Results 1 to 18 of 18
Thread: Waterpump M6 Bolt Snapped Off During Extraction
    Nov 2015
    CA
    330i
    Following the tutorial on bmw330ci.net. I took off the pulley and am attempting to remove the water pump from the engine block.
    I inserted the two air box bolts (10 mm) on both sides of the pump. I took turns spinning each side. The hole on the drivers side of the pump broke off, whereby the bolt that was in there fell off.
    I kept turning the left side and the bolt ended snapping off inside of the hole. There's nothing hanging outside of the hole, everything is inside.
    The water pump has no signs of loosening and is still tight.
    Any ideas?
    Sent from my Nexus 6 using Tapatalk
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    If all of the water pump bolts are out, the only thing holding it in is the tension of the o-ring that holds the body of it in to the block. You shouldn't have anywhere near enough tension to snap the bolts off.
    Nov 2015
    CA
    330i
    Quote Originally Posted by dhurley34 View Post
    It was on extremely tight. Got it off though.
    Got it out with a hammer, two different sized pry bars and a medium sized screwdriver. Hit on all sides and pryed alternately. Tons if calcium deposits. Im thinking the calcium was holding it in.
    Apr 2009
    Vancouver Isl, BC, Canada
    98 Euro M3, 04 M3, 06 M5
    I had one that i ending up extracting in several pieces. It happens when the wrong coolant is used in the car and reacts with the aluminium to cause the calcium.
    Ones that have used proper coolant their whole lives i rarely even need to use the extracting holes.
    Current:
    - 09 335i MSport, FBO.
    - 98 Euro M3, Estoril Blue
    - 04 M3, Carbon Black, 6 Speed Coupe
    - 06 M5, Black on Black, Full Leather.
    - 73 3.0CS, Tagia Green, 5 speed M30b35 converted
    Ex's: 1984 325e, 1988 325IX, 1992 525I, 1995 540i/6, 2002 330i, 2005 330xi, 1992 850i, 2003 330i #1, 2003 330i #2, 2002 330ci, 2004 330ci, 2007 328CI, 2007 335i, 2001 M3, 2006 M5 6 speed
    Nov 2015
    CA
    330i
    Quote Originally Posted by legoman67 View Post
    Interesting. To my knowledge, the car had BMW coolant. I had to add Prestone 50/50 last week due to the upper radiator hose disconnecting near the bleed screw.
    Would one week of running Prestone cause this?
    Apr 2009
    Quote Originally Posted by shalang View Post
    Nah a week wouldnt of done it. It may be old, once it forms it doesnt really go away unless its manually cleaned out.
    Current:
    Nov 2015
    CA
    330i
    How can I manually clean it out?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    You might try vinegar. You can run the engine with vinegar as what is sold in markets is 5% vinegar and 95% water. That should help remove calcium deposits. Also, never use tap water in the cooling system. The result will be calcium deposits. Always use distilled water and BMW coolant.
    Nov 2015
    CA
    330i
    Quote Originally Posted by MarcoZandrini View Post
    Thats pretty cool. Starter reading up on it. I am installing a new radiator, should I still do this?
    Also, do I need to have coolant in the car when I do this procedure or do I just fill two gallons with white distilled vinegar? What is the procedure of running the engine?
    Aug 2014
    Lawrence Kansas
    Use a 30% vinegar, 70% distilled water mix. Bring it up to temperature and idle for 20-30min then drain. No need for coolant. This is an old trick used on boats to clean and neutralize salt water deposits in their cooling systems.
    Nov 2015
    CA
    330i
    Use a 30% vinegar, 70% distilled water mix. Bring it up to temperature and idle for 20-30min then drain. No need for coolant. This is an old trick used on boats to clean and neutralize salt water in their cooling systems.
    Any particular type of vinegar?
    So two gallons worth of this mixture, correct? Do I do this with the new thermostat, water pump, radiator, hose, etc installed?
    Aug 2014
    Lawrence Kansas
    Correct. Yes, have everything installed. Once done, drain the radiator and block. then refill with the coolant/distilled water mix and enjoy.
    Nov 2015
    CA
    330i
    Great, I will do that today! Do I have to drive the car or can I just let it get up to temp while idling?
    Aug 2014
    Lawrence Kansas
    Idling is preferred.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Any particular type of vinegar? So two gallons worth of this mixture, correct? Do I do this with the new thermostat, water pump, radiator, hose, etc installed? Sent from my Nexus 6 using Tapatalk
    Whatever is sold in the market. As I wrote above, most vinegar is 5% vinegar and 95% water.
    I'd run this through after the new cooling system parts have been installed. Also, I'd follow up with a distilled water only flush to get rid of the vinegar and any calcium that's come loose.
    Nov 2015
    CA
    330i
    Great thanks. I got white distilled vinegar.
    Another question, do I follow the bleeding procedure as with the regular coolant mix?
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Great thanks. I got white distilled vinegar. Another question, do I follow the bleeding procedure as with the regular coolant mix? Sent from my Nexus 6 using Tapatalk
    Yes, the bleeding procedure will be the same. Let me change one thing that I wrote: I'd do the vinegar flush with the old parts in the car. Drain that and then install the new parts. Then do a flush with the distilled water. Then use the BMW coolant and DISTILLED WATER refill and bleed.
    Nov 2015
    CA
    330i
    I already have all of the new parts on, including the radiator.
  1. M62TU Camshaft Bolt Snapped Off -- Help!
    By peter540 in forum 1996 - 2003 (E39)
    Last Post: 04-12-2014, 02:28 PM
  2. snapped off water pump bolts
    By norcale28 in forum 1982 - 1988 (E28)
    Last Post: 12-15-2012, 04:06 PM
  3. Discovered head bolt snapped off
    By archilot in forum 1983 - 1991 (E30)
    Last Post: 09-10-2009, 05:17 PM
  4. Water pump bolt snapped off!
    By boscenter in forum 1991 - 1999 (E36)
    Last Post: 09-24-2005, 01:07 AM
  5. m6 bolts for h2o pumo change
    By gsxy in forum 1991 - 1999 (E36)
    Last Post: 08-10-2001, 04:30 PM
