Results 1 to 10 of 10
Thread: Wiper Motor Control Circuit for 3 wire BMW wiper motors
    Salem, Nh
    01 Z3M Coupe
    In getting ride of the wire harness and re-using the stock wiper motor it proved to be a challenge to get the motor to operate low & high and then shut off in the appropriate "park" position. A good friend of mine came to the rescue with this simply circuit made with two relays and a DPDT switch. After reading about other racers having to mess around to try and get the wipers to park by repeatedly turning a switch on off which is distracting and from what I've heard has actually caused a crash, thought I'd share this. Works like a charm.
    Jan 2012
    Perth, Australia
    1994 318is
    Nice, doe this work with the E36, I have no idea if it has a 3 wire wiper motor, but mine only runs flat out and doesn't park automatically.
    Salem, Nh
    01 Z3M Coupe
    I would think so the z3 shares a lot of parts with the e36 easy to check if the connector coming off the wiper motor has 4 wires total 3 thicker and one small then it should work
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    Posting for when I finally get around to wiring my wipers.
    Apr 2002
    Broomfield, Colorado
    Here's what I did:
    http://www.bimmerforums.com/forum/sh...ighlight=wiper
    It's basically the same as your diagram, without the relays.
    EDIT: yours actually auto-parks, and offers high and low wipers.
    So, yours is more complex, but better functionality.
    Nice work.
    Salem, Nh
    01 Z3M Coupe
    I'm not sure if your approach is switching the power feed to the motor but this is one of the things I like about the circuit my friend came up with. The power supplied to the motor is switched through the relays, which is a good thing and the DPDT switch is only switching the ground to the relays. Therefore all the wires I used going from the switch to the relays are small 22 ga. and the only heavier wire needed is to supply power to the relays. I used the stock wiring in going from the motor to the relays and from the motor to ground. I mounted the relays to a small piece of carbon fiber along with some terminal strips and made all the connections at the terminal strips and switch with spaded terminations on the wires and used sockets for the relays so I can replace any of the components easily without having to touch the wiring. I also used a push button reset circuit breaker instead of a fuse so I don't have to worry about carrying fuses around.
    Jul 2012
    Novi Pazar, Serbia
    1992 BMW E34 520i Sedan
    please reupload the photo. im doing the same thing and I'm stuck with wipers
    Salem, Nh
    01 Z3M Coupe
    Quote Originally Posted by EX27 View Post
    Here it is
    Northeast PA
    3 - E30 M3s, '04 Ford F350, '06 Audi A3
    I did mine without replays I went the super simple way Chuck described in his 1st post.
    Mine is a DP switch, up is fast, down is slow, Im switching power to the motor, motor is grounded, and I've had pretty good luck just stopping it out of my way if I wanted to.
    The stopping out of the way is easier with a single wiper.
    I dont stress over it, If i want to shut them off, I just wait for a straight away or other moment when I would otherwise have time to check my gauges and breath.
    As the wiper moves to where I want it, I flick the switch off, its really not been an issue at all, not near the issue I was afraid it would be.
    jimmy p.
    88 E30 M3 Zinnoberot - street
    88 E30 M3 Lachsilber - SCCA SPU
    87 E30 M3 Prodrive British Touring Car 2.0 Litre
    04 Ford F350 - V10
    06 Audi A3 Brilliant Red / 2.0 / DSG
    Aug 2012
    Central, MD
    1995 M3
    Quote Originally Posted by CMM3 View Post
    If you want auto-park of wipes, why not just keep the original Wiper Control Module? It's lighter and and already wired up, compared to 2 relays, etc.
  1. Wiper motor relay rewiring for 1997 BMW 740iL
    By MDWalters in forum General BMW sponsored by Intercity Lines
    Last Post: 12-30-2015, 10:06 AM
  2. Noisy motor blower air for my bmw e39
    By kimovitch in forum 1996 - 2003 (E39)
    Last Post: 05-03-2014, 02:56 PM
  3. PA Prussian Motors is looking for a BMW inventory specialist
    By bubela in forum Middle Atlantic - US
    Last Post: 10-17-2012, 12:34 AM
  4. lookin for a windshield wiper motor
    By bimmerguy320 in forum 1975 - 1983 (E21)
    Last Post: 10-28-2007, 08:35 PM
  5. FS: SRS Sensor Control Circuit (for Racing Seats) - $15
    By Lee in forum BMW Parts For Sale sponsored by Bavarian Auto Recycling
    Last Post: 02-12-2004, 04:36 PM
