Results 1 to 12 of 12
Thread: E36 M3 SALOON LS6/LQ4 Swap.
    Aug 2016
    Coos bay
    e36m3.e30335is.e30325i.
    Hey guys I'm going to be starting my swap tomorrow and want to share and get feedback.
    1997 M3 Saloon, I'm pulling her heart and tranny and replacing with a lq4 bottom end with 243 ls6 heads. I'll list all the parts here soon, but I had a question do I need to remove or move or replace the brake booster? I've read yes no this that but not sure. Same with the steering shaft. Let me know if I'm missing something.
    2003 hummer h2 lq4
    243 ls6 heads(cathedral port)
    232/234 .598 Texas speed camshaft V.2
    Chromoly pushrods 7.4
    Muscle car race oil pan(for clearance)
    .625 PAC valvesprings
    Short fabricated ls6 racing intake(shorter runners)
    102mm throttle body
    Tune by frost
    Wiring specialist harness(to keep my obd2 bmw stuff)
    42lb EV1 injectors
    8vms spark cables
    MSD coilpacks
    Guna try to use the m3 radiator
    Dirty dingo alt relocation bracket
    Oil cooler and adapter
    Power steering line adapter
    Vorshlag drive shaft
    Vorshlag remote bleeder
    CX racing motor mounts
    Hugger headers Ebay
    Howards cams & racing components dual bearing aluminum race rockers
    Walbro 255 fuel pump
    Universal fuel and oil pressure regulator
    C6 T56 trans
    XTD stage 3 clutch and lightweight flywheel
    ARP head studs
    Dual chain comp cam sprocket
    Hawks third generation short throw shifter
    Megan racing 32 way adj coilovers
    Fender flares
    Vorshlag trans mount
    Drilled and slotted rotors (new pads)
    Stock rear end till it melts
    I think that's it prob more but let me know thanks.
    Nov 2008
    Minnesnowda
    97 M3, and others
    Are you still working on the swap, or is it complete? I'm doing the same in my 97 M3 sedan with a LQ4. currently researching the trans; leaning towards a nv3500 since t56's are $$$$
    also, how accurate was your parts list? I'm going to copy most of it.
    Wish you were closer to Minneapolis!
    NY
    325i, 530i, F250
    I can offer some input as im getting close to getting my car complete....
    You can keep the stock brake booster depending on what motor mount kit you have. I have Vorshlag and it fit fine. Close fitment but still fit.
    I bought a cheap stainless set of headers off of ebay and the driver fit fine but I also flipped mine for the turbo. I used an E46 steering shaft and modified it for the E36 couplings. That and the flipped manifold could be why I didnt have an issue but each case is different.
    Im not sure about the Muscle car oil pan, I thought I read somewhere that it doesnt work with our cars, I have the stock LS1 oil pan and it fit perfect
    Take a look at http://www.ictbillet.com for the alternator relocation brackets. I used their brackets for my alt, ps and I got the manual adjustable idler tensioner. The crappy stock GM ones will throw the belts.
    Good luck its a fun process.
    Sep 2015
    Stow, MA
    1997 328i
    Quote Originally Posted by simone36 View Post
    Don't go with an NV3500, definitely not strong enough to hold up to an LQ4, plus it's a truck transmission.
    Instergrams: @davemakepictar
    Nov 2008
    Minnesnowda
    97 M3, and others
    Thanks for the input guys... yea, everything i've read the past few days seems like the nv3500 is not the best choice.
    Do you (or anyone) have a recommendation for a manual trans?
    I havent had to time to dig deep and research everything yet. I'm looking to keep the LQ4 around the 450hp mark so I can keep as much stock m3 parts as possible for now. Doing my best to keep this as a budget build.
    Don't mean to hijack, but no sense in starting another thread.
    I'm still learning about this process and have a long way to go!!!
    Nov 2008
    Minnesnowda
    97 M3, and others
    Apparently a trans (cd009) from a 350z or g35 is a good alternative to the t-56 and is much cheaper.
    I've been looking for one of those.
    Nov 2015
    kelowna
    Z3 Coupe 3.0
    Yeah the muscle car pan is really tall. It's priced well as that kit.
    Must everyone uses the fbody pan.
    Nov 2008
    Minnesnowda
    97 M3, and others
    does anyone have the part number handy for the f body oil pan? Looking for the complete set.
    Been researching it the past few days and want to make sure i get the right part.
    does OEM fit the best? I also read Holley could fit, but dont know about the 302-1, 302-2, 302-3....
    Also, looking for flywheel suggestions.. In the end i went with the T-56 trans to pair with my LQ4
    thank you gents!
    Houston, TX
    1997 M3 Sedan
    Don't know if it fits best but it fits well. Good luck with the swap!
    Sent from my iPhone using Tapatalk Pro
    NY
    325i, 530i, F250
    thank you gents!
    I bought used on LS1tech, usually theres a few in there for sale...make sure you get fbody dipstick and tube...I have a brand new driveshaft for the T56 with stock 4 bolt diff if youre interested....
    Sent from my SAMSUNG-SM-G930A using Tapatalk
    Jul 2013
    FL Gulf Coast
    E36 - 1998 328iS - LS2
    does anyone have the part number handy for the f body oil pan? Looking for the complete set....
    thank you gents!
    Prices are from four years ago.
    Nov 2008
    Minnesnowda
    97 M3, and others
    Thanks for the offer, but I have the driveshaft already
  1. E36 Complete e36 m3 front 5 lug swap, coilovers, m3 brakes. NC
    By pottsalot in forum Suspensions, Springs & Shocks
    Last Post: 08-11-2012, 02:32 PM
  2. E36 1997 BMW E36 M3 with LS1/T56 swap
    By SHhhhh in forum 3 series & Z Series
    Last Post: 11-11-2011, 10:19 PM
  3. E36 Complete e36 M3 suspension, brake, diff swap, 78K miles
    By bth14 in forum Suspensions, Springs & Shocks
    Last Post: 11-01-2010, 01:29 PM
  4. E36 E36 m3 s52 engine tranny swap 2,500.00 120k florida
    By FLORIDADUDE727 in forum Engines, Performance Parts & Software
    Last Post: 03-29-2010, 04:41 PM
  5. E36 FS: E36 M3 complete 5 speed swap
    By efiniGTX in forum Drivetrain & Transmission Parts
    Last Post: 12-21-2009, 09:34 PM
