Results 1 to 22 of 22
Thread: The Official E39 Rear Shock Replacement DIY Guide
    CT
    E28, E32, E39, E53, E90
    I just replaced the rear shocks on my 530i Sport and recorded some videos to demonstrate the complete procedure. You can read more about the tools required and other details on my site here:
    https://bimmerzeit.com/2016/08/19/e3...-complete-diy/
    Step One: Rear Seat Removal
    Step Two: Rear Parcel Shelf Removal
    Step Three: Rear Shock Replacement (Driver Side)
    Step Four: Rear Shock Replacement (Passenger Side)
    Hope this helps!
    Aug 2011
    Charleston, SC
    2000 M5, 2018 Macan Turb
    First, thanks to the OP for the DIY. However, I would recommend taking the rear shocks out by removing the rear upper control arm, then the shock drops right out. It's easier than bending the fuel fill pipe around or hassling on the other side with the evap system, and less risk of damaging the top of the fender or damaging a hose etc.
    PCA HPDE Instructor
    current:
    2004 M3 convert 6sp man - low mileage beauty!
    past:
    1995 BMW M3 3.2
    2004 M3 convert SMG
    2003 BMW 540i6 Alpine White M sport (I want her back!)
    CT
    Quote Originally Posted by bostonaudi View Post
    Interesting, I didn't think of doing it that way. Can you link to any video or photo of that method? Thanks!
    Aug 2011
    Charleston, SC
    Quote Originally Posted by rbelton View Post
    As in photo, with upper link removed it’s quite simple to remove the damper. The link is reasonably easy to pop, make sure wheel is at ride height when retightening the inner bolt.
    PCA HPDE Instructor
    current:
    past:
    1995 BMW M3 3.2
    2004 M3 convert SMG
    Aug 2011
    Charleston, SC
    And to make it super easy, the Schwaben spring compressor. Makes struts a snap.
    PCA HPDE Instructor
    current:
    past:
    1995 BMW M3 3.2
    2004 M3 convert SMG
    NW suburban Chicago
    hiss by my window
    "And to make it super easy, the Schwaben spring compressor. Makes struts a snap."
    Are you using this just to slightly compress the assembly for installation or using it to change the shock?
    Is the spring retained by anything? That thing looks like an accident waiting to happen.
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    I don't use a spring compressor, just a jack under the swing arm.
    Don't unbolt the top shock mount.
    Unbolt one end of the sway bar link.
    Remove the top front upper link nut, pop it out of the wheel carrier.
    Remove the shock rod nut and then the nut on the bottom of the shock.
    Lower the jack.
    Aug 2014
    Cheshire, CT
    1998 BMW 528i / 5
    Quote Originally Posted by ross1 View Post
    Agree! I'm ducking just looking at that picture! I'm hoping that there's some sort of safety clamp hidden from view behind the clamps.
    Lower the jack.
    Hmmm. Interesting Jim. I'm wondering how/if to use this method on the front struts. My hands and arms are sprained from doing just the left side two weeks ago with threaded rods.
    Ed CT
    1998 528i
    5-Speed
    Aspen Silver
    Aubergine Leather
    JimLev's Avatar
    Sundance Mesa, NM
    Ed, I used my spring compressors on the fronts. One on each side of the spring, they have hooks that go around the coil so they can't fly off.
    Pretty sure Raj has a good DYI on his Biesan site.
    Aug 2014
    Cheshire, CT
    1998 BMW 528i / 5
    Yes, been doing the same thing using Rajai's procedure, and using 3 compressors to keep the coil centered.
    Ed CT
    1998 528i
    5-Speed
    Aspen Silver
    Aubergine Leather
    Aug 2011
    Charleston, SC
    Quote Originally Posted by Ed CT View Post
    The Schwaben is gold, I’ve been doing suspensions for 35 yrs, this is best home tool you can get. It hooks the spring and holds it solidly, and it’s super easy to compress the spring. Way better than than the typical cheapies with threaded rods.
    PCA HPDE Instructor
    current:
    past:
    1995 BMW M3 3.2
    2004 M3 convert SMG
    Aug 2011
    Charleston, SC
    Should add the fender liners can still be a PIA even with the top link removed. The top mount can get caught on the top of the liner.
    PCA HPDE Instructor
    current:
    past:
    1995 BMW M3 3.2
    2004 M3 convert SMG
    Aug 2014
    Cheshire, CT
    1998 BMW 528i / 5
    So it does have a safety hook or something. This is good to know Thanks.
    Ed CT
    1998 528i
    5-Speed
    Aspen Silver
    Aubergine Leather
    NW suburban Chicago
    hiss by my window
    Glad to hear that. It looks like a well made tool.
    After using and having scary moments with screw types and other DIY type stuff for ages I started bringing my struts to a local shop with a friendly owner. He would do them for me using a Brannick wall mount spring compressor. ~2 years ago I broke down and bought my own. It was an epiphany, 5 minutes TOPS using one of these and you're not so afraid as if disarming a nuclear bomb.
    I've since noticed several used ones for sale on Craigslist at reasonable prices, $2-400 v. $800 new. I suspect the popularity of fully assembled "quick struts" has a lot of shops abandoning the practice of replacing components
    Lower the jack.
    Gotta be a little dodgy re-assembling that way, no?
    JimLev's Avatar
    Sundance Mesa, NM
    No, pretty easy. The swing arm is down. Stick the shock with spring up into position, slide the bottom of the shock into position, install the bolt, then start jacking the swing arm up. Reassemble the remaining parts.
    Removing the front upper arm from the wheel carrier lets the swing arm drop down enough so no 2x4 wood is needed.
    NW suburban Chicago
    hiss by my window
    Hmmm, I'd have thought lining up the shock to the mount hole would be problematic. I will be facing this job again soon (if some engine issues get sorted first) and will give your method a try. It's gotta be much easier to wrangle the shock without the mount into place.
    Words can't describe how much I hate doing these. Maybe you'll have eased my pain.
    Westchester County, NY
    Porsche 930, 2003 540 Sport
    That’s a great description
    NC
    2003 BMW 530i
    Rear shock removal without spring compressors and without removing wheel liner.
    Thanks OP for the excellent video tutorial.
    Please follow the Bentley's Service manual instructions. I did this at my own risk.
    To remove the rear shocks without spring compressors and without removing the wheel liner I did the following on a 2001 530i Msport suspension re using original springs.
    1. Remove sway bar link at the sway bar and place a jack under the swing arm.
    2. Remove both swing arm bolts that attach to the body. Note orientation of bolt washers.
    3. Remove both rear control arm bolts that attach to the body (control arms ball joints can remain installed). Unhook abs and parking brake line.
    4. Loosen bottom shock bolt.
    5. Remove shock mount nuts and the shock shaft nut inside the rear cabin.
    6. Slowly lower swing arm using jack all the way down. Remove shock bolt, shock mount, then snake the shock out.
    7. Installation is reverse order except you can install shock mount by hand.
    8. Preload suspension when tightening shock, swing arm and control arm bolts.
    8. Get an alignment.
    Santa Cruz Mountains
    '03 M-Sport 540iA
    +1...that's how I did it too.
    I was born and raised in Charleston, SC...
    '00 540iA Sport w/235k+ Original TCG's, Vanos and transmission.​*Trans failure at 244k+...FS Now
    Jul 2019
    Canada
    BMW E39 528i 1998
    I'm getting ready to replace the rear suspension, including full suspension and rear subframe bushings.
    I have a question for the rear struts.
    Do you guys replace all the other components as well?
    All the rear strut hardware comes out to $650 CAD - more expensive than the rear struts themselves.
    Do you guys replace all the strut hardware components or some are safe to skip? The top plates alone for the rear struts are alone $140 each
    https://parts.brianjesselbmw.com/p/b...521091710.html
    May 2018
    Austin, TX
    00 M5 | 03 540i | 94 NSX
    Replacing the rubber bits makes sense but not the other stuff unless its just really rusted out or something. I would buy #7, #5, #3, and maybe #4.
    Middle of a corn field
    E39 hamster/ruberbandPWR
    Just replace the mounts , any rubber spring pads, and bump stops , and of course the struts and shocks ...
  1. Rear shocks replacement DIY
    By shogun in forum 1988 - 1994 (E32)
    Last Post: 03-10-2020, 12:04 PM
  2. E39 Touring Rear Shock replacement
    By BlackBMWs in forum E39 Common Problems and DIY Fixes
    Last Post: 12-10-2014, 01:38 PM
  3. Will E39 rear shocks fit the E34?
    By locknload in forum 1988 - 1996 (E34)
    Last Post: 11-13-2012, 08:39 AM
  4. E39 525 Touring, NON SLS, rear spring replacement DIY?
    By timmay77 in forum 1996 - 2003 (E39)
    Last Post: 07-26-2012, 09:46 PM
  5. anyone use the JTD steel rear shock mounts?
    By 95MMM in forum 1992 - 1999 M3 (E36)
    Last Post: 01-05-2004, 10:07 AM
