Results 1 to 17 of 17
Thread: Fuel leak
    Sep 2015
    GA,USA
    89 BMW 635CSI
    Fuel leak
    Hopefully someone can help me with this. Whenever I full my tank it leaks, not sure what to look for. It's fine if I don't fill it to the top but I'm guessing it's either a hole in the top of the tank or a fuel line hose. Has anyone else had problem with a gas leak?
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    Check the 3 ingress and egress pipes(tubes) on the right side of the gas tank by the filler pipe. They are known to rust and severely when they do.
    81 Euro undergoing total nut and bolt restoration
    pictures at: flickr.com/photos/bertsphotos
    Jul 2014
    Riga, Latvia
    e24 635csi
    rust destroys welded spots of the "neck", where you put the gas pistol in, which is welded to the fuel tank. usual e24, e12, e28 fuel tank problem. pull off the rubber cover, which is around the neck and you will notice the problem. and, as Bert mentioned, check those 3 pipes too
    Sep 2015
    GA,USA
    89 BMW 635CSI
    Quote Originally Posted by Bert Poliakoff View Post
    Quote Originally Posted by crime View Post
    rust destroys welded spots of the "neck", where you put the gas pistol in, is welded to the fuel tank. usual e24, e12, e24 fuel tank problem. pull off the rubber cover, which is around the neck and you will notice the problem. and, as Bert mentioned, check those 3 pipes too
    thanks for the fast reply guys. I'll be sure to check when I get home.
    W-S, NC
    84 E24, 91 M5, E36's,E46
    And the seal around the pickup, have had to replace mine before. It's on the top of the tank, so more likely to seep when it is full.
    When you say "leak" what do you mean exactly? Is it dripping or do you just smell it?
    '84 Euro 635CSi Polaris/Pacific, for sale (maybe)
    Home of the Silver Bimmers: '91 M5, '84 Euro E24, "99 E36, "98 E36, '02 E46 xiT (yes, all silver)
    Sep 2015
    GA,USA
    89 BMW 635CSI
    Quote Originally Posted by Sprocket View Post
    It does both. It makes a small puddle. I think it happens if I keep pumping gas when it stops.
    W-S, NC
    I guess I would suggest not doing that, eh?
    If it is actually dripping, then it is not (or more than) the pre-pump/pickup gasket. I would park it outside until you figure out and fix it.
    Seriously.
    Sep 2015
    GA,USA
    89 BMW 635CSI
    Seriously.
    I filled up yesterday and had no problem. Just stopped pumping when the gas pump clicked. If I do It drips and yeah I park my car outside anyways. Looking back I remember it leaked when I jack up the left side of the car. I'll try all the suggestions you guys gave me and knock it out. I'll report back my findings.
    Nov 2010
    Santa Ana, CA USA
    1988 m6
    Install new hoses, it takes about 10 feet
    Jay
    '88 M6 Cinnabar Red / Nappa Natur Highline Interior (10-87) Santa Ana, California. USA
    My NEW Website, Link : https://www.jaysbmwparts.com
    Booster repair
    A/C Wingcell Compressor leak repair
    e31 Door Handle Fix,
    Sep 2015
    GA,USA
    89 BMW 635CSI
    Going to get around to doing this as soon as it gets a bit warmer. Got a new job and currently drive her 80 miles a day and have to fill up every other day and At 16mpg hwy I’m sure the leak is the culprit. I’ve never driven my car more than a few miles so it’s interesting that even at 300k miles+ I rarely have to top up oil/coolant etc and have no other problems other than the UCAB I’ve been putting off replacing and the AC valve..
    Does anyone know where I can source some good hoses? I recall someone saying I need about 2m. Where does one sources hoses of that length? I’m gonna be sure to do it right so I never have to do this job again anytime soon.
    Feb 2009
    Pittsburgh, PA
    '86 635CSi, '08 128i
    I haven't dine this yet, but I was thinking about it this spring. I believe that BMW originally installed fabric-covered 6x11mm low-pressure fuel line, but I have a lot of standard BMW high-pressure 8x13 mm fuel injection hose I'll use instead. I know that high-pressure hose is overkill, but it's pretty tolerant of our high alcohol fuel mixtures over here. Any dealer and many US aftermarket parts suppliers (Blunt, Pelican, RockAuto, etc.) can get it for us.
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    Fabric covered hose is readily available. It is used on older VWs. I have been told to not use it and high pressure hose needs to be used. I have all lines installed with the fabric covered hose and hate to pull it out as it looks good and also retro at the same time. High pressure fi hose should be available at any decent parts store. Changing those hoses over is not a big job and maybe will take a few hours
    Sep 2015
    GA,USA
    89 BMW 635CSI
    I recall hearing something similar about the braided hose. Thanks. I’ll try grabbing some 6mm, 8mm and 12mm hoses from autozone or oreilly.
    Apr 2008
    Scottsdale, Arizona
    81 euro 635, 4.4 X5
    The seam that goes around the tank can also leak. I had to re weld part of the seam as gas was leaking from there. It only showed up if you filled the tank over 1/2
    Sep 2015
    GA,USA
    89 BMW 635CSI
    Haven’t considered that. I do know my top hose leaks, I’ll need to check the seam when I get under the car. Hopefully it’s not the tank. Mine only leaks when full.
    Sep 2015
    GA,USA
    89 BMW 635CSI
    Finally getting around to replacing these tomorrow. Does anyone know where these run to or how to replace them? I’m guessing I could access them from under the car?
    Aug 2011
    Ireland
    M3
    Hi
    The hoses go to a vapour tank in the (trunk) or boot on the right hand side. A hose then goes to a metal hose that runs along the rear bulkhead to the underneath of the car. This is the vent to atmosphere.
    Be careful removing the hoses from the tank as it is very easy to damage the metal pipes in the picture. If you cut the hoses and drop the tank you can inspect the tank and change all the hoses easily.
  1. Fuel leaking
    By azatty in forum 1991 - 1999 (E36)
    Last Post: 03-17-2004, 11:11 AM
  2. Motor died and will not restart - fuel leaking from rail/injectors
    By Mad Dog 20/20 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-30-2004, 05:48 PM
  3. 1992 325i fuel leak
    By Patrick Bateman in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-06-2003, 09:33 AM
  4. Fuel Leak
    By 318ispower in forum 1991 - 1999 (E36)
    Last Post: 11-20-2002, 02:49 AM
  5. E36 fuel leak revisited
    By ToneCapone in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 06-17-2002, 07:37 PM
