Im working on getting my M5 straighten back out, I did a scan on it and I had a intermitent fault code in the DME, it only if you get heavy on the fuel pedal, but normal around town driving, its fine. I seen there was a couple of threads about it, but no one said in them what their fix was.
I cleared the code and it only comes back on very heavy throttle
Then in the IHKA I had these two fault codes, for which I tried clearing but they come immediately back on, so I know something is causing the problem, any suggestions on where these are located so I can start diagnosing the issues.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Well, I figured out the DME fault code, it turned out to be a bad fuse, F30 in the dash fuse box, but Im going to change the fuel filter anyways as a preventive measure
