im guessing 480/420. Next power upgrade would be METH and that would push me over 500whp I think.
    Oh it flat gets it at this power level very good at straight roads lol.
  1. '79 323i restore/m20 carb project build thread
    By onedroppr in forum 1975 - 1983 (E21)
    Last Post: 11-01-2017, 10:53 AM
  2. Boosted 528's turbo E39 build thread
    By boosted 528 in forum Forced Induction
    Last Post: 02-04-2015, 10:37 PM
  3. Replies: 11
    Last Post: 07-19-2009, 10:35 AM
  4. 2002 turbo / megasquirt build thread
    By n00bjabi in forum Forced Induction
    Last Post: 03-05-2009, 12:04 PM
  5. 1996 M3 Turbo V3 Build Thread
    By DanR in forum Forced Induction
    Last Post: 09-05-2008, 09:18 AM
