Page 7 of 18 FirstFirst 1234567891011121314151617 ... LastLast
Results 151 to 175 of 436
Thread: S54 in E36 M3, my turn
  1. #151
    UT
    98 M3/4/5
    lol i think so, need to mount it then start to rewrap it, was going to wrap it before i put it on the car then thought better of it because i dont know what needs to be where and how long.. also opened up Andrews swap harness laid that out.. i see there is a connector that needs to be replaced, where do i source that at ?
    98 Estoril ///M3 4/5
    S54 swap
  2. #152
    May 2009
    Pittsburgh, PA
    S54/E36,18 Sierra Denali
    Quote Originally Posted by TH3 Shifty View Post
    You talking about the blue plug on the Z3m harness? You get the black one from the E46M engine harness and splice it. In my thread on page two or three I covered it.
    As for wiring I hear you haha I have 4 "separate" harnesses all wrapped together.
  3. #153
    UT
    98 M3/4/5
    oh ok cool ill check your thread...
    S54 swap
  4. #154
    UT
    98 M3/4/5
    Quote Originally Posted by illadlephia View Post
    So you're running an e46 section 1&2 mated to an e36 muffler section? Just beginning an s54 e36 swap myself. I'm sure you'll be hearing from me often!
    yeah typically the section 1 & 2 will physically bolt in, then you need to modify the rear muffler section (3) from your E36. Im lengthening the section 1 due to the Euro cats by about 8-9" longer, so i took out the center section of the section 2.. which is really just a perforated, joined muffler with no cross over section but hollow to the other side, like another H pipe but slightly silenced. I like my exhaust to rumble and ive read numerous posts from tuners that a mostly separate dual system is the best on the S54. So i'll see how this sounds.
    Im going to use my Stromung rear section, (modified) and see what its like.. still quite a few weeks away from starting the car but im working on everything a little bit at a time. I basically get about 2-3 hours a week to work on it.. which blows goats.. then on top of that i make the Valve spring tool for the M50/S52 guys, which eats up my time but pays for the swap..
    S54 swap
  5. #155
    UT
    98 M3/4/5
    update: since i havent done it in a while. lately ive been so involved with making the valve spring tools for the S50/52 guys that i havent had time to work on my car.
    So up to today, i laid out the swap harness, drilled a 1 1/4" hole where the old throttle cable went, pushed the plug for the new accelerator to go to.
    Found the correct size vacuum line for the fuel rail to the fuel pressure reg.
    Finished welding the section 1 cats in place,
    Found a box that had the bimmerworld Euro overflow conversion kit that i bought a year ago, has the correct mounting flanges to mount the tank, kick ass!
    Mounted the power steering resevoir
    Finished the shifter referbish (new rubber seal, grommet for the arm, bushings ect)
    Mounted the trans cross brace and got the trans off the jack
    I also did the restructuring of the trans harness to remove the SMG parts thanks and big help from PITT M3 RR who has helped me out a ton with this project.
    whats left?
    I need to mount the trans harness, the swap harness, put some oil in, put some power steering fluid in, and i should be good to start it..
    S54 swap
  6. #156
    Tampa, FL
    97 E36M3 S54
    Nice updates! Man I've been trying to source the euro expansion tank mount parts and its nearly impossible so I'm probably going to just make some custom aluminum brackets to hold it...
  7. #157
    UT
    98 M3/4/5
    Yeah mine came in th bimmerworld conversion kit that they used to sell. BOught it last year before I knew I was going to do a swap. I didn’t really notice that they included both brackets for the tank
    S54 swap
  8. #158
    UT
    98 M3/4/5
    OK SERIOUSLY...
    how is the living hell are you guys mounting the freaking Oil dipstick!?!?!?! this mother F-ker is NOT going in with the damn E36 M3 power steering reservoir sitting in the way. Ive tried both the E46 M3 dipstick and the Z3 S54 dipstick.. the Z3 seems to fit better, has a slight different bend.. no way in hell is the E46 M3 one going in...
    am i mounting the reservoir wrong? i am also using the stock E36 M3 motor arms... i mounted the reservoir on top of the arm, but i need more room.. is there a smaller reservoir to use? this shit is pissing me off ..
    S54 swap
  9. #159
    Jul 2003
    Texas
    1997 M3/4/A
    i have the same issue, i gave up. i swiveled the oil reservoir bracket away just enough to install the dipstick and tighten the one bolt down. i know its ghetto but that is the only way i could get the dipstick on
  10. #160
    UT
    98 M3/4/5
    looks like i just figured it out....
    there are 2 different part numbers for the reservoir bracket for E46 M3 and E36 M3
    For the E36 M3, which is what im trying to use right now, the part number is 32411141655
    E46 m3 is
    32411092940
    , looking at both pics on ECStuning, looks like the E46 M3 one is a tiny bit shorter than the E36 M3.. this deffinately accounts for the lack of room i have when the tube hits the top of the reservoir
    S54 swap
  11. #161
    Jul 2003
    Texas
    1997 M3/4/A
    maybe, i tried to swap the brackets but it didnt help any. i do have a e46 m reservoir i can try to test fit to confirm before you order one
  12. #162
    UT
    98 M3/4/5
    reservoirs are the same... the brackets are different, forgot to put in the last post, the word BRACKET, not the reservoirs... the E36 M3 is taller.. the E46 M3 is shorter..
    S54 swap
  13. #163
    Jul 2003
    Texas
    1997 M3/4/A
    i also swapped the e46 m brackets, that didnt work either.
  14. #164
    Jan 2002
    North Augusta SC
    Quote Originally Posted by brokeazz View Post
    I believe that's what I did as well, along with bending the heck out of the dipstick tube.
    '95 M3 S54 Track Toy
    '12 X3 35i M-Sport
    '16 VW Golf R
  15. #165
    UT
    98 M3/4/5
    fock
    well the new bracket was $10 so i dont mind that cost to try it... if not ill just make new mounts out of metal tabs and push it towards the frame rail
    S54 swap
  16. #166
    UT
    98 M3/4/5
    Hey 2 things,
    #1. What size A/C belt are you guys using? I’m using the e36 compressor and the e36 mount/tensioner. The E36 belt is too small, so is the E46 since is used a different tensioner that can not be swapped to the e36 mount
    #2. I know this blue connector on Andrews harness needs to be changed to that black connector, well the problem is I no longer have the E36 engine harness, where can I source this connector?
    S54 swap
  17. #167
    May 2009
    Pittsburgh, PA
    You can get a molex connector at radio shack and cut off the connectors from each harness then use it in place. Any 2 pin will work. But the black connector comes the e46M harness, not the E36 one
    no a/c for me sorry
  18. #168
    Jul 2003
    Texas
    1997 M3/4/A
    im using a gates 5PK865, the width is a little smaller but it works
  19. #169
    UT
    98 M3/4/5
    Quote Originally Posted by PITT M3 RR View Post
    no a/c for me sorry
    Where is that on the e46M harness? I have the engine harness, looked over it last night but I did t find it at all???
    Awesome for that, thank you
    S54 swap
  20. #170
    Jul 2003
    Texas
    1997 M3/4/A
    i think its the black plug with 4 wires, but you are only gonna use 2
  21. #171
    UT
    98 M3/4/5
    shit... im so retarded... i think i saw that but dismissed it cause i was looking at the pic PITT M3 has on his thread where he already removed the other wires from it..
    S54 swap
  22. #172
    Jul 2003
    Texas
    1997 M3/4/A
    dont worry, he got me too hahahha
  23. #173
    May 2009
    Pittsburgh, PA
    Oops haha yea I cleaned it up by removing the unused wiring
  24. #174
    UT
    98 M3/4/5
    Update: pics to come, and ill fix the old pics as well since PB went full retard
    got my manual transmission harness from Turnermotorsports. i attempted to cut down my SMG harness but it was just a mess and became more bulky from my re-taping lol
    things i got finished:
    Cut down the power steering reservoir holder to allow dipstick to fit properly
    Mounted the A/C compressor and got a new belt that fit (thanks brokeazz)
    Changed the A/C tensioner
    Sent out the DME to TTFS for their tune
    Changed the vacuum tube from the air manifold to the FPR
    Mounted the VDO oil pressure sending unit to the frame rail
    things in the works:
    the euro overflow tank mounting
    installing the new trans harness
    routing the vacuum lines to the brake booster
    installing the S52 coolant temp sensor into the lower radiator hose
    setting up the power distribution block
    S54 swap
  25. #175
    Mar 2006
    Edmonton,CANADA
    1997 BMW M3 Coupe
    I noticed your keeping your 5speed, I am going to do so as well. Just preparing for my swap.
    Question for you, you mentioned you bought a manual transmission harness from turner because your current engine harness is smg. If my s54 came from a 6 speed manual do I need a extra harness for my 5 speed or is my s54 engine harness good to go. This wiring info Is a total overload.
    Also what lower hose do you have e36 or e46, just wondering how your mounting the sensor.
  1. S54 in euro M3 E36
    By ulmi in forum Engine Conversions
    Last Post: 08-16-2018, 11:08 AM
  2. First kill in s54 turbo e36 m3, orange challenger
    By PedraM5 in forum Kill Stories
    Last Post: 09-06-2013, 06:34 PM
  3. E36 Anyone interested in e36 m3 sways?
    By M3racer007 in forum Suspensions, Springs & Shocks
    Last Post: 07-03-2012, 12:30 PM
  4. How do I angle my HIDs in e36 m3
    By ayoDMO in forum Lighting sponsored by BAVToys
    Last Post: 12-10-2010, 03:41 PM
  5. S54 in E36 M3 works!!!
    By carcrazed4life in forum 1992 - 1999 M3 (E36)
    Last Post: 07-08-2003, 01:22 PM
