Page 6 of 7 FirstFirst 1234567 LastLast
Results 126 to 150 of 161
Thread: E39 V8 Big Power SC / Turbo DeadPool Tracker
  1. #126
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Don't you think that by simply MENTIONING it in the same sentence with a single turbo swap on a 335i he has strongly implied everything he needs to? The two projects could barely be further apart in terms of difficulty.
  2. #127
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Quote Originally Posted by tptrsn View Post
    yer right, I'm probably being too demanding! allways a ballbustah that GG.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  3. #128
    DeWitt, Michigan
    Haha.. I about spit out my coffee when I saw those two projects mentioned together like that.
    Maybe he didn't really mean anything by it other than, "I found out that I like a nice turbo setup so much, I decided to bite the bullet and undertake the massivity (made up a word for this) of the turbo e39 540 with A/C project."
    I'm guessing an AZ boy ain't gonna want to be trashcan'ing the A/C, afterall. I'm so excited to see what ensues!
  4. #129
    Mar 2012
    Lansdale, Pa
    98 540 6, SC'ed, 16psi
    Lol at you guys!
  5. #130
    DeWitt, Michigan
    HOLY COW! Look what else the cat dragged back in (besides DK and me).
    You got any car guy adventures planned for 2019 Chris, or are you still waiting for someone to dethrone you and thereby light a fire under your azz?
    And by the way, Merry Christmas to everyone!! If you aren't into Christmas, then Happy Hanukkah! If you aren't into that either, then I don't know what to tell you other than f-off. Hahahahaha... I still crack me up.
  6. #131
    Mar 2012
    Lansdale, Pa
    Miss you too Thad! I am due for some suspension refreshing I guess. No play, but some boots are rotting away and I still need to change out a rear swing arm where the anti sway bar bracket busted off. My engine has been running great! We need some LRS updates!
  7. #132
    Dec 2014
    Cave Creek, Arizona
    2008 E90 335i
    Well, I'm obviously going to be hitting around 700whp cause that what my 335i can do and V8 is superior. I'm trashing the AC cause racecar. And I am going to be running a 6466 cause that what all the lsx guys do so its sick.
    Actually, I'm hoping that I can just get it to run stably within the next year and we will go from there. Probably going to use my old 5858 cause I have it and it works well. My buddy is going to be helping me with the manifold design since we go to asu and have access to all that fancy plotting and flow software. This is also gonna be the capstone project for my minor so really I can't lose as long as I learn stuff of the way to blowing out and losing cylinder 8.
    E90 335i
    On3 Performance top mount single turbo kit, Precision 6466 Turbo, ECS Tuning charge pipe, 7in FMIC, JB4 w/ MHD backend flash, Stage 3 fuel pump, Port injection, E85, some wheels that came w the car but are thick
    E39 540i (SOLD)
    6 spd swap, "Almost Nardo" Vinyl Wrap, JB Racing LTW flywheel, M5 clutch & control, BC
    Racing
    coilovers, cat back straight pipe, E60 SSK, ZHP shift knob, hard wired aux, Style 32 17", BFG G-force Sport Comp-2 tires, shadow-line trim, reenforced differential bushing, ATE Type 200, Hawk HP Plus pads, intake res delete, 10W40 M1, trans fill 50/50 Redline MT-90 & 75w90NS, solid shifter carrier bushing, pixel fix, red needles
  8. #133
    DeWitt, Michigan
    Quote Originally Posted by dk500 View Post
    Lol!
    Ok, but you can't seriously run a 300hp N/A engine through a single 5858. Maybe you mean you're going to run that, plus another one like it. That would be a sweet setup, albeit still kind of turbine limited.
    Are you actually planning to try to keep the A/C then? And do you have a plan for tuning yet? Or waiting to see what DME you end up with first?
  9. #134
    Dec 2014
    Cave Creek, Arizona
    2008 E90 335i
    Lol!
    Im waiting to see what I end up first, and then I will plan how it will all go once I can model flow and all of that with whatever I end up w with the tools available to me at ASU. For tuning though I am more than likely going to go standalone. I have a bunch of guys in Formula SAE that are gonna be helping me with the tuning side of the project and stand alone DMEs are what we are all experts in.
    E90 335i
    E39 540i (SOLD)
    Racing
  10. #135
    DeWitt, Michigan
    Looks like you got autocorrected a bit there or something, so I'm not positive I completely understand your meaning, but that all sounds good. Hopefully your braintrust can come up with something cool. I think this is the first nerd group entry into the deadpool.
  11. #136
    Mar 2017
    Lynchburg, VA
    2001 540i
    Never underestimate a group of engineering nerds. If it ain’t broke, it doesn’t have enough features!
    2001 Salvage Title 540i
    My build thread: https://www.bimmerforums.com/forum/s...toive-decision
  12. #137
    DeWitt, Michigan
  13. #138
    Nov 2011
    Greedland
    99 540i6, 02 X5, Tundra
    Quote Originally Posted by MisterM52 View Post
    Summers Comin... So is the Project! This Year...
    What project?
    E85 fueled, Eaton m112 supercharged 4.5L M62TU, TTV racing flywheel, Spec stage 2+ clutch, 88c thermostat, eibach sway bars, wavetrac 3.15 lsd, m5 steering box, Quantum 340lph fuel pump, Dinan camber plates, some powerflex bushings, Supersprint headers, M5 cats, 2001 gas pedal upgrade and many other things done. all diy by me
  14. #139
    Dec 2014
    Stuttgart, Germany
    One Too Many
    Sorry, Wrong Thread! Was Looking for the Deedpool
  15. #140
    Nov 2011
    Greedland
    I've never seen a Deedpool, I see you now in the deadpool, still dead, still no progress pics
  16. #141
    Dec 2014
    Stuttgart, Germany
    One Too Many
    Just wanted to give you guys a quick update, we are still on it but had no progress in a while, we intend to get it done by this year though. At least the prototype.
    This will be the same blower you see here on our current setups
    "So we've come to the conclusion that BMW just has parts laying around they decide to throw on cars for no reason."
    Interest on a Very Budget Supercharger Build??
  17. #142
    Dec 2014
    Cave Creek, Arizona
    2008 E90 335i
    Little deadpool update - nerd group has put the project on hold cause I'm getting sued over the dumbest thing ever. Will update progress when my lawyer finishes the job and I can reclaim costs from the other party cause almost all of my money for this project has disappeared cause of this.
    edit: you can be sued if someone slips on ice in your property, even if you don't know who they are and never told them they could try to break into your garage.
    E90 335i
    E39 540i (SOLD)
    Racing
  18. #143
    DeWitt, Michigan
    That is definitely one of the top 5 all time best posts in this thread!
    And here's hoping that the bastard has enough funds (or a job to wage garnish) for you to be able to recoup some penalties for a bringing a frivolous action. Have you counterclaimed for trespass or anything?
  19. #144
    Dec 2014
    Cave Creek, Arizona
    2008 E90 335i
    Yea, I have but I doubt they have remotely enough for me to reclaim costs. They have a lawyer doing their stuff pro bono so I doubt I will get anything more than maybe a few hundred right away. When I win my counterclaim I doubt I will get all the money until at least a few years after.
    E90 335i
    E39 540i (SOLD)
    Racing
  20. #145
    DeWitt, Michigan
  21. #146
    May 2014
    Hockinson Washington
    Two 2003 540i6 Msports
    That makes me angry for you!!! I friggin' hate that s**t.
    I do not believe in a risk free society where the thrill of living is traded for the safety of existence. Nick Ienatsch
    The law does NOT determine "right" from "wrong". They are unrelated.
    If you put cheap parts on your car, you will soon have a cheap parts car.
  22. #147
    Mar 2010
    Yeah. But the reality is actually "you can be sued for anything at anytime".
    Doesn't mean they are going to prevail, and in those "burglar sues cuz he hurt himself whilst burglaring" cases seldom do (despite the scare stories you read), but the sky is the limit on what some asshat can try to bring. Its a different story if you set traps or some crap like that, then you're eff'd. Booby traps are for sure a lawsuit goldmine for a burglar. But from what I understand he can only win if you were well aware that he was trespassing repeatedly and regularly, AND you were aware of the hazards, AND if the hazard was reasonable to believe the trespasser would run into. Like if the ice was on a path on your property and you knew people constantly take that path and ignored it... And even then, the counter-argument would be it was the trespassers duty to expect natural conditions in winter on an outdoor trail and they couldn't possibly not have been aware the hazard was there. It is stupid though, and unless there's some other bit you haven't mentioned he almost certainly won't prevail.
    But as you seem to have run up against... doesn't mean that some douche won't try it. Is his real angle actually to intimidate you into not pursuing the breakin-in charges via the fraudulent tort?
    #notalawyerjustinterestedinlaw
    2003 M3CicM6 TiAg
    Former:
  23. #148
    Mar 2017
    Lynchburg, VA
    2001 540i
    That’s the game though. My ridiculous lawsuit can be easily disproven to a degree that would shame Lionel Hutz, but it’s going to cost you $5k to do it. Or, for the low low price of $2k, you can get my attorney a little closer to hell and me enough money to meth out for 2 weeks, and we go away. I don’t have a solution, but this is definitely one of my top “the world is going down the toilet” old man rant inducing rage topics.
  24. #149
    DeWitt, Michigan
    Bingo.
    Quote Originally Posted by douglawrence42 View Post
    And BINGO! Some slimy sorts squirm through life on settlement value from frivolous lawsuits because they are unrecoverable on counterclaims, and insurance companies just pay out to get things concluded at the lowest possible cost. And the cries of "I gots me a lawsuit!" are heard across the land. Lol
  25. #150
    Mar 2012
    Lansdale, Pa
    ^All that makes me sick. I hate that subset of our human race. Gimme gimme gimme... cut their balls off already.
  1. Bolt-On Top Mount S366 Turbo Kit (E85, Stock Compression, Big Power) - No Longer Available
    By Doesnt Matter in forum Forced & Chemical Induction Parts
    Last Post: 04-01-2016, 07:49 PM
  2. Replies: 27
    Last Post: 01-19-2014, 02:58 PM
  3. Remote/ Mid mounted turbo kit for e39 v8's?
    By joba356 in forum 1996 - 2003 (E39)
    Last Post: 08-21-2011, 09:19 PM
  4. GT42R Turbo, looking for big power?
    By JBgotM in forum Race Cars & Track Parts
    Last Post: 12-05-2007, 10:52 AM
  5. Engine mods for max power/ no turbo or SC
    By habs35 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-06-2005, 10:42 AM
