Page 31 of 32 FirstFirst ... 6212223242526272829303132 LastLast
Results 751 to 775 of 789
Thread: Blackknight530i 530i6 -> M5 Conversion Build Thread
  1. #751
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    Quote Originally Posted by sooch View Post
    Very nice find! Where will updates for the coupe be posted? I enjoy following all of your stuff!
    Are you going to repair the subframe/bulletproof it back there? I don't think the 325/328/330 are immune to that.....
    Not sure yet. Probably in the e46 section on here (though I've never posted there before). I don't really frequent e46fanatics and I think that's really a different crowd than what I'm in, LOL. Any suggestions, I'm all ears.
    I plan to do the subframe reinforcement when I do the M3 rear end. Not sure yet when that will be, but most of the tearing that happens occurs on M3s due to the increased power. I plan on doing it just as a precaution since it will be on track a decent bit anyways. I'll be doing front suspension soon. I got new ZHP control arms, lollipops, sway bar endlinks so far. I've also ordered motor mounts and transmission mounts and a shifter rebuild kit. I will also want to do a shifter detent rebuild and maybe a clutch before the spring HPDE, but that of course requires pulling the transmission and I would like to do that once I get a lift put in my garage. Still working towards getting that done, so trying to manage funds a bit. Hoping to sell the 540it soon so I can cover some of that. It's going to be a fun car.
    Oh, and I'm debating getting some track tires from discount tire direct on Ebay since they're doing a $100 off $400 with coupon code PTIRES18. Bridgestone RE71Rs in staggered 17" sizes are only $566 after the coupon is applied. Again, hard to spend that kind of money right off the bat. Only have until 10/28 though, so need to decide soon.
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
    2006 Porsche Cayman S - Soul Performance Competition Headers and Exhaust, H&R Coilovers, 718 Boxster Spyder wheels, Rennline 35mm rear spacers
  2. #752
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    LOL. Yeah, E46Fans is... not real 'pro' crowd generally. But if you want some advice on comparing your ultrablue angel eye options... I used to post a bit there but rapidly reduced my activities to here and M3forums...
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  3. #753
    Philadelphia, PA
    2005 M3 & 2004 330i
    Quote Originally Posted by blackknight530i View Post
    If you can exchange them, Z4M control arm bushings are a pretty nice plug and play upgrade for E46 non-Ms. Offset and solid rubber instead of fluid filled.
    Even though your car is not a ZHP, ZHPMafia is a decent forum for non-M stuff. Not very active nowadays though due to the small userbase.
  4. #754
    IL
    2000 740i sport
    Nope, it's keeping the M54B30 and might get a 6 speed. Will eventually get a M3 rear end. Other than that, probably stay mostly stock other than track pads and maybe some safety equipment. Oh, and coilovers, sway bars, etc.
    Sent from my SM-G965U using Tapatalk
    You say that now but I foresee a serious motor swap...
    Sent from my SM-N960U using Tapatalk
  5. #755
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by TerraPhantm View Post
    Hmm, good to know on the control arm bushings. I'll see about exchanging them. I bought them on FCP, so don't see a problem doing that.
    I actually tried to join ZHPMafia a while back as a vendor and they were going to charge a pretty high price, so I passed, but I would consider signing up again now that I have an e46. Thanks!
    -Paul
  6. #756
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by purplecty View Post
    I would say that unless the M54 dies, I don't see much need for swapping. Supercharger one day, maybe.
    -Paul
  7. #757
    Nov 2010
    Charlotte, NC
    Terraphantm, are these the bushings you are referring to?
    https://www.fcpeuro.com/products/bmw...z4-31107838575
    -Paul
  8. #758
    Philadelphia, PA
    2005 M3 & 2004 330i
    Those are the ones - can be pressed into your existing lollipops. Alternatively you can buy them pre-pressed into new lollipops. https://www.fcpeuro.com/products/bmw...z4-31107836862 and https://www.fcpeuro.com/products/bmw...z4-31107836863
  9. #759
    Nov 2010
    Charlotte, NC
    Yeah, I saw those with the lollipops, but that's a significant price increase. I have a press, I can swap them easy enough.
    -Paul
  10. #760
    Philadelphia, PA
    2005 M3 & 2004 330i
    Yep, should be fine if you have your own press. The bracket has an ID of 66mm regardless, so it'll fit. Just make sure you line them up properly (arrow pointing towards the bump)
  11. #761
    Nov 2010
    Charlotte, NC
    Cool. Thanks!
    -Paul
  12. #762
    Nov 2010
    Charlotte, NC
    Hey guys,
    I finally got the GoPro videos from my last 2 sessions at VIR. These were my first solo sessions in B group and I think they went pretty well.
    Also, in other news, I did a bunch of work on the 330Ci today. We changed the front control arms and bushings with ZHP parts, sway bar endlinks, motor mounts, the thermal oil level sensor, and did an oil change. It was a long day, but after the test drive, it was well worth it as the car drives so much better. The control arm bushings were totally shot and one of the ball joints was as well. No more clunks when coming to a stop and no more shaking under braking.
    Also, I am thinking about putting a build thread for the 330Ci in the OT section in here. I've seen others do that, so look for it soon.
    -Paul
  13. #763
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Link it here when you do!
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
  14. #764
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by computiNATEor View Post
    https://www.bimmerforums.com/forum/s...rack-Car-Build
    -Paul
  15. #765
    CT
    E28, E32, E39, E53, E90
    The car looks amazing! Where did you get the steering wheel done?
  16. #766
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by rbelton View Post
    FCP Euro brand new BMW M5 wheel.
    -Paul
  17. #767
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    VIR looks like a blast! Looking good Paul!
  18. #768
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Ditto, subscribed.
  19. #769
    Nov 2010
    Charlotte, NC
    Thanks Chris and Jim!
    -Paul
  20. #770
    Nov 2010
    Charlotte, NC
    Hey guys,
    Haven't done much on the M5 lately, but this afternoon, I did finally put some finishing touches on the outside cosmetics:
    It's subtle, but now, at least it looks complete on the outside.
    -Paul
  21. #771
    IL
    2000 740i sport
    Hey guys,
    Looks awesome! It's the little things and attention to detail that really matter...
  22. #772
    Nov 2010
    Charlotte, NC
    Agreed.
    -Paul
  23. #773
    Oct 2014
    Bellevue, Wa
    02 M62 Dinan 5 (SLOW)
    I’m surprised you still are finding things left to do on that car still. I can’t imagine anything being untouched. Did you spend much time on track this summer?
    Btw I’ll pm you, I have a couple seattle guys who need cluster work if you’re up for it
    ------------------------------------------------------------------------Like the late Bill Paxton says repeatedly in Twister "I'm Not Back"---------------------------------------------------------------------------------------------------------
  24. #774
    Nov 2010
    Charlotte, NC
    Quote Originally Posted by 1gr8e39 View Post
    Hey man! Long time!
    Yeah, a few things here and there, but not much. I only did the fall VIR HPDE this year, but doing an autocross at the BMW performance center at the end of the month.
    After the autocross, I'll be changing out my springs for the softer ones I got from Ground Control. After that, it's basically just maintaining it.
    Sure, send them my way
    -Paul
  25. #775
    Nov 2010
    Charlotte, NC
    Hello everyone! Been a long time since I've updated the thread on my "M5", but not a whole lot has changed on the car since the last one. I've done several track events with the car since, although only one during the pandemic in 2021 at Road Atlanta. The car has been doing great and I've really just been maintaining it. Regular oil changes with oil analysis have shown the engine is still quite healthy at about 88k miles. The chassis has now reached over 242k miles and is still holding up well. Probably due for another suspension refresh in the near future, but mostly just the rear.
    What I have done was to get rid of the UUC Evo3 shifter and DSSR in favor of the stock rod with e60 shifter and I'm so much happier for it. I used to have quite a bit of slop in the shifter and I always thought it couldn't be the UUC with the bearings and DSSR and such, but since switching to the e60, it feels so much better. Go figure.
    I've also done the subframe bushings in the rear, which not in horrible shape, but definitely got rid of a shimmy I had in the rear forever.
    The last thing that I've done recently is to finally upgrade the brakes to something serious and hopefully much better on the track. I first did the e65 brake master cylinder upgrade and finally got around to changing the mid-lines in the engine bay with new stainless lines. And just recently, I decided to purchase the Epytec brake caliper adapters for front and rear Brembos for the E39. Sreten at M539Restorations helped me out a ton by buying them for me and shipping them from Germany as they apparently won't ship to the US due to some insurance liability or whatnot. Sreten is an awesome guy and I can't thank him enough. His videos are amazing if you haven't seen them. The adapters I got were for AMG C63S front 6 piston calipers and Porsche Panamera 4 piston rear calipers. The fronts use e60 M5 front rotors and the rears use e60 M5 rear rotors. The rotors are a bit pricey, but all in, I'm at about $3k for both axles with rotors and pads. So far, I've only installed the fronts as I wanted them for going to the Vintage this weekend, but after, I'll be repainting front and rears and putting new Brembo decals on.
    Here's a sneak peek:
    I also got a set of e38 M-Pars that will be going on once I get them refinished and some front PS4Ss mounted.
    That's it for now. I'll try to update as those things happen.
    -Paul
  1. Blackknight530i’s 530i6 6-speed swap build thread
    By blackknight530i in forum 1996 - 2003 (E39)
    Last Post: 09-06-2023, 12:07 PM
  2. Replies: 63
    Last Post: 06-01-2017, 10:27 AM
  3. Replies: 3
    Last Post: 01-01-2013, 10:57 PM
  4. Topaz540i's M5 diff conversion build thread
    By topaz540i in forum 1996 - 2003 (E39)
    Last Post: 01-01-2013, 09:52 PM
  5. Arnold's Tranny Conversion Build Thread...
    By Jo@EuroDyne in forum 1996 - 2003 (E39)
    Last Post: 02-10-2010, 06:06 PM
