Results 1 to 4 of 4
Thread: P1100 fault code on 118i E87 2005
    Aug 2016
    Perth, WA, Australia
    BMW 118i E87
    Exactly what does this code refer to? I have been told everything from the MAF sensor, to the O2 sensors. Please clarify for me so I can fix it.
    Dec 2016
    Melbourne, Australia
    X3, E90 302i, E87, R56,
    Quote Originally Posted by Learner View Post
    Did you sort it? I would love to know too!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Google is your friend. Manifold Absolute Pressure (MAP) Sensor Malfunction (Open/Short). Check the wiring.
    Dec 2016
    Car 1 N46 2006 120i
    Car 2 N46 2006 320i both same problems..
    I have tried with no luck replaced MAF Air-box 4X O2 sensors Up & Down-steam , MAP sensor maniflod & Cleared all and seperatly the adaptations with INPA, still no luck! Codes come back.
    Check plugs & wiring back to ECU.
    I know the car has had CCV done, so would an air leak throw up codes like P1100?? if not done correctly or the CCV is broken?
    Anyone know specifically a BMW tech please not something you found on google. Please don't reply if your not a tech, or you know 100% by your own experience on this specific motor, thanks.
    What I have not done is an ECU rest or refresh, as I don't know how or know what software to do this with.
  1. How go I clear the fault codes on an ODB1 car?
    By Nemesis519 in forum 1991 - 1999 (E36)
    Last Post: 11-12-2006, 11:24 AM
  2. Misfire fault code on all six cylinders
    By shifterkart33 in forum 1999 - 2006 (E46)
    Last Post: 07-21-2006, 01:36 PM
  3. Fault codes on a 2002 Bmw Xi
    By Eghatchy in forum 1999 - 2006 (E46)
    Last Post: 07-05-2006, 07:46 AM
  4. Fault Codes on '95 M3
    By Dr. Car in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-07-2006, 06:24 AM
  5. Fault Codes on 97 OBDII
    By razormy in forum 1992 - 1999 M3 (E36)
    Last Post: 12-01-2004, 07:06 PM
