Results 1 to 3 of 3
Thread: 2000 328ci ses/eml/tcs p0120
    Aug 2016
    Vancouver, Washington
    2000 328ci
    I have a 00 328ci, had the vehicle detailed and when driving home after 30 min the ses/eml/tcs lights were going on and off, the car would barely run, then be fine, then barely run. limped it home. scanned it and saw codes p0120, p1580. cleared codes, and re-started, still barely runs, misfires at idle and will not rev over 2500 rpm, pops and chugs, smell unburnt fuel, only code that returned is the p0120. sounds like i just need to replace the throttle position sensor? maybe it got wet when they shampooed the carpets? i searched, but never saw a combination of those two codes. any help is appreciated. thanks!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The idle control valve is used to control the amount of air going into the air for engine speeds from idle (doh) to about 1800 rpm. It sounds like the throttle body is stuck in the slightly open position.
    Your gas pedal has 2 position sensors, "A" and "B." That's for redundancy. If sensor "A" goes bad (as it seems to have happened) the ECU relies on sensor "B" and ignores sensor "A." I doubt that washing the carpets damaged the sensor. Of course, that depends on the amount of water used to clean the carpets!!! Was a garden hose used to rinse the carpets? /s
    I'd check the throttle body for issues first.
    Aug 2016
    2000 328ci
    i thought this thing was fly by wire, it got a throttle cable, after tearing into it the throttle body/tps seems like it is one huge expensive unit that will have to be replaced, is that correct???!!!
  1. 2000 328ci EML issue, list of codes help is greatly appreciated
    By Bmw328ci00 in forum 1999 - 2006 (E46)
    Last Post: 02-04-2011, 08:50 PM
  2. My 2000 328Ci
    By E46_328Ci in forum BMW Rides & Events
    Last Post: 01-30-2003, 08:58 PM
  3. Looking at 2000 328ci
    By ///Mwannabe in forum 1999 - 2006 (E46)
    Last Post: 01-26-2003, 01:37 AM
  4. trade in 95 M3 for 2000 328ci? PLEASE HELP!!!
    By Turboricecooker in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 11-19-2002, 08:49 AM
  5. Tire blowout in 2000 328Ci
    By MattT1685 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 07-03-2002, 09:23 AM
