Page 3 of 12 FirstFirst 123456789101112 LastLast
Results 51 to 75 of 299
Thread: 2001 740iL Project
  1. #51
    Oct 2014
    Simpsonville, S.C.
    2x E38 740iL/04 4.8 E53
    Quote Originally Posted by dville View Post
    Can you share how you got the gauges to work?
    Sure thing.
    I used the OEM water temp sensor. The one in the top of the water pump. I had to rethread the sensor to fit in the standard threaded hole of the new block. Also when this sensor is unplugged it will make the temp gauge go directly into the red when plugged back in. Easy fix. Unplug the battery for about 10 minutes, restart the car and now the temp gauge will read correctly.
    For the tach I used the OEM crankshaft positioning sensor (the one in the bell housing of the transmission). It is magnetic and all I had to do was weld a tip on the new transmission flywheel and place the sensor close enough to pick up the tip rolling past. Easy as that. Tach picked up instantly and hasn't skipped a beat. I did however have to go through 3 sensors to get the right placement. Too close twice.
    2001 E38 (Stroker Motor) / 2004 X5 4.8iS / 2006 760Li V12
  2. #52
    Oct 2014
    Simpsonville, S.C.
  3. #53
    Oct 2014
    Simpsonville, S.C.
  4. #54
    Oct 2014
    Simpsonville, S.C.
    Got a lot done today. Hood cut, put the front end back together and took it out after new center support bearing installed. Purred like a kitten! Ran some more wires for new gauge cluster to go in the center console area. Had it up to 50 mph today. First time it's seen over 10 lol!! Really coming together now.
  5. #55
    IL
    2000 740i sport
    Bummer you had to cut the hood...
  6. #56
    Sep 2009
    Lititz, PA
    99 740iL, 12 VW TDI
    Great work. How are you gonna do the hood, or is it done!
  7. #57
    Oct 2014
    Simpsonville, S.C.
    Quote Originally Posted by daniels635turbo View Post
    Nah, thinking of something similar to the M3 hood. Have to work out the details still but I think it's completely doable. It will look more modern than a cowl hood. I wanna keep it as subtle as it can be lol. Once it's started there is nothing subtle about it.
  8. #58
    Oct 2014
    Simpsonville, S.C.
  9. #59
    Oct 2014
    Simpsonville, S.C.
    2001 740iL Project
    The old center support bearing
  10. #60
    Sep 2009
    Lititz, PA
    99 740iL, 12 VW TDI
    That is pretty meaty!!
  11. #61
    Oct 2014
    Simpsonville, S.C.
    Yes sir!!
  12. #62
    Oct 2014
    Simpsonville, S.C.
    2001 740iL Project
    Both my girls haha!
  13. #63
    Jan 2015
    Tempe, AZ
    1995 525i/5
    It sounds like a truck right now, haha. Is there a exhaust system in place or is just running with open headers? I forget, did you get the AC working or is that still on the to-do list?
    1995 525i 5-speed - Thread
  14. #64
    Girard, Ohio
    98 VW Passat
    Well it's an old school carb based engine, so it's going to be loud regardless lol.
  15. #65
    Oct 2014
    Simpsonville, S.C.
    2001 740iL Project
    Quote Originally Posted by dannyzabolotny View Post
    I have the A/C just isn't installed at the moment. So, it's still on the to do list. And it's open headers at the moment. It's way too loud!!
  16. #66
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    Yea - you need to fix that exhaust leak for sure.
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
  17. #67
    Sep 2009
    Lititz, PA
    99 740iL, 12 VW TDI
    Dude while you are at it you should totally NOS it!!!
  18. #68
    Mar 2011
    Ritzville, WA
    07/97 740i
    Quote Originally Posted by 01740iL1985 View Post
    Both my girls haha!
    They are beautiful! This is an awesome project. Nice work man!!
  19. #69
    Oct 2014
    Simpsonville, S.C.
    Haha. I have ZERO experience with NOS!
  20. #70
    Oct 2014
    Simpsonville, S.C.
    Quote Originally Posted by 98740i View Post
    Thank you! It's still a diamond in the rough but hopefully by October I can take it on the first real road test!!!
  21. #71
    Aug 2012
    Austin TX USA
    2006 M3 ZCP/2001 540iT
    Super cool project, cant wait to see the finished result... or mostly working result...they are never "finished" hehe
    2001 540it Black/Black --- 2006 M3 Competition Pkg Black/Black
    **FOR SALE - E39 DINAN 540I 4" intake and filter - gently used PM ME for details.
  22. #72
    West Palm Beach, FL
    06 Audi A8L Quattro
    2001 740iL Project
    Couldn't you remove that triangle air cleaner to get some clearance and fab up some ductwork to use the fresh air vents on the top of the hood to route them through the existing filters to the carb?
    So when you close the hood it sucks air through the vents near the windshield washer jets back to the carb
  23. #73
    CT
    E38
    WOW those wheels! They look amazing against the Anthracite Metallic. I may have to get rid of my M Parallels on my Anthracite Short Sport for those. Absolutely beautiful. I'd just be afraid that they'd negatively affect driving dynamics.
    E38 M Sport 6 Speed MANUAL
  24. #74
    Oct 2014
    Simpsonville, S.C.
    Quote Originally Posted by RSBBlackM3 View Post
    Yep yep!! May be done soon but it will never be complete lol.
  25. #75
    VA
    E63AMG/Z31/Tacoma/F31
    Wheels do look great! This car needs a huge blower though.
  1. My 2001 740iL Project Car
    By dville in forum 1995 - 2001 (E38)
    Last Post: 12-27-2018, 10:59 AM
  2. Pricing info - 2001 740iL
    By jr87492 in forum 1995 - 2001 (E38)
    Last Post: 03-29-2004, 04:09 PM
  3. 2001 740il, NJ, $36k
    By rgc1265 in forum BMW Cars For Sale / Wanted
    Last Post: 03-15-2004, 12:38 PM
  4. Best price anyone has seen for a 2001 740il sport?
    By AlexeTDog in forum 1995 - 2001 (E38)
    Last Post: 12-10-2003, 12:57 PM
  5. Is this a good price for a 2001 740il?
    By edcheung in forum 1995 - 2001 (E38)
    Last Post: 04-06-2003, 05:56 PM
