Thread: RVAE34's next E38 project
  1. #2826
    Jan 2017
    Sacramento, CA
    2007 BMW 328I COUPE
    Amazing !!!
  2. #2827
    VA
    E63AMG/Z31/Tacoma/F31
    I've been driving the car a lot more lately and I think my subtle vibration issue is actually flat spots on the soft tires. It would have more vibration when I let it sit. When I daily it, it almost completely goes away. So it seems. I still plan to install monoballs, check out the bearings and check all wearables but I think I'm onto something.
  3. #2828
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Do you ever venture out to Charlottesville? Would love to see your car in person some day.
    Current: 2007 Z4 M Coupe (blue/black)
    Previous: 2001 740iL Sport (black/black), 2000 528i Sport (black/tan), 1995 318is (black/black), 1991 318is (white/black)
  4. #2829
    VA
    I don't. Ever come to Richmond?
  5. #2830
    Oct 2013
    Louisa, VA
    2007 Z4 M Coupe
    Darn. And nope, Short Pump is closest I've gone (except the Zoo with kids).
    I've got a buddy with Z4 M coupe in Richmond but I haven't seen/talked to him in ages
  6. #2831
    VA
    I go to Short Pump fairly often.
  7. #2832
    VA
    Love this edited version of a pic I took a few weeks ago.
  8. #2833
    Mar 2004
    Tyler, Tx
    '01 740i Sp, '07 335i
    Nice -- White on Grey.......
    http://i293.photobucket.com/albums/mm71/krallopian/darthSigTest2_zpsn6zkw5id.jpg[/URL][URL="http://www.facebook.com/pages/DFW7-Dallas-Fort-Worth-BMW-7-Series-Club/300942239566"]DFW7 on Facebook/URL]
    "The Last Great e38" 2001 i Sport - Born'd on date 1/01 Cosmos/Grey - 32.8K miles - 2 1/2 " Custom Exhaust, Center “X”over , Modified OEM rear bumper, M5 style trunk spoiler, M6 OEM wheels, M3 Steering wheel with working paddle shift & CF trim, Bi-Xenon upgrade, 13mm Rear sway bar added, SS brake lines and bronze bushings, Cross drilled rotors and painted calipers, Akebono pads, Zionsville aluminum radiator & exp. tank with electric fan, Sprint Booster, BluTooth conversion, MKIV Nav., Custom wood cupholder, DUDMD Tune, Orien V2.5 LED Angel Eyes, Evans waterless. Recently added grey faced //M5 Cluster - all gauges functioning. Changed the grey carpet to black and topped off with GG Bailey front/rear mats[/SIZE]
  9. #2834
    VA
    I've been contemplating trading her out for an F10 M5 lately.
  10. #2835
    Dec 2005
    Melbourne, Australia
    E24, E34 x2, E36
    Hehe u get easily bored but I wouldn’t trade it esp on the m5.
    Been looking back the last 4 pages on my annual scan of this thread.
    Couple of things I found with playing with my own vortech bmw v8
    firstly when going smaller pulley on the ess kit it’s certainly worth investigating using an 8 rib setup. There is enough room on the 140mm crank pulley to have some extra ribs machined. Going from 6 to 8rib eliminates the phantom slip. I went from 10 to 13 psi @ 7000rpm with no pulley dia change. U may be able to up the fuel pressure slighly to accomodate.
    Secondly the exhaust change is not easy to find the balance between flow, noise, and quality. Ideally you will need a min of dual 2.5” but the note can get very bassey at low rpm due to the velocity drop. To gain that nice high end sounding v8 scream some sub resonator chambers above the rear muffler slotted to the body of the main muffler work wonders in lifting the quality of the sound especially at cruising rpm. The quality aftermarket exhaust spike the supersprint and eiesenman (spelling?) are designed for NA and have prob not the dia for the force fed s62. They will sound great and really scream at high tho due to the high velocity.
    Love your work so far and don’t sell this beast. Just keep developing it.
    BMW’s
    90 E34 M5
    84 E24 M635csi standalone ecu with coil on plug
    94 E34 540i/6 SC 5-17psi Flex fuel/standalone ecu
    97 Z3 2.8
    97 E36 M3 euro SC still u/c
    OTHERS
    11 Audi S5 APR stg2
    19 Volkswagen Amarok V6
  11. #2836
    VA
    That's pretty much where I am at. Either I kind of go a little crazy (er more crazy) or upgrade.
  12. #2837
    Dec 2005
    E24, E34 x2, E36
    There is so much more left in it power wise. Intercooling , 8pk, bigger crank pulley and programmable management. With the nature of centrifugal supercharger can’t see why u can’t run 18psi with pump fuel. Add e85 and flex fuel capable engine management and u will turn a solid performance car into a complete animal.
    BMW’s
    90 E34 M5
    97 Z3 2.8
    OTHERS
    11 Audi S5 APR stg2
  13. #2838
    VA
    Talked to the wifey and she would prefer I get an F80 to an F10 if I ever did sell. But I am going to try and hold out and eventually have both. The F80 prices will likely drop even further when the new M3/4 comes out.
  14. #2839
    Dec 2005
    E24, E34 x2, E36
    There is something I just don’t quite like about the f80 m3/4. They look sexy but every juiced up one I hear on the street just sounds abit crappy. F90 m5 is more my go except for the bank balance.
    Id have a look at installing a wideband and adjustable fuel pressure reg (with gauge). You will be amazed at the extra drivability u can get by small fuel pressure adjustments. Not only that u can see how safe the tune is.
    Ive just installed today an AEM failsafe gauge with ethanol content metering and boost all in one gauge. Much easier to read display rather than the pocket calculator numbers of the old gauge. This will be of major benifits if you start powering it up a little. It’s abit addictive now I can see how the turbo guys keep developing their setups all the time.
    BMW’s
    90 E34 M5
    97 Z3 2.8
    OTHERS
    11 Audi S5 APR stg2
  15. #2840
    May 2010
    East Bay Area, CA
    01 Dinan 740iS, 97 318ti
    Anyone ever find or receive a resolution on the airbag recall issue? My E46 wheel and bag were purchased from a reseller and I haven't gone to the dealer to find out either.
    '01 740i Sport MKIV, Quad Brake Lights, OEM Bi-Xenon retrofit, LED Angel Eyes, HID Fogs, LED Plate Lights, Dinan 7 certification, BM53 radio, OEM Sirius, Aux Input, TCU Bluetooth, Intravee II, iPod, Strong Strut, Dinan Struts, Springs, Camber Plates, Intake, MAF, CAI, Exhaust and Throttle Body
    '99 318ti Titanium Silver '97 318ti Boston Green; '96 318ti Alaska Blue (sold); '08 X5 4.8i Titanium Silver (sold); '13 X5 3.5i Black Sapphire Metallic (sold)
    '84 633csi Black (sold); '88 325iC Black (sold); '97 740iL Black(sold); '01 740iS Black(sold); '97 318ti Alpine White (sold)
  16. #2841
    VA
    I've had enough time to mull it over and I'm absolutely keeping my e38.
  17. #2842
    Jul 2016
    San Diego
    1998 E38 750iL
    Good choice. If you're not going for the Ferrari, stick with the E38.
  18. #2843
    Alpine 7even's Avatar
    Alpine 7even is offline The King Of E38 Custom BMW CCA Member
    Mar 2011
    Haymarket VA
    e38 iL, F-e38 iL, e23 L7
    Good choice! It’s a beautiful build man!
    -2000 iL Individual. VF Supercharged at 12psi, Dinan MAF and TB, 6spd 420g swap, Euro under body guards, strong strut, N62 engine cover, Hydro trunk, Full suspension mods, Brembo F+R big brakes, custom headliner/interior, Bi-Xenon headlights, wide screen nav/mk4, Custom splash screen (I make them), coded video module with custom made harness, reverse camera, Intravee II, factory rear screen entertainment console, rear comms armrest, rear blower, seat back tables and writing tablet, all euro options coded on etc.
    -1997 iL. Pioneer 8500nex double din/Avic navigation, swc and dsp still functional. Reverse camera, full suspension upgrades, leather dash, console and door cards, rear blower, Re-upholstered seats, facelift sport contour seats, heated steering wheel, 750 front brakes, custom cup holder replacing the front ash tray, all euro options coded, headliner in black, rear headliner MID console.
  19. #2844
    VA
    Driving home from work today in left lane. Car in front of me goes to pass the vehicle in front of it. Turns out that was a slow driving truck hauling a trailer full of concrete mixing crap. As soon as the car goes to pass, a chunk of concrete nails my windshield. $1500 for a replacement... Guess I should feel lucky it didn't hit the A pillar.
  20. #2845
    IL
    2000 740i sport
    That car needs a forcefield built around it. Could have been worse...
    Sent from my SM-N910T3 using Tapatalk
  21. #2846
    VA
    I know! It makes is stressful to own sometimes. I had to park it on the street today while at lunch with a client and I went to check on it 3 times My wife told me I shouldn't even drive it to work but it's the most enjoyable part of my day when I do. If I don't drive it, what would be the point of having it?
  22. #2847
    IL
    2000 740i sport
    Quote Originally Posted by RVAE34 View Post
    So true! A gift and a curse...
  23. #2848
    Apollo Beach, Fl
    '92 BMW 735i(W/383 GM)
    I don't know who your carrier is, but I have Hagerty and they are really really good people, and they understand car people.
  24. #2849
    Oct 2007
    VA
    00 Mshoe
    The heck is the glass made of that it's $1500 to replace? Diamonds?!
  25. #2850
    VA
    It's because it has the UV/IR glass. Which I love so I'd never cheap out on the replacement.
Page 114 of 122 FirstFirst ... 146489104105106107108109110111112113114115116117118119120121122 LastLast
  1. Babushka's E38 Project-Update 07/2019 Car is now for sale
    By Babushka in forum 1995 - 2001 (E38)
    Last Post: 07-24-2019, 10:50 PM
  2. E38 Project
    By Jfstu in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 09-20-2006, 03:47 AM
  3. This could be YOUR next conversion project!!
    By marinersfan in forum 1975 - 1983 (E21)
    Last Post: 05-03-2006, 04:11 PM
  4. Buying E38 Project car? Where do I find the fun stuff?
    By 760list in forum 1995 - 2001 (E38)
    Last Post: 06-22-2005, 01:48 AM
  5. Is this Jim's next evil project?
    By dysphunxion in forum Off-Topic
    Last Post: 08-26-2002, 02:20 PM
