Hey guys I have a 335i Bmw coupe I want to paint the engine cover but I'm not sure where to start except for cleaning it to death! I've watched videos and it says that high heat primer for at least 3 coats is good and then can paint with regular paint over it. Also I want to know if clear coat is a good idea after - please and thank you for the info.
I would scuff it lightly with a scotch pad to give your primer more "bite". I would not clear coat it though. Perhaps use high gloss high temp paint instead?
You might consider an adhesion promoter also to help?
People I owe beverages to, lokijibber
