Page 17 of 29 FirstFirst ... 789101112131415161718192021222324252627 ... LastLast
Results 401 to 425 of 724
Thread: What did you buy your Z3 this week? v3.0...........
  1. #401
    Tallahassee
    1998 Z3 M Roadster.
    Rear brake pads and discs.
    Plus a 3.0 Z3 clutch hose for my M Roadster to get over the CDV or restriction in the case of the M
  2. #402
    Feb 2017
    Suburbadelphia, PA
    1997 Z3 2.8 Roadster
    Control arm bushings, two tires, a fuel filter and six spark plugs.
    It was annual inspection time.
  3. #403
    Feb 2013
    Danville, IL
    1999 BMW M Roadster
    New reskinned seats (was going to buy genuine leather skins myself and do the work, but found a good deal on professionally skinned seats w/ same skins I was going to order), Federal 595RS-RR 235/35/19's & 275/35/19's, H&R Hubcentrics will be ordered once I get an idea on thickness needed, new top (went with twillfast ii) and associated parts, scrubbed-powered-vacuumed interior carpets and replacement trunk carpets I bought (along with various car care products as I claybarred, waxed, back to black etc), MTL & MT-90 w/ plugs n gasket for trans & rear diff fluid changes, replacement stereo head unit (some dumb*ss stole face plate only lol). Ah, and a fitted bmw car cover.
    Ordering new shift/ebrake boots (have new knob), trunk lifts, fluids for radiator flush, and hopefully M emblems, replacement key fob (they don't like the ocean), interior trim tidbits, floor mats pending budget.
  4. #404
    Tallahassee
    1998 Z3 M Roadster.
    Rear stopping gizmos for my 98 M
  5. #405
    Sep 2013
    North Texas
    2001 MCoupe
    Cheapo set of Federal RS-RRs to try as my track rain tires. Hard to find the Direzza StarSpecs now in the sizes needed.
    2001 Steel Gray MCoupe - 147,000 miles and owned since new. MCS 2WNR suspension, Hotchkiss swaybar, poly bushings all around, cat delete headers with custom tune, 3.73 LSD, and Clownshoe Motorsports rear subframe reinforcement.
    2014 Porsche Cayman S / 2022 BMW X3M Competition / 2020 Ram Rebel
  6. #406
    Sep 2018
    Oakland CA
    2000 BMW Z3 2.8L
    Got myself two Wiper modules as my wipers only work on high. Neither worked so went off the the salvage yard and bought two different wiper storks so I can test why the Da? thing doesn't work. As it is an April 2000 2.8 Z3 can't find anywhere a relay could be on the car. Also not sure if the Module is correct. Any help would be appreciated
  7. #407
    Feb 2016
    tempe, az
    1998 Z3M, 2006 330i
    Quote Originally Posted by chris.puli@asgn View Post
    My poor memory tells me that the problem is often in the motor itself. I read up on it a couple of years ago, when I bought the car, but my problem just went away. I then suspected it was sticky from non-use (I'm in AZ) Not much help I know, but you said "any help ..."
  8. #408
    Jan 2018
    Pomona
    ‘02 BMW M Coupe
    This week was a great week for purchasing stuff for the shu! Just don’t tell the wife. She may not be as enthusiastic about it all...
    I was able to get an OEM shift knob, A new defrost vent for the passenger side of the dash, the little m badges for the wheels, and a new m badge for the valve cover on the S54 motor!
  9. #409
    Aug 2015
    Denver, CO
    1999 Z3M, 1999 2.8 Coupe
    Set of (4) DSIIs for snow tires on the Coupe...all 17x7.5.
    Found (3) on Craigslist for $120, and shelled out $100 for the 4th on eBay.
    Nathan in Denver
  10. #410
    Sep 2017
    Northeast
    2001 M Roadster
    IE subframe bushings and RE SS clutch line
  11. #411
    Oct 2016
    Ambler, PA
    2000 BMW Z3 Coupe
    Just installed a new set of bavauto ignition coils since I was getting intermittent misfires in cylinders 1 and 3. Car felt much quicker afterward. Still have to figure out my lean fuel trim in banks 1 and 2 issue. Had car smoke tested, saw nothing, changed the maf sensor after seeing the old one was dead and it helped a little but the code is still there. Car dips and surges at idle when the engine is still cold, doubt the coils will fix that but we'll see in the morning lol
  12. #412
    Aug 2015
    Denver, CO
    Quote Originally Posted by ihm96 View Post
    Rebuild your VANOS.
    Nathan in Denver
  13. #413
    Oct 2016
    Ambler, PA
    2000 BMW Z3 Coupe
    Quote Originally Posted by s8ilver View Post
    Rebuild your VANOS.
    Thats something that I've been thinking it probably is, so I'll do that next. Unfortunately though, despite it running much better the misfire codes came back in 1 and 3. I'm thinking maybe swapping around fuel injectors or maybe cleaning them?
    You know who sells the best vanos rebuild kit?
  14. #414
    Aug 2017
    ...You know who sells the best vanos rebuild kit?
    http://www.beisansystems.com/products.html -> Double Vanos Seals Repair Kit (6-cyl)
    This should be the right instructions for your car: http://www.beisansystems.com/procedu..._procedure.htm
    He is the one that came up with the replacement seals first many years ago and did the engineering for better seals.
  15. #415
    Johnson City, TN
    2000 BMW Z3 Roadster 2.8
    Quote Originally Posted by me77 View Post
    The instructions leave one thing out. REPLACE the screws that hold the splined caps to the camshafts. It will save you the headache when you torque them to spec and they snap off. Ask me how I know
    Sent from my Life One X2 using Tapatalk
  16. #416
    Aug 2017
    I thought that 50 Nm is VERY tight for those caps. Didn't snap them off, but dried the threads as good as I could to make the torque wrench as accurate as possible. If the threads were full of oil, you probably overtightened them quite a bit.
  17. #417
    Jun 2016
    Odessa, TX
    2000 BMW Z3 2.8 Roadster
    A "new" interior trim cover for the driver's side A pillar and "new" sill covers for where the carpet meets the weatherstripping. I don't know why I bothered with the A-pillar trim, considering that I don't even have a dashboard.
  18. #418
    Oct 2016
    Ambler, PA
    2000 BMW Z3 Coupe
    Just ordered a vanos and valve cover kit, plus 02 and cam sensors. Hoping to finally get rid of my CEL and my idle dip/surge. Considering ordering a front strut bar. Between the Dinan, Garagistic, and Stron Strut, any of you guys have opinions on whats best?
  19. #419
    Aug 2015
    Denver, CO
    Dinan and Strong Strut are great quality (actually didn't know Garagistic made a Z3 brace), but I like the look of the SS best. If I already had some Dinan CF under the hood, I'd probably go that route. Hmm, think my Coupe needs a black SS...
    Nathan in Denver
  20. #420
    Oct 2016
    Ambler, PA
    2000 BMW Z3 Coupe
    I have a Dinan Chip and CAI but its also almost double the garagistic one, and that one looks pretty solid to me. I'm not sure what to do. About to do a ton of maintenance on the Z though, new motor mounts, trans mounts, flex disc, csb, vanos rebuild so I figure its a good time to get a strut bar as well. In the spring then I wanna do coils and refresh the rest of the front and rear supension and fix my saggy headliner, worn drivers seat, and shifter boot
  21. #421
    Jun 2005
    Chicagloland
    99 Estoril Blue M Coupe
    Was installing VF engineering kit. The instructions are pretty rough, I can’t believe after all these years they supply instruction for a m52 engine, not s52.
    Disconnected the ICV from manifold, immediately got stuck when I realized they gave me a threaded cap, but no tap to make the threads to plug the manifold with cap. So going for a tap tomorrow
  22. #422
    Dec 2013
    USA
    1999 BMW MZ3 Roadster
    I bought my M Roadster a baby brother recently.
  23. #423
    Nov 2009
    Herndon, VA
    99 z3 2.8L
    Replaced the original oil filter housing gasket, oil pressure sensor, oil temp sensor, and vanos feed line on my 99 2.8 (130k miles). The gasket leaked like mad and since I was in there I decided to do the other stuff as a preventive measure. The original gasket was pretty brittle. I cleaned out the alternator vent as well since that was clogged with leaves for who knows how long...
    Also installed koni sport shocks (new RSMs) and h&r springs.
    Front refresh (LCAs, tie rods, end links, and lollipop bushings) plus the koni sports with h&r struts (with front strut reinforcement plate and bav auto camber plates) coming in the next week or so when I find time.
  24. #424
    Nov 2009
    Herndon, VA
    99 z3 2.8L
    Finished the front suspension and front refresh plus an alignment. It drives a lot better than before.
    Planning on doing the RTABs and RSFBs and possibly hiring out the Subframe reinforcement welding later in the year.
    Meyle/Meyle HD refresh bits
    Koni Sports
    H&R Sports
    BavAuto Camber plates (about - 3* on all four corners)
  25. #425
    Oct 2016
    Ambler, PA
    2000 BMW Z3 Coupe
    Installed a condor tall weighted shifter this week, replaced both front wheel hubs. Next is condor subframe riser bushings. I'll be purchasing coilovers soon once I fix my E34
  1. What did you buy your Z3 this week? v2.0...........
    By Terry F. in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 02-19-2017, 09:50 PM
  2. What did you buy for your e36 M3 this week v2.0
    By MauiM3Mania in forum 1992 - 1999 M3 (E36)
    Last Post: 08-08-2014, 06:16 PM
  3. What did you buy your Z3 this week?
    By ZUUD BYE in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-07-2014, 03:40 PM
  4. What did you buy for your e36 M3 this week
    By hellrot98m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-26-2011, 01:50 PM
  5. So, what did you buy your bimmer for Christmas?
    By QuickSilv3r in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 12-17-2005, 01:11 PM
