2007 BMW 335xi.
19 8.5 offset 15 front, 19 9.5 offset 22 rear
Will this work? How bad will this stick out?
I have a used set of bbs lm wheels.
Tires 255/35 all around or 225/35 in front. Have all these tires already.
Help and suggestiond are very much appreciated. Have to make a decision today.
P.S. Im ok with small agression. I just dont want fitting problems or anything unsafe.
Thanks!
Hi,
Those offsets are a 5 series fitment. 3 series fitments will typically be ET37 front and ET39 rear. There'll be some small variance to those depending on which oem wheel is on the car, but will be fairly close i.e +/- 3 or 4mm or so difference.
Are the BBS wheels the genuine article? if so, it's then worth perhaps pulling your arches to improve the visuals. If they're imitation wheels, pass on them and look for better 3 series fitment wheels instead.
Cheers, Dennis!
