Results 1 to 3 of 3
Thread: 2006 BMW 325i e90, NO START
    Aug 2016
    Ft Worth, Texas
    2006 325i
    I have a 2006 BMW 325i e90 series, The problem that it is having is that it will turn over just fine but will not Start. It has a new Battery.
    It has fuel pressure at the fuel rail and I can here the injectors firing, I checked the spark with a spark plug attached to the coil / boot assembly on #1 cyl. but it is not firing.
    I hooked up a OBD ll tester and got codes P0344/ P0369 and P1124.
    I thought it might be the crankshaft position sensor but upon cranking the engine it is showing to be turning 200rpm so I don't know it could still be bad.
    Is there a fuse for the ignition coils or would the ECM come into play on this problem, I went to subscribe to ALLDATADIY.com but they do not support BMW.
    I am a Technician by trade but this is my first BMW that I am having to troubleshoot.
    I hope that this is a problem that can easily be fixed, I don't throw parts at it to fix it so it would be good to here some feedback from a real Technician, Thank you... TERRY
    Mar 2015
    Bolingbrook, IL
    2006 BMW 330i
    Quote Originally Posted by tripjet777 View Post
    I just stumbled across this because my 06 330i is doing the same thing. Did you happen to figure out what the problem was?
    Jan 2017
    California
    2006 325i
    Did you solve your problem ? I came across the same problem on my 2006bmw 325i?
    Sent from my SM-J327P using Tapatalk
  1. Replies: 0
    Last Post: 12-02-2015, 09:01 AM
  2. BMW 325is e36 no start after crankseal replaced
    By jae992 in forum 1991 - 1999 (E36)
    Last Post: 12-06-2013, 02:46 PM
  3. DIS/GT1 install guide for 2006 BMW 325i E90?
    By Saskatoon2005 in forum Diagnostic Software
    Last Post: 10-20-2011, 10:23 PM
  4. Diagnostic Test- 2006 BMW 325I (e90)
    By rki1966 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-12-2010, 12:52 PM
  5. E9x 2006 BMW 325i E90 Sport Package Socal
    By Jimtway1 in forum 3 series & Z Series
    Last Post: 02-12-2010, 06:56 PM
