Results 1 to 25 of 25
Thread: How To Get Started Using RomRaider -- E36 Specific Guide
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Ok, here is a work in progress write-up I did on the OpenMS41 Wiki that should have the best of this sort of information:
    https://sites.google.com/site/openms...with-romraider
    Last edited by tptrsn; 08-24-2016 at 01:17 PM. Reason: Replacing my writeup with better info
    Jul 2011
    Dell Rapids, SD
    2-97 M3 sedan, 2015 STI
    I clicked on the links but none seem to work.
    THE TIME DRAWS NEAR!
    DeWitt, Michigan
    Ok, thanks. Some of them don't work for me either, I'm not sure what I did... Anyway, I am working my way through them and fixing them.
    Ok, I think they are all fixed now. At least they all work properly on my computer with a single click. Sorry about that, I'm not sure what I did wrong the first time through.
    Jul 2011
    Dell Rapids, SD
    It opens up now but it says I'm not authorized to download the attachment. it seems you have to register with RomRaider first before you can download it. I tried registering before but i didnt get any response from the site. if you don't mind, can you please email me the attachment at kasj2002@gmail.com? thanks in advance.
    I have the ECU editor knowledge of opening up and organizing the different files but the logger is my biggest issue.
    DeWitt, Michigan
    Well, the logger is sort of a separate thing, that still often gives me problems (but sometimes I can get it to work). I'm hoping to gain some good understanding of why it doesn't work for me sometimes so I can iron out whatever the issue is, and then I can maybe help with the use of the logger too.
    For now, TestO seems like the slickest option for logging. You can find it in this thread:
    http://www.bimmerforums.com/forum/sh...ime-graph-view
    Still though, I can email you something if you tell me exactly which document you are looking for?
    Jul 2011
    Dell Rapids, SD
    Quote Originally Posted by tptrsn View Post
    for now I'm asking for the latest ms41 v0.43 definition file. Can you email me a copy please.
    As for the logger, sometimes I get it to work sometimes I don't. That issue is due to the files that are required to be open and run the logger for the e36 ms41 has to be in a certain location, so I'm thinking.
    DeWitt, Michigan
    Coming your way!
    Jul 2011
    Dell Rapids, SD
    Coming your way!
    thanks. I received it.
    Dec 2009
    Halifax, NS, Canada
    '90 325is '88 M3 '87 iX
    The biggest thing that screwed me up with RRlogger, was not having the newest version of the logger.
    After that, it took me a while to figure out that in RRlogger, I needed to go:
    Settings>Select Logging Protocol Options>DS2--K-Kine.
    Once I had it on that setting, it worked properly.
    Jul 2011
    Dell Rapids, SD
    Quote Originally Posted by Northern View Post
    The biggest thing that screwed me up with RRlogger, was not having the newest version of the logger. After that, it took me a while to figure out that in RRlogger, I needed to go: Settings>Select Logging Protocol Options>DS2--K-Kine. Once I had it on that setting, it worked properly.
    Mine is automatically set to that when I open Rrlogger but it still doesn't connect to the DME. I know for a fact that it's because I'm not opening the logger definition from the right folder/file. I know the v317 is where the logger definition is but I can't seem to find the right profile to load.
    May 2012
    South West Michigan
    e38 740i e39 540 wagon
    You guys should contact Tunercat and Moates.net, they can do much better software and get you real time tuning ability.
    DeWitt, Michigan
    What have you used that on? And what years are your 540 and 740? Have you done any tuning on them? If there is a good tuning method for an early e39 540 I need to know about it!
    Quote Originally Posted by spenka View Post
    I was just out doing some logging with TestO, it is pretty sweet.
    Jul 2004
    Houston, TX
    36 Cylinders
    Quote Originally Posted by SeanCollins View Post
    Very off topic, it probably has to do with a standalone system. Totally different of what is mentioned here.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    DeWitt, Michigan
    That's what I figured too Abel, but I figured I'd respond in kind with another off topic. Lol (Thad here)
    Oct 2005
    Lawrenceville, GA!
    Many Broken Ones
    I use a moates setup for OBD1 E30/E36 stuff. Nice and wish i could get it working for OBD2.
    460whp/515wtq wifes MMW tuned 335i
    DeWitt, Michigan
    I reloaded everything, and so far the logger has been working well for me. Going out to throw a new tune in the car and see if the logger works again straight away or not. RomRaider really is pretty slick once you get everything rolling. No complaints here.
    Jul 2011
    Dell Rapids, SD
    It does work but to get it to work you have to open certain files in certain folders.
    DeWitt, Michigan
    All I have done is made a folder on my desktop called RomRaider where I have the latest definition file, and I also have another folder called logger _v317 inside of that folder where the logger definitions including the one I made for my car. They seem to work great now that I properly installed RomRaider instead of running it from a thumb drive... My problems were self-inflicted as usual. Haha
    By the way, in the first post I deleted my writeup and replaced it with a link to a similar writeup I made on the OpenMS41 Wiki. That way as that gets improved, this thread will just have a link to the improved version.
    Jun 2017
    cape town, south africa
    e36 328i
    can I please get a copy of the ms41 definition, ive been trying to register on romraiders website for months now
    busterhax's Avatar
    busterhax is offline Y̝͎̘̍́ͣ̉͑̿̆Ō͎̼̺̬̒ͯ̃̇͗̂ U͈̖
    Jun 2006
    NYC
    e36
    Quote Originally Posted by bjenkinson View Post
    Why can't you register?
    Jun 2017
    wi
    328i 325is e420 s55 f150
    same issue, if someone could send it to me also that would be great
    busterhax's Avatar
    Jun 2006
    NYC
    e36
    DeWitt, Michigan
    busterhax is an administrator or something on there, so you guys really should help him to help you.
    Dec 2015
    Newcastle, NSW, Australia
    1997 BMW 323i
    Quote Originally Posted by busterhax View Post
    I can't register either, I get the message
    "The submitted form was invalid. Try submitting again.
    The confirmation code you entered was incorrect."
    I tried submitting about 30 times, no luck.
    EDIT: i was trying to register previously on android through chrome, today i tried on windows through chrome, it appeared to work and when i checked my spam it was in there, so problem solved, romraider signup does not work on android, and emails go to spam in gmail.
    Aug 2020
    adelaide
    1997 e36 325
    hi tptrsn just wondering if you can help me out i am having trouble getting definition files for ms41.0 off rom raider if you can email them to ramomujic1@outlook.com would be far more than helpful and greatly appreciated thank you����
  1. Calypsorot E36 - how to get started, ideas?
    By bahasad in forum BMW Rides & Events
    Last Post: 02-24-2011, 12:05 AM
  2. Looking for help on how to get started with Tracking my car
    By Driven06Z4M in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 12-18-2006, 01:28 PM
  3. How to get start in autocross?
    By monsterjoe in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 09-14-2006, 10:12 PM
  4. How to get started?
    By bwo1525 in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-10-2005, 10:52 AM
  5. Anyone know how to get into a locked E36?
    By Scott528iM in forum Georgia sponsored by Harrison Motorsports
    Last Post: 03-05-2004, 11:46 AM
