Page 4 of 32 FirstFirst 123456789101112131429 ... LastLast
Results 76 to 100 of 789
Thread: Blackknight530i 530i6 -> M5 Conversion Build Thread
  1. #76
    Jun 2003
    Raleigh NC
    03 M3T, 03 M5T/SC, 01 M5
    https://youtu.be/mnQ2ZXlfW6E
    Submitted via mobile device
    2003 Ferrari Red M3 3.5L wagon // 2011 Montego Blue tri-turbo 335d wagon
    2012 Deep Sea Blue X5d // 2003 Orient Blue 330i wagon
    In progress/For Sale: 2003 Alpine White M3/ZHP wagon // 2003 Japan Red M3/ZHP wagon
  2. #77
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    It's alive! Congrats guys.
  3. #78
    IL
    2000 740i sport
    Sounds mean!
  4. #79
    May 2015
    Atlanta, GA
    540i6 S2M5 M2C 135 S52ti
    Hell yeah!
  5. #80
    Mar 2012
    Virginia Beach, Virginia
    2001 BMW 540i
    Dude... You guys are beasts!!! What a project...I thought doing an M conversion on a 540 was difficult enough let alone on a 530....
    Quick question, are you going to de badge it and put "sleeper" in its place?
  6. #81
    Dec 2014
    Cave Creek, Arizona
    2008 E90 335i
    Nice.
    E90 335i
    On3 Performance top mount single turbo kit, Precision 6466 Turbo, ECS Tuning charge pipe, 7in FMIC, JB4 w/ MHD backend flash, Stage 3 fuel pump, Port injection, E85, some wheels that came w the car but are thick
    E39 540i (SOLD)
    6 spd swap, "Almost Nardo" Vinyl Wrap, JB Racing LTW flywheel, M5 clutch & control, BC
    Racing
    coilovers, cat back straight pipe, E60 SSK, ZHP shift knob, hard wired aux, Style 32 17", BFG G-force Sport Comp-2 tires, shadow-line trim, reenforced differential bushing, ATE Type 200, Hawk HP Plus pads, intake res delete, 10W40 M1, trans fill 50/50 Redline MT-90 & 75w90NS, solid shifter carrier bushing, pixel fix, red needles
  7. #82
    Jul 2013
    Ontario, Canada
    1998 528i; 2000 540i;
    That little grin over the side of the A pillar says it all.
    gmak: The Good, the Bad, and the Ugly. A journey with my new-to-me 2000 540i
    "Working on a BMW E39 is the best way to run out of time."
  8. #83
    Raleigh, NC
    SR-71 Blackbird
  9. #84
    Philadelphia, PA
    2005 M3 & 2004 330i
    Quote Originally Posted by blackknight530i View Post
    A lot of the wiring is the same as the 540i->M5 stuff, but since the 530i didn't have a starter relay, I noticed that the starter signal goes straight from the EWS to the starter, so I shouldn't have to do anything special for that.
    I remember seeing in the wiring diagram that the S62 cars *do* have a start relay despite apparently not having auto start. I guess it works fine without that (you're basically wired as if an MSS54 right now).
  10. #85
    VA
    E63AMG/Z31/Tacoma/F31
    Awesome!!
  11. #86
    May 2010
    USA
    08 535xit
    : i miss all of the good stuff.
    that is an amazing amount of work you all have done!
    G~
    E61 Mods: Trailer Hitch/wiring, Cargo cover roller fix, Backup camera, H&R springs, ER charge Pipe, Mishimoto catch can, boost gauge, intake scoop, JB+, CSR Rear Spoiler, Full SAT retrofit.
    Coded: legal disclaimer removal in iDrive, auto folding mirrors on lock, turn signals in HUD, fan speed indicator on when in auto, Doors unlock when key removed
    E39 Mods: Euro dash conversion, Dinan exhaust, Dinan suspension with Camber kit, 2.81 differential, flappy paddle with double pull M mode activation/deactivation, backup camera, Video playback on Nav computer (iPod Video for video storage and playback), stereo video playback through DSP, MKIV computer, RPA Tire Pressure retrofit, Intravee II iPod integration, Euro armrest, HUD, Parrot BT, voice recognition module, trailer hitch/wiring, rear mounted 10" subwoofer with amplifier, lighted interior door handles, Evans coolant.
  12. #87
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    Just got the car over to BPC in Raleigh for an alignment and hopefully AC recharge and possibly exhaust mating
    Sent from my SM-N910V using Tapatalk
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
  13. #88
    Raleigh, NC
    SR-71 Blackbird
    "Exhaust mating," I like that.
  14. #89
    Nov 2010
    Charlotte, NC
    My "M5" is trying to get its inspiration from a F10 M5 getting it's block sleeved for more power.
    -Paul
  15. #90
    Nov 2010
    Charlotte, NC
    Just got back from getting the 530i rear section of the exhaust welded to the 540i cats I had on the 7 before and got an alignment. It isn't an ideal setup, but it will get me by for now until I get the m5 bumper on and get a proper dual exhaust done. That will require trunk floor modding, so it can wait until funds recover a bit.
    Alignment is in spec, but only barely because we didn't get the steering column aligned to the steering wheel properly. At least it tracks straight and doesn't drone in the cabin.
    -Paul
  16. #91
    Feb 2016
    Destin, FL
    W220 S55 AMG, E39 540i6
    Just got back from getting the 530i rear section of the exhaust welded to the 540i cats I had on the 7 before and got an alignment. It isn't an ideal setup, but it will get me by for now until I get the m5 bumper on and get a proper dual exhaust done. That will require trunk floor modding, so it can wait until funds recover a bit. Alignment is in spec, but only barely because we didn't get the steering column aligned to the steering wheel properly. At least it tracks straight and doesn't drone in the cabin. Sent from my SM-N910V using Tapatalk
    So, how's it drive!?!?
    Chris
    04 Mercedes S55 AMG
    97 BMW 540i6
  17. #92
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Are you planning to keep the spare tire well, or are you going to transplant an M5 trunk floor pan? Whenever I get around to doing a full dual exhaust on my 540i touring, I want to keep the spare tire well, so I'll beat it with a hammer just enough to fit the second exhaust pipe. I plan to run muffler-less, so that should minimize how much space I'll need.
    1995 525i 5-speed - Thread
  18. #93
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by cnsorial View Post
    It drives great. The handling is amazing with the eibach bars and M5 steering box, but I don't have servotronic hooked up yet, so it's very stiff steering. It feels like I'm running super wide tires up front, but I'm only running 255s.
    I still haven't swapped the fuel pressure regulator and pump yet, so no big WOT driving yet. Hopefully going to finish it tonight.
    -Paul
  19. #94
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by dannyzabolotny View Post
    Check out Redshift's build thread to see how to modify the floor properly for a dual exhaust. His was kind of pricey, but they basically welded a 4" diesel exhaust pipe section above the exhaust pipe. Then they undercoated and painted it.
    I plan to cut the floor in a similar way, but the touring has a deeper floor, which has more space to still fit the spare wheel, while the sedan might not. I really doubt I'll be swapping out the trunk floor from a M5 though. That's a lot of work and I don't weld.
    -Paul
  20. #95
    Mar 2012
    2001 BMW 540i
    I wonder if you can just cut out a section of the spare tire well and turn it upside down...if you cut it equal that is...it's what I planned on trying when I do dual exhaust
  21. #96
    Raleigh, NC
    SR-71 Blackbird
    Are you saying you'll have to redo the steering column again?? If true .... AWW HHELLLLL NAAWWWW!!!!!!
  22. #97
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by auaq View Post
    Just the part under the steering wheel. Not a big deal.
    -Paul
  23. #98
    Nov 2010
    Charlotte, NC
    Last night, I drove it from Raleigh to Charlotte to get it back home and it drove perfectly, with no weirdness or issues. I kept it around the speed limit and listened and smelled for any strange odors or sounds, but it was fine. I'll just say, there is no CEL, no DSC error, no brake warnings, no ill messages at all, except for the right turn signal light I forgot to reconnect when putting the headlight back in and now the connector is stuck. I'll get that fixed shortly. I also have a strange buzzing coming from the glove box area, but I think it's how I wired up the ebox fan. I admit I hadn't really thought it through that well, but since the 530i has a 3 wire ebox fan with a temp sensor in the ebox, I cut one of the locking tabs on the 2 wire plug on the M5 harness and just plugged it in how it would fit. I'm guessing that it's the issue, so I'm hoping to get a M5 fan from Adam shortly. We also stripped one of the axle bolts when torquing them down, so I need another one and the subframe bolts we expected to use to bolt it to the body weren't correct, so I'm also getting a full set of new bolts. The ones we put in work fine and were properly torqued, but just for safety sake, I'll swap them for the correct ones. I also need to get the AC recharged, which will hopefully happen in the next day or two, because it's still super hot and humid here.
    So far so good guys!
    -Paul
  24. #99
    Raleigh, NC
    SR-71 Blackbird
    Wish I was around to help you guys finish up the last few stuff, take a ride, drive, burnouts, donuts, getaway chase, street racing, going sideways, ..... you know how I like to roll.
  25. #100
    Nov 2010
    Charlotte, NC
    Us too man! No crazy driving until I get the fuel stuff done. Don't want to run it lean and destroy the motor.
    -Paul
  1. Blackknight530i’s 530i6 6-speed swap build thread
    By blackknight530i in forum 1996 - 2003 (E39)
    Last Post: 09-06-2023, 12:07 PM
  2. Replies: 63
    Last Post: 06-01-2017, 10:27 AM
  3. Replies: 3
    Last Post: 01-01-2013, 10:57 PM
  4. Topaz540i's M5 diff conversion build thread
    By topaz540i in forum 1996 - 2003 (E39)
    Last Post: 01-01-2013, 09:52 PM
  5. Arnold's Tranny Conversion Build Thread...
    By Jo@EuroDyne in forum 1996 - 2003 (E39)
    Last Post: 02-10-2010, 06:06 PM
