Results 1 to 25 of 34
Thread: Dilemma / Advice
    Oct 2008
    So. Cal
    95 525, 92 525, 84 528
    Dilemma / Advice
    So I posted a thread earlier on possible hydro lock, which I misunderstood what happens in that scenario. I basically started losing coolant, with no visible external leaks. I did find a little seepage at the hose connections, then eventually my radiator took a crap. All of my cooling system problems have now been addressed. (New radiator, thermostat housing, hoses, and fan clutch) I thought I was getting excessive pressure at the coolant hoses, causing these problems, but its been a couple weeks with no leaks. I'm still losing coolant though, as I need to add coolant every couple of days. There is no coolant at my dipstick, and no oil in my coolant. I did find some milky residue on my oil cap though. I'm not overheating, nor blowing smoke.
    My engine now has 294k on the clock, and I did do a headgasket job almost 100k ago, when my head developed a crack and the head was fixed. My wife overheated the car about 4 or 5 months ago, when one of my TB coolant hoses took a shit. My last smog check, I barely passed, and the technician said I am burning oil. So, I'm thinking engine overhaul, or maybe engine swap? The car has alot of good things going for it, recent front end overhaul, lifetime warranty on tranny (Aamco). I'm open to any advice, as I'm thinking of picking up another e34 to drive, while I take my time addressing this car's issues. I also have an 84' 528e for use.
    Airplanes & Hotel Rooms
    E34 M5T
    Time to swap in a new(er) motor. Given the mileage and issues if you want to keep the car this might be the easiest and most cost effective route.
    Oct 2008
    So. Cal
    Quote Originally Posted by stilljester View Post
    Should I stick with an M50, or maybe M52?
    Oct 2008
    So. Cal
    Anyone? What is the easiest engine to swap in with the least amount of complications?
    Mar 2012
    Baltimore, Maryland
    2016 640i, 1990 535iM
    M50 for the ease of swap. Just need engine, dme, engine harness from an e34. Done
    Oh and the right diff.
    2016 640i Coupe'
    1990 Bmw 535i Turbo 600whp
    1999 740iL: Sold
    1997 740i: Crashed and Parted
    1988 535i: Crashed and Parted
    1988 528e: Crashed and parted
    IG- @Rogetta_Stone
    May 2015
    Atlanta, GA
    540i6 S2M5 M2C 135 S52ti
    Quote Originally Posted by Mendozart View Post
    least amount of complications will be original motor (model not unit)... Anything else is probably fairly similar and difficulty if you change from original... If you do why not buy an s54? That would be super cool
    Oct 2008
    So. Cal
    Well, I'm going to go look at another 92' m50nv engine, with only 110k. If it looks good, I'm doing a straight-forward swap. In the meantime, I started to look for another e34 to drive while I take my time fixing my 92'. Found this immaculate, one-owner, 95' arktiksgrau-metallic. Its turn-key, really don't have to do anything, but maybe some new springs and wheels. ;-)
    Mar 2012
    Baltimore, Maryland
    Well but that one and part the other one
    2016 640i Coupe'
    1999 740iL: Sold
    IG- @Rogetta_Stone
    Oct 2008
    So. Cal
    I did buy it. I'm still going to fix the other one, as I'm going to need a vehicle for my daughter soon. ;-)
    Oct 2008
    So. Cal
    So, I'm finally getting around to swapping in the new engine. Any tips or info would've be appreciated.
    NW suburban Chicago
    hiss by my window
    Replace ALL the hoses, belts and tensioners. Good time to do the water pump and T-sat too. Re-gasket the "new" engine unless you are sure it's not leaking.
    Parts are cheap, now is the time.
    Dec 2011
    Lancaster CA
    e34,e38,e39,e46,e70,e90
    Quote Originally Posted by ross1 View Post
    This is great advice. I replaced the motor in my e38 (M62) and did all the gaskets and timing chain job while it was outside the car. Super easy. I contemplated doing the head gaskets but my friends convinced me it wasn't needed and get the car on the road. About 30k miles later, one of the HGs failed. Took both sides apart and found the other side HG was cracked too. Instead of $50 in gaskets, I spent about $500 to check the heads, get other gaskets, etc. Talk about a PITA job, especially the position of the exhaust manifolds in that car.
    Not saying you should do the HG, but it sure will be easier now than in the car, if you lean that way. With only 110,000 miles, it should be good for another 80-100k before you get into HG failure territory.
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by kouks View Post
    You were unlucky. HG failures are more related to cooling system maintenance than miles. If OP's "new" engine has/had nasty coolant in it then it might be worth investigating. H gaskets are a big job either way and always lead to even more "might as well".
    Jan 2017
    Amman, Jordan
    1995 BMW 525i Touring
    I did an M52 swap (from 528i 1998) about a year ago, it's great it also has more torque same horse power tho, and no need to change any electronics. it's also 50 kg lighter.
    it has been running great with no problems what so ever.
    E34 525i Touring 1995, M52B28 LSD... fully restored.
    Oct 2008
    So. Cal
    Alot of hoses and tensioners were just replaced on my engine. I have transferred all the good parts to the engine going in.
    I just drained the block, and the coolant was nice and clean.
    Oct 2008
    So. Cal
    So, I'm just about ready to pull the engine. When I was pulling my oil pan, which needed to be swapped, I accidentally broke off the very end of the windage tray. Do you think this will be a problem?
    Mar 2012
    Baltimore, Maryland
    I'd say as long as no more parts break all is ok
    2016 640i Coupe'
    1999 740iL: Sold
    IG- @Rogetta_Stone
    NW suburban Chicago
    hiss by my window
    Nice going there, Brutus. Make sure no smaller fragments are ready to come off, perhaps smooth the edges and forget it.
    Oct 2008
    So. Cal
    Yeah, I cant believe I did that. Here's probably a stupid question. Do I have to remove my tranny to swap the engine in?
    NW suburban Chicago
    hiss by my window
    Well, sounds like you already got it out without the trans. Easier to do with an automatic as you won't need to align the input shaft & clutch, do-able either way.
    Oct 2008
    So. Cal
    Actually, I've only lifted the engine to pull the pan. I haven't had anyone free to give me a hand.
    Oct 2008
    So. Cal
    Ok, engine is out. Any tips on installing replacement engine with tranny in place?
    Mar 2012
    Baltimore, Maryland
    If trans going to in the cat just lay it in nice and leveled. Set engine mounts in place, use something to prop the rear side of the engine so you can attach the trans
    2016 640i Coupe'
    1999 740iL: Sold
    IG- @Rogetta_Stone
    Oct 2008
    So. Cal
    So, I'm swapping the last parts from my old to new engine. I went ahead and replaced main rear seal, and when I went to install the torque converter, it wouldn't go in as the bearing is different at the rear crankshaft. Any ideas?
    edit: So, after doing some searching, it looks like I need to remove the pilot bearing, then install a sleeve that centers the torque converter. Any ideas on how to remove the pilot bearing?
    Macon, GA
    '94 530iT/A|'95 540iT/6
    I've never tried it, but I've heard the "bread" method works.
    Stuff pieces of bread into the hole and compact it in with an socket extension and hammer. Eventually the bread builds up behind the bearing and is pushed out, lol.
  1. E9X shopping dilemma! Advice appreciated!
    By F3LIX in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 12-17-2010, 11:51 PM
  2. My e30m50 brake booster dilemma... Need advice!
    By RenaissanceMan in forum 1983 - 1991 (E30)
    Last Post: 06-02-2007, 12:23 AM
  3. A radiator dilemma, need advice
    By dcroghan in forum 1992 - 1999 M3 (E36)
    Last Post: 05-22-2006, 08:15 PM
  4. Advice on tire dilemma
    By nmehta211 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 01-08-2006, 12:25 PM
  5. Have Dilemma-Need Your Advice (long)
    By zrdster in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-04-2003, 07:08 PM
