Page 17 of 18 FirstFirst ... 789101112131415161718 LastLast
Results 401 to 425 of 436
Thread: S54 in E36 M3, my turn
  1. #401
    UT
    98 M3/4/5
    i searched mitch's thread but didnt see a list... i have a 4" 45* elbow and the 3.5" MAF and the stock E46 M3 elbow, and a few other connectors
    98 Estoril ///M3 4/6
    S54 swap CSL
  2. #402
    May 2009
    Pittsburgh, PA
    S54/E36,18 Sierra Denali
    Shit it was in my tbread. I’ve also got a 4”-5” silicone 45 for the bottom now that goes into the bumper area instead of that 4” plastic tube.
    Quote Originally Posted by PITT M3 RR View Post
    HFM
    inline filter
    4”-3.5” elbow
    cut 1/2 from the 3.5 end of the elbow and use it on the HFM to oem elbow connection for a tight seal.
  3. #403
    UT
    98 M3/4/5
    yep i have all that then... just got confirmation the filter just got delivered..
    hey how did you get that E46 M3 elbow to stay put on the box? very tight fit next to the shock tower..
    S54 swap CSL
  4. #404
    May 2009
    Pittsburgh, PA
    I hold it on, tighten it so it’s secure and then used a heat gun to soften it and it retained the new shape.
  5. #405
    UT
    98 M3/4/5
    ah.. pretty good idea, ill try that...
    so all my exhaust pieces should be here by thursday, just also ordered some 309 stainless MIG wire, going to trade my tank from the 25/75 to the tri-gas blend for stainless (90/7.5/2.5), got a that new VULCAN welding hood from Harbor Freight, its pretty nice, havent used it yet but this week i will.
    S54 swap CSL
  6. #406
    May 2009
    Pittsburgh, PA
    Oh nice, I have stainless flux core and it’s ass, but if your gas is separate, you should be good. You’ll want argon for stainless. Post some pic when you’re done!
  7. #407
    UT
    98 M3/4/5
    Finished the X pipe, I haven’t taken a final pic of it but this was just after I finished the center welds
    S54 swap CSL
  8. #408
    UT
    98 M3/4/5
    More welding, decided to make my own true 2.5” mandrel bent stainless section 2 & 3. Technically my section 1 is half 2.5” as well as the cats. I didn’t like the section 2’s D shape piping after the H.
    So I also ditched the H and made a true X. Almost all of the piping is 2.5” 16g stainless. I decided to use V-bands on the end of the muffler to ease installation and removal. Just an example of the work I’ve been doing below. I’ll be posting full pics once it’s done.
    S54 swap CSL
  9. #409
    UT
    98 M3/4/5
    Got the X midpipe done. 2.5” 16g stainless. I’m not the best welder at all and cleaned them up with flap wheels
    V-bands for the muffler connections. Stock flanges for the section 1 connection
    The X is made from 2, 15 degree bends, cut and merged. Then I used 2 more 15 degree bends to straighten them. All the other bends are mostly 45*. I had to make a few 25 degree and 2 10 degree bends.
    S54 swap CSL
  10. #410
    May 2009
    Pittsburgh, PA
    DudeThat is some serious fabrication, send me those installed pictures! I want to hear how this sounds to
  11. #411
    UT
    98 M3/4/5
    ill finish the install tomorrow afternoon. im off till thursday this week, so this thing WILL be done... i stopped early today because it starting raining, and i need the garage door open to work on the rear, i was getting soaked and it was miserable so i called it a day at 4pm.
    all thats left to do:
    hang the exhaust, make the center support bracket..
    clear the codes from last start up.
    put the wheels back on
    get it off the jack stands
    I just got a tracking number, FINALLY, for my euro washer tank and radiator cover... i have all the rest of the parts needed for install already.
    S54 swap CSL
  12. #412
    May 2009
    Pittsburgh, PA
    Have you driven it yet!? Your going to be like a kid on Christmas haha I drove mine with no bumper hood etc before I buttoned it all up just because
  13. #413
    UT
    98 M3/4/5
    Went to go start it yesterday and the battery was dead, put it on charge last night, about to go check it this morning. Also charged up the GoPro to record the drive.
    S54 swap CSL
  14. #414
    May 2009
    Pittsburgh, PA
    F'n finally. What go pro? I was looking at the Hero 5 black?
  15. #415
    Tampa, FL
    97 E36M3 S54
    You should totally Youtube live stream this so we can all watch!
  16. #416
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Quote Originally Posted by TH3 Shifty View Post
    Sweet! Im taking mine out for the first time tomorrow too. Just got my new coils and installed them this evening. I'll take video too
  17. #417
    UT
    98 M3/4/5
    Minor setback, started up great and sounds awesome, then the squealing started, traced it back to the trans, pulled the trans and 2 things happened, #1 I had the clutch disk in backwards. And #2. The pilot bearing just falls right out as well. ???? The hell???
    i must have had my stupid hat on that day, measured the pilot beating again, it’s correct no damage. No input shaft damage either. Decided to pull the fly wheel. Had it resurfaced, on my way to pick it up now. I also need to weld up 3 tiny pin holes in the exhaust I missed, so that’s a positive, anyway, getting it done today, picking up the flywheel now
    S54 swap CSL
  18. #418
    May 2009
    Pittsburgh, PA
    Damn - at least it’s squared away. When’s it all coming together now?
  19. #419
    UT
    98 M3/4/5
    “Because it’s shinaaaaayyyy”
    CDF35839-85CD-4C4C-987F-D77025146718.jpgThis is the FX/F1 chromoly 16lb flywheel. The machine shop said it was one of the strongest flywheels they have ever cut. Said the density was super hard, he liked it.
    Right now, I’m under the car as I type.
    Oh oh and I have GoPro Hero 3+
    S54 swap CSL
  20. #420
    May 2009
    Pittsburgh, PA
    Dude clean those flywheel bolt holes and that hub haha if you didn’t read my thread, read it.
    Also don’t be shy with the red loctite
  21. #421
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    Hey shifty, did you take a picture of how the clutch disk is supposed to be installed? The protruding end of clutch disk towards the flywheel or towards the trans?
  22. #422
    UT
    98 M3/4/5
    toward the flywheel.. i had it backwards when i put the protruding end facing the trans... it was causing the disk to barely touch in neutral and the wheels to slowly spin...
    we got the trans back in last night, got all the way up to putting the guibo back on.. then realized i had about 1/2" space between the 3 drive shaft bolts and guibo??? i didnt know the shaft can collapse, i had changed positions on the quibo thinking that was it... after searching on here, it appears others have ran into that issue, strange.. working the next 5 days in a row, but i'll be on it when i get home tonight to finish that and re-button up the exhaust.
    S54 swap CSL
  23. #423
    May 2009
    Pittsburgh, PA
    That space isn’t an issue mine did it too. That lock nut on the middle splines is weaker. I usually get the giubo loosely bolted and pull the rear half to the diff by hand, then you can preload the CsB last
    and depending on what clutch you have the disk can face the trans with the protrusion. Mine does, so just triple check to always be sure what’s recommend.
  24. #424
    Tampa, FL
    97 E36M3 S54
    I think you just dropped a Moana quote? lol
  25. #425
    UT
    98 M3/4/5
    Quote Originally Posted by M52 POWER! View Post
    yes... yes i did.. gets in your head after a while, damn kids
    what clutch system do you have? I have the FX/F1 stage 2 carbon kevlar... uses a Sachs pressure plate.. from the added research ive done, with other people with the FX/F1 system, the protrusion needs to face the flywheel.
    S54 swap CSL
  1. S54 in euro M3 E36
    By ulmi in forum Engine Conversions
    Last Post: 08-16-2018, 11:08 AM
  2. First kill in s54 turbo e36 m3, orange challenger
    By PedraM5 in forum Kill Stories
    Last Post: 09-06-2013, 06:34 PM
  3. E36 Anyone interested in e36 m3 sways?
    By M3racer007 in forum Suspensions, Springs & Shocks
    Last Post: 07-03-2012, 12:30 PM
  4. How do I angle my HIDs in e36 m3
    By ayoDMO in forum Lighting sponsored by BAVToys
    Last Post: 12-10-2010, 03:41 PM
  5. S54 in E36 M3 works!!!
    By carcrazed4life in forum 1992 - 1999 M3 (E36)
    Last Post: 07-08-2003, 01:22 PM
