Page 4 of 25 FirstFirst 1234567891011121314 ... LastLast
Results 76 to 100 of 620
Thread: What did you buy your Z3 this week? v3.0...........
  1. #76
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
    Quote Originally Posted by dennisljacob View Post
    Thanks, you've been very helpful. I've read that e46 M cars without cats, have a rather stinky exhaust smell. Is it the same for e36 M cars? That would be something I'd need to consider when planning for exhaust systems. Especially in a roadster when you get to smell everything. Dennis
    It smells awful on pretty much every car without cats, except maybe electric cars and hydrogen cell cars for obvious reasons. On these cars, you also get staining on the rear bumper.
    For mine, I got something similar to this randomly selected dual 2" in, 2.5" out cat to replace the OEM units when I got some cheap ebay headers.
    Bought 2 front strut mounts, 2 rear shock mounts, the stupid gaskets, lock nuts for the struts, the brake switch, some wheels, tires for the wheels, and some other stupid trash.
    I still have a long laundry list of stuff to do, like replace the top, fix the glovebox, fix the tabs for the glovebox on the dash, reinstall the wood trim on the upper center console bezel, use butyl rope to secure the trim piece over the I/C that apparently wasn't affixed the way Ford clips those parts on and I was stupid to think it would look like that, actually fasten down the door trim panel on the passenger side door, adjust the CSB preload, pull the diff cover and check backlash etc, replace all the transmission fluid with Dexron VI (Dex VI is backwards compatible with all automatic GM transmissions that use Dex III as long as they are made by GM; other applications using Dex III are SOL), replace the center brake hoses, replace the front lower ctrl arms, replace the flc-arm bushes again, replace rear subframe bushes and rtabs, do all 4 corners brakes, rebuild calipers, and by then I should be all good unless the obnoxious noises in the drivetrain involve rebuilding the diff or 4L30E because life is too hard.
  2. #77
    Jun 2005
    Chicagloland
    99 Estoril Blue M Coupe
    Hood roundel
    Before/after
    https://instagram.com/p/BQ4Bn06lwfg/
  3. #78
    Jul 2016
    Texas
    '98 M Roadster
    It's not this week, but since I purchased the M Roadster in July year I've done:
    - Rear Koni Sport shocks and mount hardware
    - Ireland RSF mounts
    - Lamin-X for headlights
    - HIR High and Low beam lamps
    - Panavise Dash mount for phone
    - Various interior trim bits
    - 3rd brake light housing, bulbs, sockets and seal
    - Trunk gasket
    - ZHP Shift Knob
    - Roadster Rear Window Cover
    - 20 to 16 Pin OBD2 Adapter Cable
    - Hood and trunk strut
    - Spark Plugs
    - Roadster Solutions Z3 Wind Blocker
    Jim
    1998 ///M Roadster
    2007 Audi RS4
    2016 Audi S4
  4. #79
    Dec 2015
    Talmage, CA
    '99 Z3 Coupe, 2016 R3
    Coco Mats! I blame my subscription to Hemmings Sports&Exotic Car.
  5. #80
    May 2014
    council bluffs, Ia
    97 Z3 90 Porsche S2
    OK I had to mention this. I did say that I got a new shifter. I didnt think it would make such a difference but it sure does. If yours is loose or sloppy spend the $84 plus it's shorter.
  6. #81
    Aug 2009
    Rochester Hills MI
    98 M Rdstr
    I bought yet ANOTHER Saab wagon. That makes for three in the household. It is another car which makes the Roadster stay nice.
    '98 RMS stage 2+++++(VAC cams, CES Cutring-9:1, Built blower, FlexFuel etc)
    '20 Cadillac CT4 2.7T AWD (wife's)
    '09 Saab 9-5 Combi 5mt 1 of 1(Built Motor, Brembos, LSD, the works!)
    '10 Saab 9-3x
  7. #82
    Aug 2014
    Canada
    1996 BMW Z3 1.9 Hellrot
    Brand new (Not painted) set of aero side grills
  8. #83
    Jul 2015
    Shoreline Wa
    M Coupe, A4 Avant , MGB
    Rebuilding my calipers... just got em back from the powdercoater. Had the carriers done too.
    I filed the seam/flashing off the front of both to tidy them up a bit
  9. #84
    Quote Originally Posted by caglar View Post
    I'm a bit jealous. I see this for sale from time to time but never at a price I'm comfortable with jumping on. I can also never find enough pictures of them installed to even know if I really like em... get em on and get some pics
    Quote Originally Posted by Ring Rat View Post
    Looking good. I like the choice to go with a clean gray color - certainly better than black or OEM without standing out too much since they are OEM brakes. Have you considered painting the "M" before throwing them on?
  10. #85
    Jul 2015
    Shoreline Wa
    Thanks... Thats exactly my thoughts on the color. Still nice but doesnt stand out too much. Trying to decide what color to do the ///M logo... white, black, or silver... or perhaps lighter grey. Got a few days before the rebuild part arrive to decide.
  11. #86
    Jul 2015
    Shoreline Wa
    Ended up doing just subtle black
  13. #88
    Indianapolis
    F30 328d X-Drive
    I bought this,
    https://thayermotorsports.com/collec...nt=28395299655
    and these
    https://thayermotorsports.com/collec...vice-tools-new
    also a new clutch and flywheel since I have no idea when mine was last changed and the car has over 160k miles on it. So might as well swap those while I have the trans out.
    I also have a new slave cylinder, motor mounts, trans mounts, shifter bushings, oil pan gasket, Oil filter housing gasket, and fluids for all those corresponding items.
  14. #89
    Jun 2005
    @6500RPM Las Vegas
    Z3 5-Speed Roadster '00
    Quote Originally Posted by Venom13132 View Post
    I bought this,
    and these
    The one last thing 'while your in there that deep' in the REAR MAIN SEAL, I would spend the $120 for it [ 11142247867 ].
    'Sweetness Too' M52, 2.5L Z3 5-Speed Roadster, 2000 Jet Black 148K Smiles Mine
    'Ol' Black Betty' S52, 3.2L ///M3 5-Speed Vert '98 Cosmos Black 232K Smiles Wifeys
    M50, 2.5L 525i E34 Tragi-matic '95 Sedan Alpine White III 238K Smiles Daughters
    'Gretchen' M30, 3.5L 535i E34 Tragi-matic '90 Sedan Glacier Blue/Indigo 144K Smiles 2018 Gone & I miss her
    'Sweetness' M44, 1.9L Z3 5-Speed Roadster '96 Boston Green 264K Smiles Was Mine Insurance Company Total in Jan 2013- Rear End Collision - Paid $4800 !!
  15. #90
    Feb 2004
    san diego
    ...it depands
    How did you paint the "M" so perfectly? It looks amazing!
    2011 328i E92 Space Gray Metallic / Leder Dakota+Oyster
    2003 330i Titanium Silver / Black
    2000 Z3 M Titanium Silver / Imola Red+Black Nappa
    2001 330cic Metallic Steel Gray / Gray
    2000 Z3 2.8 Topaz Blue Metallic / Beige
    1997 Z3 1.8 Atlanta Blue Metallic / Beige
    Since 1987 12 euros / 2 kdms / 2 jdms
    - Zach
  16. #91
    Jul 2015
    Shoreline Wa
    Thanks... Took a scan of the m logo on the caliper, traced in cad, scaled it, cut out on a vinyl cutter and used the vinyl as a reverse mask to paint with black laquer. I still have the file, I could cut a few more if anyone is interested, or send the file... pm if interested, I wouldnt charge so long as im not doing it for two dozen people
  17. #92
    Jun 2005
    @6500RPM Las Vegas
    Quote Originally Posted by ZUUD BYE View Post
    Ordered today for my 2000 Z3 2.5L M52TU
    Rack Doctor * |item 25460* | 1998-2002 BMW Z3 Rack And Pinion (except 3.2L engine) W/ return shipping & W/ Outer Tie Rod Ends
    Dr. Vanos item 40134 Dual Vanos [Z3 2.5i/2.8i/3.0i]
    Reman Power Steering Pump
    Valve Cover Gasket Set
    Oil Filter Housing Gasket
    Hope like hell to get it all installed the week of 3/06!!!
    Finished up the install today 2000 Z3 @ 145100 sMiles, replaced the Oil Filter Housing (wouldn't hold oil - drain overnight) and Secondary Chain Tensioner (I broke), plus oil change & new Belts and Spark Plugs went on.
    Sweet to have the VANOS working again and the Power Steering is buttery smooth, BIG kudos to Dr. Vanos and the Rack Doctor!
  18. #93
    Oct 2016
    Palmdale, CA
    1998 BMW Z3 2.8
    new clips for the slow windows
  19. #94
    Jun 2004
    Youngsville, Louisiana
    2001 M Coupe
    New sticky shoes!
    -Ed Hands
    MaxPSI Stg2 Turbo
    R.Forbes magic F&R
    100K Original owner miles.
    Proud member of the BF.c FI - Big Torque Club (>500wtq Dyno Results)
  20. #95
    Oakdale,CA
    z3 2.3 z3 3.0
    Like your maxjax set up with the pool noodle protectors. Any problems
    with the maxjax?
  21. #96
    Jan 2017
    Dallas, tx, USA
    2000 BMW z3
    Quote Originally Posted by E.Hands View Post
    New sticky shoes!
    Your new shoes are killing me! What sizes do you have FR+RR, and rim sizes?
  22. #97
    Jun 2004
    2001 M Coupe
    Quote Originally Posted by Z3X2 View Post
    with the maxjax?
    No problems, very happy with lift.
    Quote Originally Posted by Jay11 View Post
    255/40/17 and 315/35/17 on widened Roadstars. Grip is good!
    -Ed Hands
    MaxPSI Stg2 Turbo
    R.Forbes magic F&R
  23. #98
    Jan 2017
    Dallas, tx, USA
    2000 BMW z3
    Zimmermann Front Rotors set, steal a deal $35
    Thanx!
  24. #99
    Jan 2017
    orlando,fl
    2000 2.3l z3
    WOW those are some CRAZY rear tires....... Do they some with a Clorox tank to soften up the rubber at red lights ? :-)
    Ok - I bought a 25 dollar quart of Pentosin..... does that count ?
  25. #100
    TX
    97 M3/4/5, MCS
    Those 315's look amazing. Was there any rolling or modifications needed to fit them?
  1. What did you buy your Z3 this week? v2.0...........
    By Terry F. in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-19-2017, 10:50 PM
  2. What did you buy for your e36 M3 this week v2.0
    By MauiM3Mania in forum 1992 - 1999 M3 (E36)
    Last Post: 08-08-2014, 07:16 PM
  3. What did you buy your Z3 this week?
    By ZUUD BYE in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-07-2014, 04:40 PM
  4. What did you buy for your e36 M3 this week
    By hellrot98m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-26-2011, 02:50 PM
  5. So, what did you buy your bimmer for Christmas?
    By QuickSilv3r in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-17-2005, 02:11 PM
