Hi guys,
I was hoping someone might have a resource for me to aid in replacing my mounts on my 550.
I can find videos and write-ups for the V6 but i need one for the V8...
Cheers!
Welcome to the forum.
BMW has never made a V-6 engine.
I will copy the professional instructions from Alldata. They are not easy, and I can't copy the photos easily, sorry.
You'll have to look back at the steps referenced in the "preliminary steps". I will copy them, but you need to put the files together.
22 11 001 - Replacing right engine mount (N62)
Necessary preliminary tasks:
Secure engine in installation position See: Service and Repair\Removal and Replacement\Securing Engine in Installation Position.
Remove underbody protection.
Remove both front wheels See: Maintenance\Wheels and Tires\Wheels\Service and Repair\Removal and Replacement\Removing or Installing Front or Rear Wheel.
Remove reinforcement plate See: Body and Frame\Frame\Structural Brace\Service and Repair.
Lower front axle support See: Body and Frame\Frame\Front Subframe\Service and Repair\Lowering/Raising Front Axle Carrier.
Observe safety instructions on raising the vehicle See: Service Precautions\Vehicle Damage Warnings\00 .. ... Lifting Vehicle With A Lifting Platform.
Release nut (1) and screws (2).
Tightening torque 22 11 1AZ/2AZ See: Specifications.
Remove engine mount.
Note:
Illustrations show M57.
Installation:
Lug (1) of engine mount must point to middle of vehicle.
Engine mount designations:
© 2016 ALLDATA LLC. All rights reserved. Terms and Conditions
Next (This step hangs the engine with a BMW engine hanger)
11 00 670 - Securing engine in installation position (N62, N62TU)
Special tools required:
00 0 200 See: Tools and Equipment\00 0 200 Cross Member
00 0 202 See: Tools and Equipment\00 0 200 Cross Member
00 0 204 See: Tools and Equipment\00 0 200 Cross Member
00 0 208 See: Tools and Equipment\00 0 200 Cross Member
11 0 000 See: Tools and Equipment\11 0 000 Engine Lifter for Removing and Installing Engines
Warning!
Danger of injury!
Observe following instructions relating to special tool:
Prior to each use, check the special tools for defects, modifications and operational reliability.
Damaged/modified special tools must not be used!
No changes or modifications may be made to the special tools!
Keep special tools dry, clean and free of grease.
Secure engine bonnet/hood in service position See: Body and Frame\Doors, Hood and Trunk\Hood\Service and Repair\Procedures
Remove acoustic cover
Remove intake filter housing See: Air Cleaner Housing\Service and Repair
Detach coolant expansion tank See: Cooling System\Coolant Reservoir\Service and Repair and place to one side
Remove tension strut (on spring strut dome) See: Body and Frame\Frame\Strut Tower Brace\Service and Repair
Assemble transverse member 00 0 200 See: Tools and Equipment\00 0 200 Cross Member with special tools 00 0 202 See: Tools and Equipment\00 0 200 Cross Member, 00 0 204 See: Tools and Equipment\00 0 200 Cross Member, 00 0 208 See: Tools and Equipment\00 0 200 Cross Member.
Important!
Avoid a change of engine position in the transversal or longitudinal direction.
Always make sure there is sufficient clearance between the engine (or its attachment parts) and the body.
Important!
Risk of damage!
Position transverse member 00 0 200 See: Tools and Equipment\00 0 200 Cross Member with a 2nd person helping by way of rests (1) on bolt connections of side panels.
Secure special tool 11 0 000 See: Tools and Equipment\11 0 000 Engine Lifter for Removing and Installing Engines to spindle 00 0 202 See: Tools and Equipment\00 0 200 Cross Member.
Attach suitable chains to special tool 11 0 000 See: Tools and Equipment\11 0 000 Engine Lifter for Removing and Installing Engines and suspend from both engine suspension eyes.
Warning!
Danger of injury!
Tighten down all adjusting screws and nuts on transverse member 00 0 200 See: Tools and Equipment\00 0 200 Cross Member.
Unscrew nuts (1).
Raise engine approx. 10 mm with transverse member.
Installation Note:
Replace self-locking nuts.
Tightening torque 22 11 2AZ See: Engine Mount\Specifications.
Next, drop the subframe:
Conversion Calculator
2008 BMW 550i Sedan (E60) V8-4.8L (N62TU)
Vehicle » Body and Frame » Frame » Front Subframe » Service and Repair » Lowering/Raising Front Axle Carrier
31 11 506 - Lowering/raising front axle carrier
00 2 030 See: Tools and Equipment\00 2 030 Universal Hydro-Lifter Basic Unit
00 2 040 See: Tools and Equipment\00 2 040 Basic Take-Up Fixture
31 4 012 See: Steering and Suspension\Suspension\Tools and Equipment\31 4 010 Axle Support Set
33 3 274 See: Transmission and Drivetrain\Differential Assembly\Tools and Equipment\33 3 270 Set of Supports
Warning!
Danger to life!
Secure engine in installation position to prevent it from falling down.
Danger of poisoning See: Service Precautions\Technician Safety Information\00 .. ... Danger of Poisoning If Oil Is Ingested/Absorbed Through the Skin if oil is ingested/absorbed through the skin!
Risk of injury See: Service Precautions\Technician Safety Information\00 .. ... Risk of Injury If Oil Comes Into Contact With Eyes and Skin if oil comes into contact with eyes and skin!
Important!
Adhere to the utmost cleanliness. Do not allow any dirt to enter the hydraulic system.
Seal off hydraulic lines with plugs.
Remove reinforcement plate See: Structural Brace\Service and Repair
If necessary, remove steering gear cover on both sides
If necessary, remove wheel suspension cover on both sides
Remove lower steering spindle from power steering gear See: Steering and Suspension\Steering\Steering Column\Service and Repair\Removing and Installing/Replacing Lower Section of Steering Spindle
If necessary, disconnect plug connection on EH converter and expose line up to engine carrier
If necessary, disconnect plug connection on ride-height sensor and expose line up to engine carrier
If necessary, unclip vacuum line for engine mount on engine support arm
Version with Dynamic Drive:
Draw off and dispose off hydraulic fluid from fluid reservoir.
Remove bottom right wheel arch trim See: Interior Moulding / Trim\Trim Panel\Service and Repair\Removing and Installing/Replacing Front Bottom Right Wheel Arch Trim.
Release nut (1) for Dynamic Drive return line.
Tightening torque 37 14 21AZ See: Specifications\Mechanical\Suspension\Suspension Control ( Automatic - Electronic )\Electric Components.
Release nut (2) for Dynamic Drive pressure line.
Tightening torque 37 14 13AZ See: Specifications\Mechanical\Suspension\Suspension Control ( Automatic - Electronic )\Electric Components.
Release nuts (3) for pressure lines to front axle oscillating motor.
Version with active steering:
Disconnect plug connections (1, 2).
Expose wiring harness (3) up to front axle carrier.
Warning!
Danger of injury!
Failure to comply with the following instructions may result in the vehicle slipping off the lifting platform and critically injuring other persons.
When supporting components, make sure that
the vehicle can no longer be raised or lowered
the vehicle does not lift off the locating plates on the lifting platform
If necessary, position special tool 00 2 040 See: Tools and Equipment\00 2 040 Basic Take-Up Fixture with a 2nd person helping on workshop jack 00 2 030 See: Tools and Equipment\00 2 030 Universal Hydro-Lifter Basic Unit.
Insert special tool 31 4 012 See: Steering and Suspension\Suspension\Tools and Equipment\31 4 010 Axle Support Set into corresponding receptacles of special tool 00 2 040 See: Tools and Equipment\00 2 040 Basic Take-Up Fixture.
Align special tool 00 2 040 See: Tools and Equipment\00 2 040 Basic Take-Up Fixture to front axle carrier.
Note:
Make sure when raising that the special tools 31 4 012 See: Steering and Suspension\Suspension\Tools and Equipment\31 4 010 Axle Support Set are correctly inserted in the rear recesses on the front axle carrier.
Support front axle carrier in rear area by raising special tool 00 2 040 See: Tools and Equipment\00 2 040 Basic Take-Up Fixture.
Position special tool 33 3 274 See: Transmission and Drivetrain\Differential Assembly\Tools and Equipment\33 3 270 Set of Supports on floor jack mounting.
Important!
Pay attention to power steering hoses and lines when lowering and raising. Hoses/lines must not be kinked/tensioned/bent!
When lowering and raising, make sure the cover for the relevant tension strut rubber mount is free to move.
Release screws (1, 2).
Installation Note:
Check threads for damage; if necessary, repair with Helicoil thread inserts See: Steering and Suspension\Suspension\Service and Repair.
Tighten down screws (1) and then screws (2).
Tightening torque 31 10 1AZ See: Specifications\Mechanical\Suspension\System Specifications\Front Axle Suspension.
Important!
Risk of damage!
The following operation must be carried out during lowering:
N54 with automatic transmission: Release screws (1) and remove bracket (2) for transmission oil cooler lines from front axle carrier
Lower front axle carrier 100 mm.
After installation:
Fill and bleed hydraulic system
Check pipe connections for leaks
Carry out steering angle sensor adjustment/adjustment for active steering
Carry out initial Dynamic Drive operation See: Steering and Suspension\Suspension\Suspension Control ( Automatic - Electronic )\Testing and Inspection\Initial Inspection and Diagnostic Overview
Don't forget to use the ISTA computer to reset steering angles sensor, etc......
Oh....you don't have an engine hanger? You don't have a lift? You don't have pole jacks to hold up the subframe? You don't know what an oscillating motor is? You don't have a second person to help, when all this stuff starts falling on your head? You don't have ISTA, to calibrate the steering angle sensor, and reset all the computers you'll piss off?
Sorry man, this IS NOT a DIY job for a newbie. Take the car to a pro.
Chris Powell
BMWCCA 274412
