Page 6 of 18 FirstFirst 12345678910111213141516 ... LastLast
Results 126 to 150 of 436
Thread: S54 in E36 M3, my turn
  1. #126
    May 2009
    Pittsburgh, PA
    S54/E36,18 Sierra Denali
    Quote Originally Posted by TH3 Shifty View Post
    yeah those are beastly!.. but i would HATE to put them on while the motor is in the chasis.. looks like a "from underneath" job, but you would a lift for the tilt angle to slide up and in.. look awesome though.. are you considering them? might have to re-do the entire exhaust system..
    I am considering them, but for the silver one. I don't think install would be that bad though, because the DP (Sec 1) disconnects from the main collector there and really shortens it up. It wont be for awhile, theres some other areas that need attention. I did see they have a set out to a guy with an S54 E36 though...If I didn't already have a standard header tune, I would consider those for the E36...You should definitely look into them. I read the who thread and apparently they're +20ish over the SSvV1's. If you're paying for franks tune...he the man for the ARH's too.
    When I dropped the motor in, I had the headers attached, but with new studs and hardware, I don't think it would be too bad of a job. Did you get the N54 studs?
  2. #127
    UT
    98 M3/4/5
    yeah i used N54... with stock manifolds so far...
    98 Estoril ///M3 4/6
    S54 swap CSL
  3. #128
    UT
    98 M3/4/5
    Update:
    got the Technica Tuning fuel pump... did the swap... wasnt bad, pretty easy to do, still waiting on SG headers..
    S54 swap CSL
  4. #129
    UT
    98 M3/4/5
    man i have been lagging on this lately... between work, children and life... not much time.. although i do have an update:
    received my 200 cell spun metalic 2.5" catsn today... going tp put them into my E46 stock section 1 where the resonater sits.
    i also followed Gpetersons idea of mounting the accelerometer by modifiying the baseplate instead of cutting the mount and re-welding it to the floor pan. I made a similar mount that gpeterson made
    STILL waiting on Status Gruppe headers ... i want to put them on before i drop the engine in..
    I also got new parts for the transmission, the pivot pin(metal from an E31) new fork and bearing.
    pics to come, ill post a pic from my phone to show a lil bling.
    Engine bling
    One more
    S54 swap CSL
  5. #130
    May 2009
    Pittsburgh, PA
    That cover is NICE!
  6. #131
    UT
    98 M3/4/5
    its actually an Ebay cover.. only 100$ shipped.. fits perfect.. you just need to increase the size of the holes for the studs a little bit to make it perfect.. it didnt come with the ///M badge so i got a new one for $40 shipped..
    S54 swap CSL
  7. #132
    May 2009
    Pittsburgh, PA
    Well when the time comes, I may have to get one. What are you doing for DME tuning?A buddy of mine sent me 2 DMEs for editing. One was for a swap, E36 / S54. I successfully edited the thing and tested it in my car. Worked perfect! I can show you how if you're interested?
  8. #133
    UT
    98 M3/4/5
    i was going to send it off to TTFS... for their header/performance tune... i just ordered the INPA/"EDIBADASAFRASSSS" disk and cable, i have no clue how to use that.... so not computer literate...any help on this is IMMENSELY appreciated
    S54 swap CSL
  9. #134
    May 2009
    Pittsburgh, PA
    I can help with that forsure. In the diagnostic section, I've asked for help on a few things. Check those out as they're common start up issues. Once it's running, it's an awesome setup.
  10. #135
    UT
    98 M3/4/5
    Small update, using Gpeterson's idea, I got the accelerator mounted.
    Then I worked on my section 1 catalytic converters to install the rear o2 sensor bungs
    S54 swap CSL
  11. #136
    UT
    98 M3/4/5
    Another update: got a used set of Status Grüppe headers, came in today, got them on this afternoon, should be dropping the engine in tomorrow
    S54 swap CSL
  12. #137
    May 2009
    Pittsburgh, PA
    Nice - feel like measuring the length of the primaries to the collector for me!?
    im getting a dyno baseline tomorrow morning.
  13. #138
    UT
    98 M3/4/5
    sure will do!
    S54 swap CSL
  14. #139
    May 2009
    Pittsburgh, PA
    sure will do!
    Awesome, I have 32 feet of stainless steel coming this week to begin the header / sec 1 Ideas I have
  15. #140
    UT
    98 M3/4/5
    stupid question, but i'll be using a soft tape measure... do you want me to measure with the tape ON TOP of each primary or on the side of the primary tube? not sure it will be different but just asking
    S54 swap CSL
  16. #141
    May 2009
    Pittsburgh, PA
    I had that issue too on the oem ones. I got 12.X at the sides and 13.X at the tops (outer most) part of the tube. Either is fine, or both haha. They should be equal length so 1 primary is fine. I don't want you to be there all day on each one. This is just a project I'm trying.
  17. #142
    UT
    98 M3/4/5
    I'll have these for you today, just going to do some quick rounds at the hospital and head home
    S54 swap CSL
  18. #143
    UT
    98 M3/4/5
    Update: got the motor in!!!! Was a beeotch, had to do it alone, the headers where keeping it from being super easy, so there was a lot of getting under the carwith a jack to maintain the rear level and the front with the hoist. I had to remove the load leveler because it was hitting the rear upper firewall. So I had the hoist attached to the front point which made super easy but the engine was a little too rotated towards the passenger side so I used the rear jack to help it rotate over so it would sit on the motor mount bolts better.
    so now it's onto the wiring. My engine came from an SMG car and thus has an SMG trans harness. I managed today to get a 6MT trans harness off eBay for $99, cheap enough so I got it and will save myself some time with wiring and stripping it.
    S54 swap CSL
  19. #144
    Feb 2016
    Rogers AR
    1995 BMW M3
    I didn't realize you had an estoril is a sedan?
    Making progress sir! It looks nice!!!
  20. #145
    Apr 2006
    Kingdom Of Bahrain
    04 E46 M3 JB/Kiwi
    Nice progress
    EURO 04 M3
    Current Mods: GC DA's, Eibach ARB's, INTRAVEE II + Alpine KCA-420i, Depo's, Screen protector for OEM 16:9 display, VCSL Bumper + Race Lip + CF Boot + CF Rear Diffusor, DIETZ TV in Motion, Z8 Starter Button, BBS CHs, Lamin-X, STORM SMG Paddles, RE RTABs/RCAs, OEM CSL Interior, OEM CSL Intake, M3 CSL HP DME, TTFS Tune, STOPTECH ST40's, FXR 3.0 Projectors, SS Stepped headers + Catless S Pipes + Res X-Pipe + Sport Muffler, OEM CSL Roof, OEM CSL Steering.
  21. #146
    UT
    98 M3/4/5
    Quote Originally Posted by lbennyboobool View Post
    Yeah estoril / dove gray
    S54 swap CSL
  22. #147
    May 2009
    Pittsburgh, PA
    Awesome, coming together. The Estroli is going to be badass.
  23. #148
    UT
    98 M3/4/5
    Update, doing some work on the exhaust, decided to shorten the E46 M3 section 2. Removed the small cross flow box chamber muffler. Working on making a Euro section 1 with 200 cell cats.
    S54 swap CSL
  24. #149
    Aug 2011
    Pennsylvania
    1995 Cosmos on black M3
    So you're running an e46 section 1&2 mated to an e36 muffler section? Just beginning an s54 e36 swap myself. I'm sure you'll be hearing from me often!
  25. #150
    May 2009
    Pittsburgh, PA
    Nice im making a sec 1 jig right now. Grab some mild steel and a few exhaust clamps, clamp the pipe in a few spots then weld the steel from clamp to clamp. Then you can build a while new one or cut parts and add cats without changing length etc.
    trans harness squared away?
  1. S54 in euro M3 E36
    By ulmi in forum Engine Conversions
    Last Post: 08-16-2018, 11:08 AM
  2. First kill in s54 turbo e36 m3, orange challenger
    By PedraM5 in forum Kill Stories
    Last Post: 09-06-2013, 06:34 PM
  3. E36 Anyone interested in e36 m3 sways?
    By M3racer007 in forum Suspensions, Springs & Shocks
    Last Post: 07-03-2012, 12:30 PM
  4. How do I angle my HIDs in e36 m3
    By ayoDMO in forum Lighting sponsored by BAVToys
    Last Post: 12-10-2010, 03:41 PM
  5. S54 in E36 M3 works!!!
    By carcrazed4life in forum 1992 - 1999 M3 (E36)
    Last Post: 07-08-2003, 01:22 PM
