Thread: RVAE34's next E38 project
  1. #2851
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    Quote Originally Posted by RVAE34 View Post
    It's because it has the UV/IR glass. Which I love so I'd never cheap out on the replacement.
    I kinda agree on the UV - it is nice! I wish my old 86 L7 would of had it maybe the leather dash would have lasted longer in the Texas sun!!!! Went thru two - BMW said no more!
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
  2. #2852
    Oct 2007
    VA
    00 Mshoe
    Gross... but more understandable.
  3. #2853
    Sep 2018
    Canfield, Ohio
    2001 BMW 740il
    Quote Originally Posted by Alpine 7even View Post
    Good choice! It’s a beautiful build man!
    So is yours tho!!! What do you mean by custom ashtray cup holder? I want one! Ones that come stock suck!!!
  4. #2854
    VA
    E63AMG/Z31/Tacoma/F31
    Finally ordered all 4 Turner monoball arms for the front.
  5. #2855
    VA
    The control arms arrived today. I have a cracked headlight lens and fog light so I think I will take the time to replace those while the car is down. My ac aux fan makes a little noise when I cut off the car every now and then so perfect time to do that as well.
  6. #2856
    Oct 2014
    Mesa AZ
    2000 740iL
    Do the bearings happen to have the PN on them? I stubbornly refused to pay for an aftermarket kit and decided to make my own kit.
    I picked 33326792553 for the thrust arm and 33306852895 for the control arms. Just curious if I picked the same OEM bearing as they did.
  7. #2857
    Greenville, SC
    01 749iM/6 sporty
    Quote Originally Posted by KinkedChrome View Post
    They use a OE quality ball bushing but the companies machine an adapter to fit the bushing in the arm. If you have a lathe you could probably make them yourself.
    Trevor
    01 749i sporty, build 12/00 "Sports Barge",S62
    92 VW Corrado VR6,AAA
    81 Delorean,B28F
    81 VW Rabbit Pickup 1.8T,AWW
    03 VW Passat wagon 4.0 W8 6spd
  8. #2858
    Oct 2014
    Mesa AZ
    2000 740iL
    Quote Originally Posted by 007008 View Post
    Yeah, those part numbers I listed are OE sealed type bearings. Originally I was just going to use something teflon lined from FK or QA1 until I saw the Turners and few others using OE bearings. As a self proclaimed circle expert, my plan was to make just the bushing that you described.
  9. #2859
    tmaxx445's Avatar
    tmaxx445 is offline E38 6 Speed Club Member! BMW CCA Member
    Dec 2010
    Greensboro, NC
    '05 M3, '03 X5, '01 740i
    That does appear to be the number that the Tuner monoballs use for the thrust arm. Prior to installation I did take the snap ring off and examine them a bit closer and they are indeed Lemforder ball joints and the numbers on the boot match up to the pictures shown on ECS for the 33326792553 part seen here:
    https://www.ecstuning.com/b-lemforde...326792553~lem/
    Here are a couple of pictures I took before I pressed them into the arms:
    The numbers 030 060 004 012 03 can be seen on the rubber boots. Not sure that corresponds to but I guarantee those are the ball joints used.
    2001 740i / S62 Swap / 6 Speed Swap / Titanium Silver Metallic / Grey Montana Leather / M Sport / Convenience Pkg / Heated Seats / PDC / MKIV Navigation / DSP / Bluetooth TCU / Dice Mediabridge / Vavona Trim / Illuminated ZHP Shift Knob / Short Shifter / Cat Delete / SAI Delete / Euro Tune / Koni Singles / H&R II Springs / Custom 3.15 25% Limited Slip Diff / Staggered OE M Parallels / 275 & 245 Firehawks / Euro City Lights / Celis Tail Lights / SunTek 70% CXP Tint
    2005 M3 Coupe
    / 6 Speed / Silver Gray Metallic / Black Nappa Leather / Premium Pkg / Cold Weather Pkg / Bi Xenons / Adjustable Bolsters / MKIV Navigation / Harman Kardon / Bluetooth / Sirius XM / Aux In / Carbon Trim / ZHP Shift Knob / Short Shifter / StreamLine Intake / SS Headers / AR20 Resonator / Exhaust Bypass Valve / P0lar Tune / Koni Yellows / Eibach Springs / Staggered OE CSLs / 275 & 245 595 Evos / Angel Eyes / CF CSL Splitters / SunTek 38% Carbon Tint
    2003 4.6is X5 / Stock /
  10. #2860
    Oct 2014
    Mesa AZ
    2000 740iL
    Quote Originally Posted by tmaxx445 View Post
    Thanks for the close up pics! They do look really close to the same. I just searched real oem until i found a bearing that showed installation with a 14mm bolt for the thrust arms and then a 12mm bolt for the control arms. From the pics on their website, it looks like Turner used the same bearing for both arms and used bushings to make the 12mm control arm bolt fit in the 14mm bore bearing.
    Its not very often these days i decide to build something instead of just buying it, so im excited to have me a little turning project soon.
  11. #2861
    VA
    Installed the Turner monoballs and was ready to drive last night but had forgotten I left the key in ignition to unlock steering which drained the battery so I will take the first drive when I get home. I plan to get it aligned soon too.
  12. #2862
    IL
    2000 740i sport
    Can't this also potentially cause the dme and ews from becoming unsynched?
    Sent from my SM-N960U using Tapatalk
  13. #2863
    VA
    If you left it for extended period. I just left the key in for 2 hours. Still has power just not enough to start. Happens every now and then from sitting for weeks at a time when I don't drive it. I've had the same issue with all the BMW's I've owned.
  14. #2864
    Nov 2010
    Charlotte, NC
    03 M5/05 RR/06 Cayman S
    That's due to the NBT adapter. I have to disconnect the adapter in the trunk (little black box) when I know I'm going to leave the car parked for longer than a week. It draws almost 100mA at sleep. When disconnected, im at 25mA.
    Sent from my SM-G965U using Tapatalk
    -Paul
    2003 "M5" - Full M5 conversion, AMG C63S 6 piston front calipers, Porsche Panamera 4 piston rear calipers, GC Coilovers,
    Eibach ARBs, UUC Evo3/DSSR, Borla Exhaust w/Muffler Delete, BMW NBT with Carplay/Android Auto, Bi-Xenons, e38 Style 37 M-Pars, e60 Hubs 530i 6-speed swap build thread
    2005 Range Rover 4.6is (M62TU Powered) - 4.6is Engine Swap from X5, BMW NBT with Carplay/Android Auto
  15. #2865
    VA
    Aha!^
    I drove the car. Monoballs feel great. Definitely a solid 10-15% increase in NVH most notably over bumps and just feeling the road in general but certainly not bothersome. Steering feels sharper and more precise and even turning the wheel while static feels different than before. It still feels like I have the subtle vibration after a short drive but I won't really know until I drive it to work. If it remains, I will do center drag link and tie rods next. Then wheel bearings if that doesn't take care of it. I already had the wheels re-balanced.
  16. #2866
    Mar 2011
    Greenville, NC
    2001 7-S62, 2002 X5 S2,
    Ive battled the control arms since 2005. I did the PowerFlex bushings on my former E38, the wheel would nearly jerk out of my hand on some harsh bumps. So I just reverted back to 750 bushings. I may go for the protection bushings next time, IIRC they are different. Been a few years since I dove into that info. X5 bushings are also the same size. There may be zero difference in 740/750/750 Protection, but ill have to look. I always think in terms of dominoes, if the "shock" is removed from the arms, then the other parts will suffer the brunt. Some folks on BimmerBoard used to fill the holes in the OE bushings with RTV to firm them up, since its flexible its works on multiple levels. At the days end, it's individual driver preference.
    2001 | DINAN 7 Sport | S62 Swapped 6-Speed
    DINAN Springs & Exhaust | 750 Brakes | M-Pars | Monsoons | NBT Nav/Radio
    Dual Pane Glass | Black & Sand Int.
    2001
    | 750iL | AlpineWeiss III
    @scotthduke on Instagram
  17. #2867
    VA
    I pushed the hell out of the car on riverside dr today which is the most amazing short stretch of local road. The car blows my mind. Hard to believe it's such a big heavy car. Loving these monoballs but did not fix the subtle vibration at highway speeds. Im going to get some new as3's put on the mpars for winter just to rule out a balance issue with the BC Forged wheels.
  18. #2868
    Dec 2009
    Dallas,TX
    '98 E38 740IL, '01 740i
    Lol we had a Riverside Dr. in ATL that is also an amazing drive, I loved running that road in my 98 can't imagine what it must be like in yours Hopefully you'll get that vibration sorted out.
    TRPCHGE - '01 740i Black/Black 230k'ish - Power folding mirrors, Mk.IV Nav, 16:9, M-pars, Sport seats, Sport wheel, Steptronic, Euro rear fog switch, 2.50" X-Pipe, Shadowline, E53 4.6is Cluster, Lacewood interior, Chromeline, 3.15, Bilstein B6+H&R Stage II's. - SOLD 06/21
    BSKCASE - '98 740il Arctic Silver/Black 175k'ish - Face-lifted, 3" Projectors, Shadowline, 01 Tails, Hydro Trunk, Sunshades, 750il Full interior retrofit, Sport Seats, Steptronic, Face-lift Steering Column, X5 Steering wheel, E53 4.6is Cluster, Euro E66 Piano black/Chrome Grab-handles, Chromeline, Suede Pillars/Headliner, Auto wipers/Lights, Lighted Handles interior/Exterior, Dual battery retrofit.
    WIP: Custom Style 42 18x9.5" ET12, 18x10.5" ET8, 3.15 LSD Rear diff.
  19. #2869
    VA
    I seem to recall that I had a slight vibration when I installed the Apex or RD wheels as well.
    I put a good amount of miles on the car today. I can tell you one thing for sure. If I had monorails and coilovers, I would hate the ride quality. I drove over a lot of different road conditions today and you can definitely notice the NVH with these over stock. Have to choose your battles though and I love the way the car handles now so still worth it.
  20. #2870
    Oct 2014
    Mesa AZ
    2000 740iL
    They seem worth just to not have to replace thrust arm bushings all the time, thats my main motivation to do them.
  21. #2871
    VA
    Meh, that job is so easy though. And I have found that the last 3 times I replaced those arms in various BMW's I have owned, I didn't even need an alignment afterwards so then it just becomes a financial issue. But for the price of the monorails, you could buy a few sets of regular control arms.
  22. #2872
    VA
    Can anyone tell me the widest people are going on tires for mpars on our e38's? I plan to order some good all seasons today. Most likely the as3's.
    I thought I recall some running 275 or even 285 on the rear.
  23. #2873
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    285/40 on the rear. They fit great and are the exact same diameter overall as the 255/45.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
  24. #2874
    VA
    What about the front?
  25. #2875
    IL
    2000 740i sport
    I went with 245 45 on the front... Matches the sidewall on the 285 40s nicely...
Page 115 of 122 FirstFirst ... 156590105106107108109110111112113114115116117118119120121122 LastLast
  1. Babushka's E38 Project-Update 07/2019 Car is now for sale
    By Babushka in forum 1995 - 2001 (E38)
    Last Post: 07-24-2019, 10:50 PM
  2. E38 Project
    By Jfstu in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 09-20-2006, 03:47 AM
  3. This could be YOUR next conversion project!!
    By marinersfan in forum 1975 - 1983 (E21)
    Last Post: 05-03-2006, 04:11 PM
  4. Buying E38 Project car? Where do I find the fun stuff?
    By 760list in forum 1995 - 2001 (E38)
    Last Post: 06-22-2005, 01:48 AM
  5. Is this Jim's next evil project?
    By dysphunxion in forum Off-Topic
    Last Post: 08-26-2002, 02:20 PM
